Old Wed, Nov-28-2018, 10:10:22 PM   #41
Default Re: OEM ZCP Rims Color, Best Powder Coat Match?
Here's what it looks like when a coarse grit aluminum oxide is used to prep the metal and then Porsche Silver applied.
Redone by a competent coater
and a DS2 set in the same color
Old Wed, Nov-28-2018, 10:45:07 PM   #42
campful
campful's Avatar
Reputation: 0 campful is on a distinguished road
Porsche Silver is probably the closest match you're going to find that will actually come out silver. It is CRITICAL that the coater blasts the wheels with a 300grit+ glass prior to application. If the bare metal looks dull and gray, your power will look dull and gray (I do not care what your guy tells you, the base metal color absolutely will change the look of the powder). They must have some luster to them.
I would advise you not to use clear vision clear. It cracks after a few years. I would avoid powder based clears altogether.
The rims are currently powder coated gun metal grey. I don't know everything about the process. Surly they will strip the coating that is currently on it.
| 01' e46 m3 w/ 6mt
| jet black
| read more ↓
https://campful.co/m3journal
https://www.instagram.com/cb_m3/
Jump to top campful is offline   Reply With Quote
Old Wed, Nov-28-2018, 10:46:22 PM   #43
campful
campful's Avatar
Second one looks on point. **EDIT** fully comprehended your last post, If I go this route (Porsche Silver) I'll request that the coater blasts with 300+ grit.
| 01' e46 m3 w/ 6mt
| jet black
| read more ↓
Old Wed, Nov-28-2018, 10:48:11 PM   #44
I just told you.
Old Wed, Nov-28-2018, 11:30:19 PM   #45
campful
campful's Avatar
I just told you.
And you didnít see the edit I literally made like one minute after asking.
| 01' e46 m3 w/ 6mt
| jet black
| read more ↓
Old Thu, Dec-06-2018, 05:19:41 PM   #46
Kdubski
Kdubski's Avatar
Any progress from anyone on matching to a prismatic color?
Sent from my SM-N950U using Tapatalk
Old Thu, Dec-06-2018, 08:58:51 PM   #47
ftapache
ftapache's Avatar
Reputation: 0 ftapache is on a distinguished road
Try Pacific Silver and report back to us. Thanks.
Sent from my Pixel 2 using Tapatalk
Revival Journal
Jump to top ftapache is offline   Reply With Quote
Old Thu, Dec-06-2018, 09:20:16 PM   #48
Kdubski
Kdubski's Avatar
Did you order a swath? Can you post a pic of how it looks under bright light?
Old Thu, Dec-06-2018, 09:28:54 PM   #49
ftapache
ftapache's Avatar
Nope. My wheels were done with BMW silver. See post #9.
Color samples will not match exactly with the end result. Depends on media being used for blasting.
Revival Journal
Old Fri, Dec-07-2018, 01:38:51 PM   #50
Kdubski
Kdubski's Avatar
The swaths I ordered are in. I think these are the closest. I dont have an actual wheel to compare against.
See attached
csl, powder coat, rims, zcp
Discussing OEM ZCP Rims Color, Best Powder Coat Match? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
