Old Fri, Nov-27-2015, 03:23:24 PM   #31
ROASTM
Reputation: 0 ROASTM is on a distinguished road
Default Re: DIY for Front Wheel Bearing Replacement?
I've got a bearing going out on the left front, based on what i've read in this thread. High pitching whining when turning right (away from side I think is going back), and it's gotten progressively worse over the last month.
You guys would recommend just replacing both fronts while at it? 121k miles, and to my knowledge, these have never been replaced (I've owned the car since ~79k).
Also, which do you guys recommend from ECS? Worth paying the extra for the OEM BMW?
https://www.ecstuning.com/BMW-E46-M3-S54_3.2L/ES49602/
The second link below:
https://www.ecstuning.com/BMW-E46-M3....2L/ES2993016/
Has BOTH front bearings/hubs for less than the price of one of the OEM Bmw parts... I'm not at all opposed to spending the extra $$$, but do you guys think it's worth it in this case?
Thanks
JB/JB 2006 M3 Coupe - Bought CPO 4/2012
3 pedals - Dinan Intake - Dinan TBs - DINAN Free Flow Exhaust (Muffler only) - Dinan ECU - Dinan SSK - HRE - Ground Control Street Coilovers & Camber Plates - Painted Reflectors - No Front Plate
Last edited by ROASTM; Fri, Nov-27-2015 at 03:26:32 PM. Reason: Additional Information
Jump to top ROASTM is offline   Reply With Quote
Old Fri, Nov-27-2015, 03:34:55 PM   #32
tinman143
tinman143's Avatar
Reputation: 0 tinman143 is on a distinguished road
I would do both sides. IIRC, I went with F AG brand from fcpeuro site. They are OEM vs OE.
Jump to top tinman143 is offline   Reply With Quote
Old Fri, Nov-27-2015, 04:15:12 PM   #33
Mash3
Look out below!
Reputation: 0 Mash3 is a jewel in the rough
Default DIY for Front Wheel Bearing Replacement?
My symptom was a loud clicking noise under hard turning. I used an F AG bearing; replaced only the bad side.
Hardest part was cutting the old inner race off with a Dremel.
You'll need a thin wall socket for the tight clearance around the 46mm nut.
Sent via iPhone/Tapasquawk
http://www.m3forum.net/gallery/data/522/medium/Willow_.jpg
Forum Member Since 2003.
. . 2004 M3, SG/ IR. No sunroof. 6MT. MCS SA. 18" Squares. Z4M rack. 130,000k miles. Original owner.
Jump to top Mash3 is offline   Reply With Quote
Old Fri, Nov-27-2015, 04:33:58 PM   #34
dtmpowerjc
dtmpowerjc
dtmpowerjc's Avatar
Reputation: 0 dtmpowerjc is on a distinguished road
I wonder if that brand is as good as oem or ***
Jump to top dtmpowerjc is offline   Reply With Quote
Old Fri, Nov-27-2015, 07:57:59 PM   #35
bsquare
Reputation: 0 bsquare is on a distinguished road
yeah, don't do that. remove the screws holding on the dust shield, shift the shield towards the front of the car, and you have enough room to get a punch against the back of the race. then (carefully) hammer it off. take care not to damage the abs sensor.
2006 M3 Base SMG AW/IR slicktop
Jump to top bsquare is offline   Reply With Quote
Old Fri, Nov-27-2015, 07:59:36 PM   #36
bsquare
F.A.G. is oem. the question is whether it is as good as oe. the answer is yes, they are the same as oe, they just don't say bmw on them.
Old Fri, Nov-27-2015, 08:02:50 PM   #37
dtmpowerjc
dtmpowerjc
dtmpowerjc's Avatar
Yes f.a.g is oem brand. I mean the brand ecstuning is selling as a pair.
Old Sat, Nov-28-2015, 07:50:07 PM   #38
ROASTM
It looks like a different brand on the two bearings that are sold in a kit packaged by ECS - "Optimal"?
Just crazy to me that these as a pair are still a bit less than the OEM BMW single replacement hub/bearing...
Old Sat, Nov-28-2015, 09:03:18 PM   #39
BTB
BTB's Avatar
Just curious, about what mileage are you guys finding your wheel bearings last till? I'm at 163k, have no knowledge of them being replaced and haven't had any issues/noises that I'm aware of.
My Journal
Old Sun, Nov-29-2015, 03:09:34 AM   #40
dtmpowerjc
dtmpowerjc
dtmpowerjc's Avatar
My thoughts exactly. Per my research they are reputable like oem quality German made quality parts. Ecs doesn't sell cheap crap. It's a good deal and it comes with everything. This is my next project.
bearing, diy, front, replacement, wheel
Front wheel bearing/hub DIY ? Special tools? m3keeper E46 M3 (2001-2006) 16 Fri, May-10-2013 11:14:04 PM
Advice on rear wheel bearing replacement jskene E46 M3 (2001-2006) 6 Sun, Aug-07-2011 11:53:17 AM
Any wheel bearing DIY? Silver///M Faults, Fixes and DIY 3 Tue, May-20-2008 12:26:58 PM
rear wheel bearing DON'T DIY EMMM TREE E36 M3 (1992-1999) 3 Wed, Aug-30-2006 12:47:13 AM
CPO vs Clutch and wheel bearing replacement so gti E46 M3 (2001-2006) 1 Thu, Aug-03-2006 08:46:31 PM
Discussing DIY for Front Wheel Bearing Replacement? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
