Old Wed, Apr-14-2010, 01:28:04 PM   #41
JCaliber
Reputation: 0 JCaliber is on a distinguished road
Great Write up you have here 5 stars to this thread!
Jump to top JCaliber is offline   Reply With Quote
Old Fri, Apr-16-2010, 02:48:26 AM   #42
Zombie_
Reputation: 0 Zombie_ is on a distinguished road
awesome thread very detailed I'm new to the forum how could I save a quick link to this page?
Jump to top Zombie_ is offline   Reply With Quote
Old Fri, Apr-16-2010, 06:25:43 AM   #43
akbersaeed
DMD baby
Reputation: 0 akbersaeed is on a distinguished road
WOW. THat was an amazing DIY.
Jump to top akbersaeed is offline   Reply With Quote
Old Fri, Apr-16-2010, 12:42:51 PM   #44
dsm918
dsm918's Avatar
Reputation: 0 dsm918 is on a distinguished road
Go on top of this thread and look at the menu. Click on "Thread Tools" and from the drop down menu click on "Subscribe to this thread".
16 F80 AW/SO M3
09 E90 SG/Black M3
03.5 CB/Black M3
00 GSXR 600 (Track Star)
90 Nissan 300ZXTT
92 Eclipse GSX - 11.841 @ 117.11
Jump to top dsm918 is offline   Reply With Quote
Old Mon, May-17-2010, 10:51:57 PM   #45
WingsAA
WingsAA's Avatar
Reputation: 0 WingsAA is on a distinguished road
Originally Posted by dsm918 View Post
Reason I said that was because the power wire is clamped to the side of the intake (this is NOT the same clamp at the back on the intake between the firewall & the intake). It didn't seem like the power wire could come out of that clamp since the clamp has a very small opening and it is molded to the intake. That's why I suggested blindly opening the nut located at the starter which releases this wire. Opening that nut was a breeze. This is not saying that the power wire will not come out of the side clamp. I may just be missing how to get it out. Good point though
See this picture. The conduit seems too big to pull out of the clamp.
Thanks. I am glad that photo helped cuz I was concerned it might confuse some people more than it would help. Reason I even decided to do that was beacuse I totally missed the drain connection when I yanked the intake out. Luckily for me, it just unplugged instead of breaking
Just a heads-up around this clip. The clip that wraps around the battery cable simply slides up and can be removed so that you don't have to unbolt the terminal blindly.
Image of the clip:
Just pull up on the outside of the clip. It will slide upwards as shown below:
Here is the clip fully removed:
2004 Jet Black 6MT
Jump to top WingsAA is offline   Reply With Quote
Old Tue, May-18-2010, 05:17:10 PM   #46
dsm918
dsm918's Avatar
Image of the clip:
Awesome. Thanks for the pictures. I have to do this again to change the starter. This will come in handy
I have updated the original post with these changes.
16 F80 AW/SO M3
09 E90 SG/Black M3
03.5 CB/Black M3
90 Nissan 300ZXTT
Old Tue, May-18-2010, 07:29:12 PM   #47
rkmM3
Reputation: 0 rkmM3 is on a distinguished road
thanks to the op...this is amazing!!
Jump to top rkmM3 is offline   Reply With Quote
Old Tue, Jun-08-2010, 12:52:07 AM   #48
d3x74
apple pie shtn skip
d3x74's Avatar
Reputation: 0 d3x74 is on a distinguished road
Gotten around to the removing the starter motor yet?
So far its a PITA to remove and you need the right torx wrench to even get those two bolts out. Not that I have yet managed to remove them. :/
Jump to top d3x74 is offline   Reply With Quote
Old Mon, Jun-14-2010, 03:21:55 AM   #49
dsm918
dsm918's Avatar
Not yet. I bought the Torx wrench but haven't gotten around to doing it.
16 F80 AW/SO M3
09 E90 SG/Black M3
03.5 CB/Black M3
90 Nissan 300ZXTT
Old Wed, Jun-16-2010, 02:09:14 PM   #50
d3x74
apple pie shtn skip
d3x74's Avatar
Just got my starter motor and battery replaced. The car starts without any cranking noises whatsoever!
Hit the bolts a few times with a brass bar and a hammer and you should be able to get them of with a E12 open end torx wrench. Getting those bolts back in is a hassle too, but they go in easy if you pre-tread them about 10 times and use a lot of lube.
Thanks for the write up on removing the intake manifold. I cleaned up a lot of contacts too while I was at it.
car, cleaning, cleaning>>>, diy, diystarter, intake, intermittent, issue, issuecomplete, removal, replacement, starter, starting, terminal
Discussing Intermittent Starting Issue-Complete DIY-Starter Replacement (Intake Removal) in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
