Old Wed, May-25-2016, 04:43:57 PM   #31
natethegreat
Reputation: 0 natethegreat is on a distinguished road
Default Re: oil drain plug spins free
Originally Posted by Sandeep1212 View Post
Until one day it all comes out.
Just got to an indy and have them tap a new hole. Will not be more than a hundred bucks.
And hoping that never happens, but I'd rather fix it the right way then having to get a different size drain plug everytime.
2001 BMW M3 Steel Grey with LED Tails, Status Gruppe Catless Headers, AR20 Welded Section 1, Manzo Exhaust, Rouge Engineering Section 2 with QTP valve, Halos, EAS Filter and Silicon Elbow, VMR V703 CSL Replica Gunmetal Grey Rims, Michelin PSS tires, Stoptech rotors and pads, CSL one piece splitter.
Jump to top natethegreat is offline   Reply With Quote
Old Sun, Jul-17-2016, 02:10:16 AM   #32
Sh0ty
Reputation: 0 Sh0ty is on a distinguished road
Originally Posted by DanAvoN7 View Post
That is not correct. The threads are cut in to the pan itself. It is easy to strip the threads if the drain plug bolt is over-torqued.
Took a photo of the inside of my pan for others - the threads are indeed cut straight into the pan.
Thanks
Jump to top Sh0ty is offline   Reply With Quote
Old Sun, Jul-17-2016, 05:34:00 AM   #33
Jazzkat
Reputation: 0 Jazzkat is on a distinguished road
Are all of the stripped oil pan threads experienced related to aftermarket magnetic plugs?
My understanding and experience is that the OEM plug is softer than the pan, so if you over torque you will take out the plug threads but not the pan threads.
Jump to top Jazzkat is offline   Reply With Quote
Old Fri, Jul-22-2016, 02:25:56 AM   #34
m3 larry
m3larry
Reputation: 0 m3 larry is on a distinguished road
Well I had the problem with striped threads. Was not over torqued. Used Timesert with no problem for a couple of oil changes. Last time the Timesert came out with the plug. So chased the threads with tap and installed new Timesert. Torqued drain plug. Timesert leaked between insert and aluminum pan. So will drain oil and install insert with Locktite 660. I hope that will take care of problem.
Jump to top m3 larry is offline   Reply With Quote
Old Sun, Jul-31-2016, 08:06:25 PM   #35
Sh0ty
My drain plug was original and made of steel; the aluminum pan's threads are most certainly softer.
drain, free, oil, plug, spins
Discussing oil drain plug spins free in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
