Old Thu, Apr-09-2015, 12:19:07 AM   #11
Rez
Rez's Avatar
Default Re: Thoughts on Liqui Moly 10W-60 Oil For Use in S65 Engine?
Originally Posted by keca10 View Post
I would only use what BMW recommends.
I had my engine die out of warranty on my E46 M3. My block cracked! BMW replaced the whole engine for free (parts and labor), however they first wanted to see proof that I only used Castrol.
Castrol is cheap insurance.
What he said
Old Thu, Apr-09-2015, 12:59:39 AM   #12
Originally Posted by IIAp3x View Post
Liqui-Moly 10w 60 is no different than Castrol TWS... I have always used Liqui-Moly in all of my M's for hundreds of thousands of miles with no issues... It is a very high grade oil...
It's actually a bit better, from one standpoint. It is more viscous. So for hot climates or track use, that would be good. But TWS may be better than LM for those in colder climates as it has lower viscosity and pour point.
You could run 0w40 in M cars if the conditions were such (cold/cool/no track use).
Oil selection should depend on more than just price (or BMW's say)
Evolve-R Alpha N Evolve CF CSL Airbox Eventuri Scoop Supersprint V1 stepped 2.5" SS V1 2.5" sect 1 SS unres 2.5" sect 2 SCZA 2.5" sect 3 Besian RE pulleys/fan delete CSL battery
OE CSL trunk Cobra Nogaros + BK + manual OE bases TMS black pedals Sportline 8S 18"x 8.5/9.5" MPSS 245/275 APEX 75mm Studs Brembo 996 4 pot 36/40 345mm CSL & 28/30 328mm CSL ZHP "712" rack
Old Thu, Apr-09-2015, 05:14:14 AM   #13
admranger
Registered troublemaker
I have this oil in my E46M3. I'll be changing it out in May and sending a sample to Blackstone. Low mileage annual oil change.
Sadly sold: 11 E90 M3, Melbourne/Black/Fox Red/Black, 6MT, roof, PP2, heated seats, Eibach Pro Kit, GC Street camber plates, Arc-8's, Technic harness, JL XD 600/6
19 X3M40i, Carbon/Oyster
18 330i xdrive GT, Mineral White/Black
Old Thu, Apr-09-2015, 03:40:25 PM   #14
checkmate1
checkmate1's Avatar
Reputation: 0 checkmate1 is on a distinguished road
I use the LM 10W60 and so far, my car runs strong with no issues. I've had excellent blackstone results having used the oil.
@ $77 shipped, its a bargain with excellent value.
I have no idols. I admire work, dedication and competence.-Ayrton Senna
Jump to top checkmate1 is offline   Reply With Quote
Old Fri, Apr-10-2015, 06:06:23 PM   #15
Powerbeast
Reputation: 0 Powerbeast is on a distinguished road
Heard good things.
Jump to top Powerbeast is offline   Reply With Quote
10w60, engine, liqui, moly, oil, s65, thoughts
Discussing Thoughts on Liqui Moly 10W-60 Oil For Use in S65 Engine? in the E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convertible) (2008-2013) Forum - {Engine: S65 - Max Hp: 414 hp (420 hp Euro) at 8,300 rpm / 295 lb/ft at 3,900 rpm} at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
