Old Fri, Sep-18-2009, 05:42:53 PM   #1
blackmist27
Shake and Bake!
blackmist27's Avatar
Reputation: 0 blackmist27 is on a distinguished road
Default Anyone have a good DIY for rear seat removal?
Hi guys,
i did a search but didnt really find a good, clear DIY for rear seat removal. anyone find something i missed?
Instagram: Blackmist27
2011 E82 1M BSM 642 of 740 (Current)
2011 E92 M3 AW Comp (SOLD)
2004 E46 M3 TIAG (SOLD)
2004 E46 M3 LSB (SOLD)
Jump to top blackmist27 is offline   Reply With Quote
Old Fri, Sep-18-2009, 06:03:04 PM   #2
Serious
Serious's Avatar
Reputation: 0 Serious has a spectacular aura about
pull up on bottom cover and pull it out.
put down both back folding seats.
take out torx screw and little bracket.
remove seat backs by pulling up and then towards center of car.
Jump to top Serious is offline   Reply With Quote
Old Fri, Sep-18-2009, 06:19:09 PM   #3
blackmist27
Shake and Bake!
sounds easy enough... thanks!
Old Fri, Sep-18-2009, 06:45:25 PM   #4
Mash3
Look out below!
Reputation: 0 Mash3 is a jewel in the rough
It's too easy for a real DIY.
What is the weight savings? Must be around 40lbs. Those rear seatbacks are nice and heavy, which kills a lot of noise from the rear. Driving without the seatbacks is pretty cool, like a free exhaust mod. But it gets annoying after a few hours.
http://www.m3forum.net/gallery/data/522/medium/Willow_.jpg
Forum Member Since 2003.
. . 2004 M3, SG/ IR. No sunroof. 6MT. MCS SA. 18" Squares. Z4M rack. 130,000k miles. Original owner.
Jump to top Mash3 is offline   Reply With Quote
Old Fri, Sep-18-2009, 09:42:23 PM   #5
Reach
Reach's Avatar
Reputation: 0 Reach is on a distinguished road
Even folding down the seats and driving lets you know how much noise those suckers are blocking. There is just no insulation in the trunk, and several openings to free air on the bottom.
Removing the rear seats is super easy, just go do it. I did to install harness attachment points, then put my stock interior back in over it.
Jump to top Reach is offline   Reply With Quote
Old Sat, Sep-19-2009, 01:23:00 AM   #6
M3&CLK55
M3&CLK55's Avatar
Reputation: 0 M3&CLK55 is on a distinguished road
Taiwan
Default rear seats
if you need step by step diy, you can alway check with the ipod ice diy for coupe, it will show you how to pull the rear seat out.
Jump to top M3&CLK55 is offline   Reply With Quote
Old Sat, Sep-26-2009, 05:55:54 PM   #7
blackmist27
Shake and Bake!
ya but it doesnt show the seat backs...
so from what i can tell by reading how multiple people describe the job, basically you:
1)yank the bottom seat out. up and then bend to clear sides
2) then you remove the drivers side bolster to get access to a hook or something?
3) just remove bracket of seat backs
does that sound right?
Old Sat, Sep-26-2009, 06:12:20 PM   #8
daytonaviolet
OEM CSL Whoore
daytonaviolet's Avatar
first remove the metal cover over the boltsters (push down into the center of the plastic pin with a small screw driver). then the sides of the metal covers attched to the window motors via a plastic round cover (just push those out with your finger tips)
the rear bolsters are held down by a top clip and a hook on the bottom. to remove the top clip correctly, you need to be in the trunk (take off the trunk liners so you can see them) and press either the top or the bottoms of the clip. the clip goes into a square hole so presssing either the top of bottom of the clip will release it.
other wise if you just pull, you'll bust the clip.
Tischer aka GetBmwParts
Old Sat, Sep-26-2009, 07:43:08 PM   #9
Mash3
Look out below!
Is that for a convertible?
For a coupe, after you remove the bottom bench you will find, right in the middle at the back edge just under the seatbacks, a metal clamp held with a Torx bolt. Loosen this and remove the top of the clamp. You will see that the rear seatbacks are hinged here, and can be pulled up then wiggled out of the side point.
Old Fri, Oct-23-2009, 04:54:13 PM   #10
Tak555
Tak555's Avatar
Reputation: 0 Tak555 is on a distinguished road
thread revival... somewhat related question
okay, so i have a busted rear folding seat "actuation unit" PN 52208240507 / 52208240508... or at least i think i do. i pull on the lever and nothing happens, so i'm assuming that the metal cord that connects the lever to the release snapped.
my question is, how do i drop the rear seat so that i can work on it, and once i do that, will it be hard to string the new one through? to me it seems like it should be pretty easy, but when i looked in the trunk, it doesn't seem very accessible. thoughts?
http://www.realoem.com/bmw/showparts...31&hg=52&fg=30
Previous Cars:
2004 BMW /// M3 Coupe
Jet Black, Black Nappa, SMGII, HK Sound, E92 18" Wheels w/PS2s, TCK SA 500/500, DINAN exhaust, PF RTAB, DICE
E9X 18" Wheel Specs:
18x8.5 ET29
18x9.5 ET23
Previous Cars:
2004 Audi S4 Avant (owned for a week... returned to Carmax after independent inspection came back negative)
2003 Mitsubishi Evolution8
2003 Subaru Impreza WRX
1999 Subaru Impreza 2.5RS
1992 Toyota Pickup
Jump to top Tak555 is offline   Reply With Quote
diy, good, rear, removal, seat
Discussing Anyone have a good DIY for rear seat removal? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
