Old Tue, Nov-11-2008, 05:44:39 AM   #11
iSoykher
iSoykher's Avatar
Reputation: 0 iSoykher is on a distinguished road
Ukraine
If the alignment shop can't get it done for you, here's a solution you can try.
If wheel is straight and car drives to the left, this means if you try to keep the car straight your steering wheel is turned to the right.
So first thing to do, mark the outter part of the tie rod on both sides and the inner tie rod on both sides. For a reference point.
So now what is happening is once you straighten you wheel the wheels are actually turned to the left. (Left wheel is toed out and right wheel is toed-in).
Since the M3 tie rods are in the front you want to shorten the driver's side tie rod and lengthen the passenger side, both the same amount(using the marks you made earlier as a reference point).
Hope that helps
Jump to top iSoykher is offline   Reply With Quote
Old Tue, Nov-11-2008, 07:33:28 AM   #12
YellowDragon
YellowDragon's Avatar
Reputation: 0 YellowDragon is on a distinguished road
Taiwan
How's the tire condition? Are they new or worn? Pulling could be an indication of uneven wear of tires due to off-camber or toe, worn RTAB, etc. New set of tires with proper alignment should take care of the problem. Check the wear bars on tires.
I don't believe taking off steering wheel with recentering will solve the problem. If you do that, the car will still pull to the left with steering wheel pointing in the same direction.
If you really want to straighten out the steering wheel with reduced pulling and don't care about messing up the original alignment - which you can deal later with realignment after new tires, fixed suspension components, etc. - you can do it by increasing the positive toe on the left front (driver's side) wheel by shorten its tie rod by rotating it top-to-bottom. Rotate the rod approx. 10-15 degrees at a time, do a test drive, then readjust if necessary.
MENAGE A TROIS: 997 SPEED YELLOW GT3 & DAKAR YELLOW Z3 EXCLUSIVE EDITION & DAKAR YELLOW E46 M3 INDIVIDUAL
Jump to top YellowDragon is offline   Reply With Quote
Old Tue, Nov-11-2008, 10:29:49 AM   #13
babydevilj
Sperm Dispenser
babydevilj's Avatar
Reputation: 0 babydevilj is on a distinguished road
Thanks for all the info I'll update on the weekend :-)
Jump to top babydevilj is offline   Reply With Quote
Old Tue, Nov-11-2008, 10:49:38 AM   #14
Makavelim3
M3 Devil
Makavelim3's Avatar
Reputation: 0 Makavelim3 is on a distinguished road
its an easy issue, you should be able to solve it at any good grage with an new alingment machine.
Currently looking for a new M3 or M4
Current Rides:
- 2011 Porsche Turbo 997.2
- 2016 Mazda 6
Gone but not forgotten: Euro 2004 E46 M3, 2011 E92 M3, 2010 E60 M5
Jump to top Makavelim3 is offline   Reply With Quote
Old Thu, May-26-2016, 03:00:30 AM   #15
BTB
BTB's Avatar
Default Re: steering wheel alignment...
Bumping up this thread... I have a similar problem.
My steering wheel has been slightly misaligned since I got the car (3 years ago). The wheel is rotated ccw (left) a few, maybe 10 degrees when the car drives straight. The car doesn't pull in any direction on throttle or brakes, and I've had probably 3 alignments since getting the car, the wheel has always been slightly crooked. This leads me to think I don't need to touch the suspension.
I ordered an OMP wheel/adapter hub that should arrive next week, to clarify, there is a way to simply adjust the alignment of the steering wheel when I take my old one off, right?
My Journal
Jump to top BTB is online now   Reply With Quote
Old Thu, May-26-2016, 03:30:03 AM   #16
m3 hal
The correct way is to adjust it out in an alignment. Ask the shop to center the steering wheel. It's easy to do but some techs don't bother to check/correct for this unless asked.
Old Thu, May-26-2016, 03:40:51 AM   #17
BTB
BTB's Avatar
Interesting.. Not that I don't believe you, but if you can answer, what is exactly wrong with just rotating the steering wheel slightly? Is the (steering) wheel centered already with the steering rack, so that right now the tie rods are basically incorrectly adjusted so that the wheels point right slightly when the wheel is straight? I don't see how any tech could think that's ok if that's the case. They should center the steering wheel before touching the alignment, no?
My Journal
Old Thu, May-26-2016, 04:31:05 AM   #18
m3 hal
The tie rods aren't the same length on each side when the car isn't aligned with the wheel centered, so suspension geometry is affected slightly. It's probably not noticeable, and I don't think it would damage anything, but it would bother me because rotating the wheel is a band-aid fix.
Yes they should, but it takes a little bit of effort and some places just don't care.
Old Thu, May-26-2016, 01:55:17 PM   #19
sergbaja5t
Uncle Grandpa
sergbaja5t's Avatar
Reputation: 0 sergbaja5t is on a distinguished road
Just as a reminder, if your steering wheel is off center, and have the "Triangle of Pain" illuminated, the off center steering wheel is the issue and once you correct the wheel/alignment, YOU should reset the DSC ecm (there's an action for this in pa-soft/IPNA). Once this is done, calibrate the DSC by driving in figure eight lock to lock a couple times, then you should be golden. If not, then you other underlying issue's with your DSC.
2016 Ford F150 Screw sport Egoboost
2005 SilberGrau Met/Schwarz M3 Smg, VMR 703 reps, Megan Racing sec 3, Bilstein PSS10/Koni
2002 StahlGrau MET/Schwarz M3 6spd AA headers, Supersprint x-pipe, AA Gen 4 sec3, Besian hub and seals, Turbotoy hardware, Rouge Engineering Vanos & Coolant pipe, Arp studded, H&R/ST/Bilstein coilovers, M220 19's. S54 timing tool w/ two guide pins**FOR RENT** Atlanta valve adjustment service(ask about rates)! Simple coding & DME scanning (Atlanta area)
Jump to top sergbaja5t is offline   Reply With Quote
Old Thu, May-26-2016, 02:56:40 PM   #20
Tom_schleg
Reputation: 0 Tom_schleg is on a distinguished road
Mine does this, I had someone look at it and they said they could fix it, however, when they went to align it my tie rods where seized so they couldnt do it until i replace those
Jump to top Tom_schleg is offline   Reply With Quote
alignment, steering, wheel
new tires mounted and wheel alignment steering wheel is not centered? supermane46m3 E46 M3 (2001-2006) 10 Thu, Apr-08-2010 03:29:13 AM
steering wheel crooked...not alignment prorcracer87 E46 M3 (2001-2006) 14 Tue, Jul-21-2009 04:57:11 PM
steering wheel of centered after alignment x-rated_e46 E46 M3 (2001-2006) 2 Tue, Oct-21-2008 12:49:15 AM
steering wheel vibrating, even after alignment TakmaN E46 M3 (2001-2006) 8 Thu, Jun-19-2008 02:50:57 AM
Steering wheel becomes so light after Alignment. Please help! M3_Fan E46 M3 (2001-2006) 7 Sun, Oct-29-2006 04:54:22 AM
Discussing steering wheel alignment... in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
