Old Mon, Aug-04-2008, 06:30:00 PM   #11
nrubenstein
Originally Posted by sqpablo View Post
thanks for the replies, sounds easy enough. Besides the socket to remove & install and barring puller are any other specialty tools needed?
A flathead screwdriver, and ideally a chisel. Remember to buy a replacement nut and replacement dust covers. You don't *need* these, but it's better to replace them now. (Becuase you want them fresh if you ever have to reuse them.)
Old Mon, Aug-04-2008, 11:54:44 PM   #12
oneblumcm
Reputation: 0 oneblumcm is on a distinguished road
Maybe these will help. I knew the Bentley would come in handy, for someone....I just haven't had the need yet. At least it's not collecting dust!
2007 Z4 M Coupe Silbergrau A08 / Sepang Brown LSD6 / Carbon Leather 4MY
2004 M3 Coupe Silver Grey 6mt, the 2.5 years was a blast
Jump to top oneblumcm is offline   Reply With Quote
Old Tue, Aug-05-2008, 02:39:35 AM   #13
nrubenstein
wtf, why do they want you to pull the ABS sensor?
Old Tue, Aug-05-2008, 03:12:18 AM   #14
Str8///Left
Leave the others behind.
Str8///Left's Avatar
Reputation: 0 Str8///Left is on a distinguished road
Originally Posted by Nick325xiT 5spd View Post
WRONG.
oopps..my bad..haven't done those in awhile.
Jump to top Str8///Left is offline   Reply With Quote
Old Tue, Aug-05-2008, 12:42:36 PM   #15
sqpablo
Lurker
sqpablo's Avatar
Reputation: 0 sqpablo is on a distinguished road
thanks, i need to get one of those.
Jump to top sqpablo is offline   Reply With Quote
Old Tue, Aug-05-2008, 04:06:51 PM   #16
Gladius
Game Designer
Gladius's Avatar
Reputation: 0 Gladius has disabled reputation
what are the symptoms of a bad wheel bearing?
'07 SilverGrey Z4M Coupe || '11 SpaceGrey 328i XDrive
Jump to top Gladius is offline   Reply With Quote
Old Tue, Aug-05-2008, 04:15:12 PM   #17
montego
Semper Fi
Reputation: 0 montego is on a distinguished road
ditto?!^^^
Jump to top montego is offline   Reply With Quote
Old Tue, Aug-05-2008, 05:45:36 PM   #18
gonzjed
gonzjed's Avatar
Reputation: 0 gonzjed is on a distinguished road
good point, the nut and dust covers are only a few bucks. the size socket for the hub nut is 46mm as I had to go to a specialty tool store becasue sears didn't have them that big. also, check the torque specs on the nut...I forgot and don't have my bently handy so you need a torque wrench too. good luck
Jump to top gonzjed is offline   Reply With Quote
Old Tue, Aug-05-2008, 05:47:19 PM   #19
gonzjed
gonzjed's Avatar
that bently will come in handy and a good resource for DIYers.
Old Tue, Aug-05-2008, 05:58:35 PM   #20
oh2fly
oh2fly's Avatar
Reputation: 0 oh2fly is on a distinguished road
You can't miss them: The most obvious is a grinding noise that will get louder as the bearing gets worse. It will be louder tuning in the direction opposite the side the bad bearing is on.
You may also be able to jiggle the wheel when it's off the ground. These are the two most obvious signs I'm aware of.
Jump to top oh2fly is offline   Reply With Quote
bearing, diy, front, replacement, wheel
Front wheel bearing/hub DIY ? Special tools? m3keeper E46 M3 (2001-2006) 16 Fri, May-10-2013 11:14:04 PM
Advice on rear wheel bearing replacement jskene E46 M3 (2001-2006) 6 Sun, Aug-07-2011 11:53:17 AM
Any wheel bearing DIY? Silver///M Faults, Fixes and DIY 3 Tue, May-20-2008 12:26:58 PM
rear wheel bearing DON'T DIY EMMM TREE E36 M3 (1992-1999) 3 Wed, Aug-30-2006 12:47:13 AM
CPO vs Clutch and wheel bearing replacement so gti E46 M3 (2001-2006) 1 Thu, Aug-03-2006 08:46:31 PM
Discussing DIY for Front Wheel Bearing Replacement? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
