Old Tue, Oct-26-2010, 08:12:27 PM   #1
BlownE46M3
Reputation: 0 BlownE46M3 is on a distinguished road
Default Weird no start issue (searched)
Drove home Sunday night from DC, parked the car and it hasn't moved. I went to leave today and the car just turns over but will not fire. I checked voltage at the pump and it was 3.38v. I figured it was the relay but initially, I had a hard time locating the M3 fuel pump module/ relay so I continued testing.
I removed the pump and jumped it, pump works fine when I supplied 12 volts. I ultimately located the EKP fuel module but am unsure how to further test it. Any ideas? Also, it seems odd that the car didn't even fire with the fuel in the system. All it did was turn over. Has anyone experienced something like this before?
Thanks!
Jump to top BlownE46M3 is offline   Reply With Quote
Old Tue, Oct-26-2010, 08:50:31 PM   #2
EM3RGY
Captain Planet
EM3RGY's Avatar
Reputation: 0 EM3RGY is on a distinguished road
starter? bad gas?
2003.5 BMW M3 Vert CB/BLK 6MT | ECIS Intake | Topspeed Exhaust | StopTech ST40 BBK | TMS Swaybar | F2 Type 2 Coilovers | HRE 540 | BMWCCA - NCC | Elite Importz | www.mpacteast.com | GO TERPS!
Jump to top EM3RGY is offline   Reply With Quote
Old Tue, Oct-26-2010, 09:02:07 PM   #3
BlownE46M3
No, car turns over fine and has good gas.
I just jumped the pump in the car and it still won't start. I'm kind of stumped here....
Originally Posted by EM3RGY View Post
starter? bad gas?
Old Tue, Oct-26-2010, 10:26:29 PM   #4
BlownE46M3
Okay, so my peake tool wouldn't work, it kept giving a11e, which didn't make sense. I disconnected the battery for 10 minutes. Hooked it back up and the lights on the dash went off, which I thought was odd. I tried to turn it over and she fired right up.... Headed out for a blast now, I hope i make it home... LOL
Old Tue, Nov-09-2010, 09:46:46 PM   #5
cozilla
Reputation: 0 cozilla is on a distinguished road
Im not really sure of your issue but if you need a new fuel pump I have one laying around that I could sell you. Just PM me.
Good luck.
Jump to top cozilla is offline   Reply With Quote
Old Wed, Nov-10-2010, 04:12:06 AM   #6
ZiMMie
Reputation: 0 ZiMMie is on a distinguished road
Germany
Sounds like an EWS issue or a dying key. Go and have have EWS Module scan.
#E36S54 #CSLWannabe #TTFS @Mykesf
Jump to top ZiMMie is offline   Reply With Quote
Old Fri, Nov-12-2010, 10:54:37 PM   #7
BlownE46M3
It hasn't happened again. I did try both keys so, I don't think its a key issue. I will have to have the EWS scanned soon. Thanks!
Old Mon, Mar-07-2011, 06:17:14 PM   #8
BlownE46M3
Default Re: Weird no start issue (searched)
Gents,
So yesterday the M3 did the same thing again. It would just keep cranking but not fire. I finally disconnected the battery and this morning, she fired right up.
Does anyone have any idea what this could be? Essentially, something stops the car from sending power to the fuel pump. The car cranks with no issue and everything continues to work IE the radio, lights, horn etc. The only thing I see is the SMG selector won't register or go into gear when I move the selector, but I can hear the pump working.
I figure I have a module or computer issue somewhere, just hoping one of you have the fix.
FYI-Its not the fuel pump, fuel pump relay, starter Coils, plugs etc.
Thanks,
Ryan
Old Wed, Mar-09-2011, 08:59:32 PM   #9
BlownE46M3
Anyone?
issue, searched, start, weird
Discussing Weird no start issue (searched) in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
