Old Thu, May-01-2014, 07:30:11 AM   #1
BrandonDunivent
BrandonDunivent's Avatar
Reputation: 0 BrandonDunivent is on a distinguished road
Default Meaty tire setup for ZCP wheels
Hey forum,
So it's time for me to buy some new tires, and I was wondering what some good sizes would be for a more beefier tire setup. I still want to keep a clean, flush look with my zcp rims but I want to add some meat to these wheels... right now I am running spacers (15f, and 12r) and ride high can be adjusted according to the setup, but Id just like to see what some of you are running. Any links, pictures, or advice would greatly be appreciated! thanks everyone.
MY JOURNAL
__________________________________________________ __________________________________________________ ___________________________________
| Supersprint Race Exhaust | Beisan Vanos upgrade| Dinan DME tune | ST coils | pc CSL rims w PA/S | Alu. BMWPedals | Alu. SMG paddles | Orion v2 AE | Depo led turn signals/side markers | Turner RSF plates |
Jump to top BrandonDunivent is offline   Reply With Quote
Old Thu, May-01-2014, 09:41:14 AM   #2
Flow
Flow's Avatar
France
Default Re: Meaty tire setup for ZCP wheels
If you want meatier tires, run 245/275 tires.
You can retain the OEM F/R ratio with this setup, and it looks better than the 225/255 setup.
2004 M3 TiAg / LSB SMG
Old Thu, May-01-2014, 12:32:18 PM   #3
duracellttu
Im in the same boat. Ive been running 265/30 and 235/35 for years but want a little more side wall.
^Flow what are the exact sizes you are running above?
2005 BMW M3 ZCP - Black/Black 2M Autowerks Full Restoration: RKP CF Roof Conversion, OE CSL Trunk, JCSL Diffuser
Paul Claudes Custom Tune | Kassel Performance CSL ECU Conversion+MAP Sensor | Lang Stage Stage 2.5 Head | 288/280 Schrick Cams+DLC Coated Followers | CSL Karbonious Airbox+OE Snorkel | SS V1 Stepped+Catted Sec 1+Resonated Twin Pipe+Race | 3.91 w/ 3 stage clutch
TCK SA 450/500 | Vorshlag Camber Plates | Rogue Engineering ASP, RSM | AKG FCABs, RTABs, SFBs | TMS Sway Bars, Camber Arms, Pullies | Mason Race Strut, Rear X-Brace | AS 30% SSK | SPAL Fan | Redish Reinforcement | Turbo Toys V2 Hub | WPC Treated Rod Bearings
Old Thu, May-01-2014, 01:12:43 PM   #4
eaglektd
eaglektd's Avatar
Reputation: 0 eaglektd is on a distinguished road
Most people with 19s run a 245/35R19 for the front and 275/30R19 in the rear. I run those with a modest drop, eibach springs so less than 1" and have no fitment/rubbing issues. These sizes are also almost identical in circumference so it won't mess with your wheel speed sensors.
Jump to top eaglektd is offline   Reply With Quote
Old Thu, May-01-2014, 03:11:15 PM   #5
PumpinIron
PumpinIron's Avatar
Reputation: 0 PumpinIron is on a distinguished road
I've run 245 / 275 on my ZCP wheels but I went back to the stock tire size and prefer it MUCH more.
Jump to top PumpinIron is offline   Reply With Quote
Old Thu, May-01-2014, 09:13:35 PM   #6
duracellttu
What makes you like stock setup more?
Old Thu, May-01-2014, 09:17:24 PM   #7
PumpinIron
PumpinIron's Avatar
Honestly? I feel like BMW Engineers knew what they were doing when they chose the stock tire size. Sure, people can argue that for a track car there might be a better tire size (and I'm sure there is) but for a car that is street driven I wouldn't doubt at all that the guys at BMW chose the correct size tire to get the job done.
Also, maybe I am wrong but with my 245 / 275 tire setup it seemed a little more 'rough' when I drove.
I know that a lot of things on these cars can be 'upgraded' to be better than factory. However, for a car that is mostly driven on the street I would say the guys at BMW did a top notch job of choosing the right tire sizes to get the job done.
Just my thoughts.
Old Thu, May-01-2014, 09:27:18 PM   #8
Kansas Corey
Reputation: 0 Kansas Corey is on a distinguished road
Originally Posted by BrandonDunivent View Post
Hey forum,
OP - very interested in hearing other responses as well. I'm currently running stock suspension, OEM ZCP wheels, stock tire sizes, and same spacers you've got. There was a thread recently about which tires had "fat sidewalls" here: http://m3forum.net/m3forum/showthread.php?t=465765
IMO, it's about the same type of question for me. I'd like a wider tread width, but I'm also interested in the meaty looking tire including a substantial sidewall.
Can't wait to see what others have to say and please, let us know what you decide.
Jump to top Kansas Corey is offline   Reply With Quote
Old Thu, May-01-2014, 09:34:34 PM   #9
daytonaviolet
OEM CSL Whoore
daytonaviolet's Avatar
i've been running 245/35 and 275/30 with 10mm spacers all the way around for several years (no rubbing).. with a slight drop the tires look really meaty.
Tischer aka GetBmwParts
Old Thu, May-01-2014, 11:15:00 PM   #10
I got a lot of tramlining with 275 rears. The car also felt slower - Like I had to drag the rear end around. Steering didn't feel as fast and easy as it does with 225 F and 255 R
Evolve-R Alpha N Evolve CSL CF Airbox Eventuri Scoop Supersprint V1 stepped 2.5" SS V1 S pipes 2.5" OE sect 2 SCZA 2.5" sect 3 Besian RE pullies fan/SAP/washer/fog delete CSL battery
Bilstein HD B6 + GroundControl/Eibach 325/550lb + GC "tall" RSMs Hotchkis front sway (med) rear strut bar TMS camber & subframe plates Eibach alu rear camber arms RE trans mounts AKG poly subf/diff 95a SDW RTAB OE weighted ///M knob + ZHP alcantara boot + UUC DSSR + delrin bushing
OE CSL trunk Cobra Nogaros + BK + manual OE bases TMS black pedals Sportline 8S 18"x 8.5/9.5" MPSS 245/275 APEX 75mm Studs Brembo 996 4 pot 36/40 345mm CSL & 28/30 328mm CSL ZHP "712" rack Pioneer/CDT/Eclipse/Kicker
beefy, meaty, tires, zcp
Discussing Meaty tire setup for ZCP wheels in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
