Old Mon, Dec-21-2009, 01:59:05 PM   #21
M3Works4Me
learn to drive it or park it!
M3Works4Me's Avatar
Reputation: 0 M3Works4Me is on a distinguished road
I use ramps & my driveway is sloped away from the house, so when the car is on the ramps, it is almost level, not quite, but better than if I jacked it up.
Also, I don't understand how the hockey pucks are not designed to take the weight of the car, is that not exactly what they are there for?
I have used them with a floor jack every time I swap wheels, and as a matter of fact, if I jack the back one up a little farther than I need, the front on that side comes off the ground as well, so I can swap both wheels on that side quickly.
Who says these cars are not stiff? Even opening & closing the door on that side is no problem..
Anyway, great DIY, especially for those who have been asking.
'99 Estoril Blue ///M3, A few common mods, lots of driver training track days, a respectful performance driving attitude, and excellent tires. Member of the local car club driver training team.
Jump to top M3Works4Me is offline   Reply With Quote
Old Mon, Dec-21-2009, 02:08:39 PM   #22
ANT'S M3
FLIBIS!
ANT'S M3's Avatar
Reputation: 0 ANT'S M3 is on a distinguished road
Great write up D! I've been wanting to make one, but I cheat and use a lift so that would not help noobs in the jacking aspect of the oil change since that is the method most use. I don't know if I'm the only one but I remove the filter in cartridge cars before performing an oil change (unless the design doesnt let me).... Habit?? I guess...
- E30 M3 -
Jump to top ANT'S M3 is offline   Reply With Quote
Old Mon, Dec-21-2009, 02:54:55 PM   #23
JPoland
Broken My Wallet
JPoland's Avatar
Reputation: 0 JPoland is on a distinguished road
I typically just start draining the oil first and while I'm letting that drip out as much as will go, I change the filter. Then go and plug the drain pan up.
It may be seen as not the best way b/c "what if you forget to plug the pan back up" (oil everywhere when I put in the new stuff ) but I am in a habit of doing it this way so I always know plugging the pan is the next step after pulling the filter.
~Joe
Jump to top JPoland is offline   Reply With Quote
Old Mon, Dec-21-2009, 03:04:53 PM   #24
das borgen
Off-Topic King
das borgen's Avatar
Reputation: 0 das borgen is on a distinguished road
Originally Posted by Z3MCOUPE View Post
Wow - I've been performing the process correctly all along
sweet write-up for noobs .
I know I'm a car guy and all but sometimes it's actually advantageous to have a mechanic do your oil. Effectively when you are paying the cost of oil to have the wole job done, it's worth it.
That's the case at at least on my bike because my mechanic uses Mobil 1 Racing 4T, which is what I use
not 4 me though, because I use awesome oil
Jump to top das borgen is offline   Reply With Quote
Old Mon, Dec-21-2009, 08:40:45 PM   #25
kerph32
Unregistered user
Reputation: 0 kerph32 is on a distinguished road
nice DIY derek, but what about one for a non-Lux?
Mike
1997 Cosmos M3
2009 BSM 335d
DIY: Washer Fluid
Jump to top kerph32 is offline   Reply With Quote
Old Mon, Dec-21-2009, 08:41:04 PM   #26
Mark_c
Mark_c's Avatar
Reputation: 0 Mark_c is on a distinguished road
England
Great writeup - nice one
95 Dakar 3.0 Euro
ACS Type 3 alloys, HID lights, Cold Air Induction kit, New brake disks with Yellow Stuff pads, new clutch, Eibach coilovers, kumho tyres
Remapped to 320.6bhp
Jump to top Mark_c is offline   Reply With Quote
Old Wed, Dec-23-2009, 01:11:53 AM   #27
fiveightandten
fiveightandten's Avatar
RE: Hockey pucks...
From the Pelican Parts tech articles...
Now, turn your attention to the underside of the car. There you will see a round plastic cover that is used as a locator for shop lifts (Figure 4). It's quite possible that these have been removed and lost before, so your car may or may not have them in place. Using a flat-blade screwdriver, pry out the plastic guide from underneath the car (Figure 5). The remaining hole and reinforced plate is the area where you want to mount your jack stands. You have removed the plastic locator because the jack stand would be unstable if you simply placed it under the plastic locator and lowered the car.
http://www.pelicanparts.com/bmw/tech...Jacking_Up.htm
-Nick
Old Wed, Dec-23-2009, 01:14:35 AM   #28
fitchesbass
I couldn't find the sports car of my dreams, so I built it
fitchesbass's Avatar
Reputation: 0 fitchesbass is on a distinguished road
Thanks for all the comments folks. Happy Holidays
If joo haz de "sports package" then joo must take it to the $tealer!!!!!
-Derek
Prior BMWs:
E36 M3
E86 Z4MC
E92 M3
Jump to top fitchesbass is offline   Reply With Quote
Old Wed, Dec-23-2009, 01:16:37 AM   #29
Isis M
Soundgarden 2010
Isis M's Avatar
Reputation: 0 Isis M is on a distinguished road
Originally Posted by fitchesbass View Post
LOL thanks guys. I know it's not exactly cutting edge stuff here - but for new owners it's a step in the right direction of DIYing. I learned a lot about DIYing from my E36 and it only makes sense to pass it along to others.
I have not seen a good DIY with pictures either so hopefully that helps.
Funny story from CarTalk (the NPR car talk show): There were two woman friends that tried to change a husband's car's oil to save some money. They were at the time stay at home moms. Anyway, they ended up draining the trans fluid and then adding oil to the engine and driving the car. Essentially driving around with twice the amount of engine oil and nothing in the transmission.... So let's avoid this type of situation
Funny enough someone I know actually did this as well on Subaru Forester. I'm not a real fan of Subaru, but the car was driven about 20 min. or so with double the oil and no tranny fluid, and it ended up being fine once the fluid situation was sorted out.
That sailboat is Mvious!
Sold: 1997 Arctic M
Jump to top Isis M is offline   Reply With Quote
Old Wed, Dec-23-2009, 01:51:12 AM   #30
fitchesbass
^ wait that sounds familiar - maybe it's the same story LOL.
It was a guy that called into car talk telling the guys that his wife did it... perhaps your friend was covering up his own mistake. I believe the car on the show was ALSO a Subaru forrester.
-Derek
Prior BMWs:
E36 M3
E86 Z4MC
E92 M3
change, diy, diyer, e36, oil
Discussing DIY: E36 Oil Change - For the new DIYer in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
