Old Tue, Jan-06-2009, 11:44:00 PM   #31
s50swapped
Reputation: 0 s50swapped is on a distinguished road
Originally Posted by Sirius View Post
What caused it?
Mr oil pump nut.
Jump to top s50swapped is offline   Reply With Quote
Old Wed, Sep-21-2011, 11:21:55 PM   #32
Sirius
How many licks..
Sirius's Avatar
Default Re: Oil Light Flicker (when hot)
Originally Posted by Isis M View Post
are you overheating at all at idle with the a/c on? for me the flicker was the pusher fan being dead part number 64508364093
I am having this exact symptom right now. Flicker at idle. However, my pusher fan is dying (one on order). Hopefully that fixes the issue. The engine only has about 82k on her... no extreme driving done.
♪♫♪♪♫♪ Trevor ♪♫♪♪♫♪
97' M3. '10 R6.
Old Thu, Sep-22-2011, 12:01:21 AM   #33
bimmaboy88
bimmaboy88's Avatar
Reputation: 0 bimmaboy88 is on a distinguished road
Armenia
you might want to check on your cooling components. i live in Cali and even when its 100+ outside i don't have that problem....and what brand and grade oil do you use?
Jump to top bimmaboy88 is offline   Reply With Quote
Old Thu, Sep-22-2011, 12:16:32 AM   #34
Sirius
How many licks..
Sirius's Avatar
I get the Castrol Mineral (non-synth) oil that BMW sells. Old habit from working at the dealer years back. 15w-40 iirc. This started many weeks ago and it has been a lot hotter than it currently is. I replaced the water pump last year along with the t-stat. But, I did notice my pusher fan is not functioning correctly and it seems this all started around when I noticed the dying fan.
97' M3. '10 R6.
Old Thu, Sep-22-2011, 02:30:06 AM   #35
BMWDAD
Reputation: 0 BMWDAD is on a distinguished road
I was having the same problem with my 96. Currently having the engine rebuilt. My mechanic measured the OP gears and it was caused by the OP. My car had 190k on the engine before the rebuild. You definitely need to have the OP checked/replaced.
Jump to top BMWDAD is offline   Reply With Quote
Old Fri, Sep-23-2011, 08:51:40 PM   #36
Sirius
How many licks..
Sirius's Avatar
Well, since I reported this. The light no longer flickers. It seems to only do it during an overheat situation; which was the case of the other day as my A/C was overheating my car.
97' M3. '10 R6.
Old Sat, Sep-24-2011, 01:55:45 AM   #37
bimmaboy88
bimmaboy88's Avatar
Armenia
sirius:
i strongly suggest you check out ur cooling components. it might be just a bubble in the system or something more serious because u overheating for using ur ac is not normal.
Old Thu, Jul-26-2012, 07:29:48 PM   #38
Sirius
How many licks..
Sirius's Avatar
To come back to this. I still get the flickering light at idle after I've been driving for awhile. I have since replaced the aux fan so that correctly works, and I recently replaced the radiator and did a full flush. There is no air in the system.
The engine has around 80k on it. So, I'm still at a loss. This only happen at idle and if I press the gas pedal down just a bit the light goes away. All the lifters sound normal too and the oil level is correct.
97' M3. '10 R6.
Old Sun, Oct-28-2012, 04:42:38 PM   #39
bmwohio
MotorsportsJunkie
bmwohio's Avatar
Reputation: 0 bmwohio is on a distinguished road
any updates on this?
TCK S/A Front Coilovers TCK D/A Rear Coilovers 400/500 w/TCK Camber plates | 10mm FR Turner Spacers | Stromung | 3.38 | Sharked | 17x9 ARC-8's | MM Underpanel | 28mm Racing Dynamics Front Bar | Turner Adj. End Links | JBR LTW Flywheel | M5 clutch disc | Sachs Race Engineering PP | Bear Motorsports SSK | AKG DSSR | AKG FCABs | RTAB Limiters
Jump to top bmwohio is offline   Reply With Quote
Old Mon, Oct-12-2015, 03:23:20 AM   #40
jacobbb
Reputation: 0 jacobbb is on a distinguished road
Sorry to bump an old thread. Having this same issue. Any more info/solutions?
Jump to top jacobbb is offline   Reply With Quote
flicker, hot, light, oil
Flickering battery light, never stays on more than 2 secs, don't flicker for days ? gixxer E46 M3 (2001-2006) 40 Sat, Mar-28-2009 02:01:44 AM
help: battery flicker, now light dimmer doesn't work jacclark E46 M3 (2001-2006) 1 Wed, Jun-11-2008 08:20:33 PM
Oil Pressure Light at Hot Idle??? alpinesaloon E36 M3 (1992-1999) 4 Tue, Jun-10-2008 12:53:44 AM
parking light flicker mugenh22a4 Faults, Fixes and DIY 0 Mon, Aug-28-2006 12:14:08 AM
Oil light flicker bigneil E36 M3 (1992-1999) 5 Tue, Oct-04-2005 11:55:23 PM
Discussing Oil Light Flicker (when hot) in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
