Old Tue, Sep-30-2008, 08:39:32 PM   #1
d0nkeyxpunch
///M3 n00b
d0nkeyxpunch's Avatar
Reputation: 0 d0nkeyxpunch is on a distinguished road
South Korea
Default Is there DIY for Engine Belt change?
Do you guys have a DIY for Engine Belt replacement?
How hard is it? Is it difficult or need a special tool for the BMWs?
Jump to top d0nkeyxpunch is offline   Reply With Quote
Old Thu, Jul-02-2009, 11:06:45 PM   #2
ZuperJameZ
Reputation: 0 ZuperJameZ is on a distinguished road
I want more information to
03 M3 IR/IR Cabriolet with SMG
Aluminum trim, 19" OEM rims, upgraded HK with two 8 inch subs and sunken amp, removable hardtop, xenons, and power seats.
Jump to top ZuperJameZ is offline   Reply With Quote
Old Fri, Jul-03-2009, 03:49:09 PM   #3
GurvM3
GurvM3's Avatar
Reputation: 0 GurvM3 is on a distinguished road
it is quite simple
there is a write up on e46fananitcs i will try to find it for you
you will have to take the AC belt off first and then get to the drive belt it should not take more then 2 hours on your driveway.
Jump to top GurvM3 is offline   Reply With Quote
Old Thu, Jul-09-2009, 10:52:38 PM   #4
dveloz01
dveloz01's Avatar
Reputation: 0 dveloz01 is on a distinguished road
Dominican Republic
Its not bad to do if you have the right tools and are good with your hands.. Its a little tight. With a lift its a 30 min job.. On the ground its about 90 mins or so.. Its really simple to do... The lack of space is the only pain in the butt... Its a 2 belt system no different from any other drive belt install..No special tools needed.. although a drive belt replacement wrench would help since its thinner..but I used regular tool set I had in the trunk so you should be fine..
Go Hard or Go Home...
2004 6-speed, Nav, vert
1987 Mustang Notch
2006 GSXR
Jump to top dveloz01 is offline   Reply With Quote
Old Sat, Dec-05-2009, 05:29:43 PM   #5
stubadub
stubadub's Avatar
Reputation: 0 stubadub is on a distinguished road
Default Pelican Parts Belt Replacemet DIY
Pelican Parts Belt Replacemet DIY.....i think this should be listed on our DIY page.
http://www.pelicanparts.com/bmw/tech...eplacement.htm
Jump to top stubadub is offline   Reply With Quote
Old Mon, Dec-07-2009, 09:53:05 PM   #6
OneFastSicilian
Frankie
OneFastSicilian's Avatar
Italy
is there anywhere we can buy a belt besides bmw? and is that write up accurate for all 3 series? or is the m3 different?
Jump to top OneFastSicilian is offline   Reply With Quote
Old Fri, Dec-11-2009, 06:48:56 PM   #7
evannever
Reputation: 0 evannever is on a distinguished road
This thread pretty much becomes the belt DIY on the second page:
http://www.m3forum.net/m3forum/showt...changing+belts Read through it because you might have two different types of pulleys and it will save you time if you know what you're dealing with.
Jump to top evannever is offline   Reply With Quote
Old Fri, Dec-11-2009, 06:50:16 PM   #8
evannever
ECS Tuning has belts: http://www.ecstuning.com/BMW-E46-M3-...L/Search/Belt/
Old Fri, Dec-25-2009, 04:02:59 PM   #9
MadeInPhilly
Reputation: 0 MadeInPhilly is on a distinguished road
Theres 2 different accessory belts listed. which one is the OEM?
Jump to top MadeInPhilly is offline   Reply With Quote
Old Sat, Jan-02-2010, 02:39:45 PM   #10
SickSeries
Reputation: 0 SickSeries is on a distinguished road
There are two main belts. The accessory drive belt which drives all major pullies for water pump, alternator, and power steering. The other belt, which is much shorter, is the A/C drive belt.
Jump to top SickSeries is offline   Reply With Quote
belt, change, diy, engine
Is there a DIY for replacing AC belt? gazosnic E46 M3 (2001-2006) 19 Mon, May-11-2009 04:48:34 PM
Looking for seat belt replacement DIY mpegripper E46 M3 (2001-2006) 0 Tue, Mar-25-2008 08:52:01 PM
DIY Oil change, Air Filter Change, Spark Plug and Brake Fluid NooK E36 M3 (1992-1999) 6 Tue, Jun-05-2007 03:53:05 AM
Belt change lola1 E36 M3 (1992-1999) 19 Sat, Feb-03-2007 04:03:46 PM
AC belt replacement - DIY? blink21me E36 M3 (1992-1999) 2 Wed, Oct-11-2006 01:24:11 PM
Discussing Is there DIY for Engine Belt change? in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
