Old Fri, Nov-20-2015, 01:51:50 PM   #131
rbrian_taylor
Reputation: 0 rbrian_taylor is on a distinguished road
Default Re: Info on steering wheel radio/telephone buttons on a ZCP car
Cc, thanks. That will help. So searching for the retrofit pdf instructions. My parts did not come with instructions. Any chance you have that and can pm?
Jump to top rbrian_taylor is offline   Reply With Quote
Old Fri, Nov-20-2015, 02:09:36 PM   #132
ccfj1
ccfj1's Avatar
Reputation: 0 ccfj1 is on a distinguished road
United Kingdom
No I dont have any install instructions, I'll most likely make it up as I go, lol.
53, M3, Silver Grey. Reto-fits: Modded Mk4 DVD, OEM Bluetooth, VR Control, Rainbow/Alpine Speakers, Alpine Amp, Alpine DSP, Kewood Sub, CCFL, Intravee II, NightMode, Audio Alerts, Rear Blind.
Jump to top ccfj1 is offline   Reply With Quote
Old Tue, Nov-24-2015, 04:59:05 PM   #133
rbrian_taylor
Here is some information if you need it.
http://forum.e46fanatics.com/showthr...7#post16819727
Old Sat, Mar-12-2016, 11:58:46 PM   #134
skillzo1
skillzo1's Avatar
Reputation: 0 skillzo1 is on a distinguished road
Cc....did you ever do this DIY yet? Id really like to do this and add the radio functions to my zcp...I already have the steering wheel radio controls and the E39 wiper stalk. But there is bits and pieces of this DIY all over the forum. Im trying to find a clean DIY with all the information in one spot.
Current 05 IB//BL 6SPD 714RWHP 590TQ
SOLD 05 AW//IR 6SPD
Skillzo's Build...http://www.m3forum.net/m3forum/showthread.php?t=487768
Jump to top skillzo1 is offline   Reply With Quote
Old Sun, Mar-13-2016, 12:15:01 AM   #135
jai5w4
jai5w4's Avatar
Reputation: 0 jai5w4 is on a distinguished road
The missing pieces probably lie in the wiring harness directions you get when you purchase the harness. It has what you need to do to connect it to the wheel and how to integrate it into the car's electronics.
2006 M3 ZCP
2017 GMC Canyon Denali
2013 X5 xDrive50i M Sport
Jump to top jai5w4 is offline   Reply With Quote
Old Sun, Mar-13-2016, 10:04:51 PM   #136
skillzo1
skillzo1's Avatar
Just to confirm...do you know if?the is the correct harness to order? https://www.ecstuning.com/Search/Sit...6012/ES161712/
SOLD 05 AW//IR 6SPD
Old Mon, Mar-14-2016, 04:33:15 AM   #137
sdaz
Reputation: 0 sdaz is on a distinguished road
Yes, that is the correct ECS part number for the wiring harness. I used that harness the other weekend to update my ZCP with radio and cruise control buttons.
BTW, I also did the E39 wiper stalk. You will want to remove the steering wheel to get to the wiper stalk. I used that opportunity to do a full cleaning and "de-fuzzing" of the alcantara steering wheel at the kitchen table.
After removing the track mode wire from the steering wheel connector (in order to place the wire from the ES161712 harness into positions 8, 9 & 10, per the instructions) I was able to remove the track mode wire further from the wiring loom and get enough wire to reach across the column to the wiper connector. You will see when comparing the two wiper stalks where the track mode wire needs to go in the wiper connector.
Good luck!
Jump to top sdaz is offline   Reply With Quote
Old Mon, Mar-14-2016, 11:31:56 AM   #138
skillzo1
skillzo1's Avatar
Good luck!
Thanks fellas.
SOLD 05 AW//IR 6SPD
Old Wed, Feb-20-2019, 09:47:43 PM   #139
DD M3
Reputation: 0 DD M3 is on a distinguished road
Hi all
I have a standard M3 with M track mode coded in. I have just bought a ZCP CSL steering wheel and I would like to use the button on the steering wheel.
How could I do this please?
Thanks
Jump to top DD M3 is offline   Reply With Quote
Old Mon, Mar-18-2019, 12:06:33 AM   #140
Cazz
High plains drifter
Cazz's Avatar
Reputation: 0 Cazz is on a distinguished road
Originally Posted by DD M3 View Post
Hi all
Thanks
Not sure if you are still looking for this, but since you already have the coding done, the easiest thing is to update the wiring so the track mode button presses the DSC button. Alternatively, you could figure out the right pin in the DME and run a wire there.
The track mode button just connects X10170 pin 8 to pin 7 (ground).
You need to disconnect the current wire going to pin 8 (MFL+/cruise control) and run a wire to tap into the DSC button wire. I'm reasonably certain the DSC button is also just a connect to ground to activate, but you will have to look up the correct wire to tap into.
Pins 9 and 10 are I-bus related on the non-ZCP and aren't used in the ZCP steering wheel. You might disconnect these and tape them off, but it probably doesn't matter.
After this mod the steering wheel button should behave like your DSC button does now.
2005 ZCP M3 + Multifunction controls
Jump to top Cazz is offline   Reply With Quote
buttons, car, info, radio or telephone, steering, wheel, zcp
Replaced ZCP steering wheel with OEM Leather Multi Function. BUTTONS NO WORK!Help? thesilverm3guy E46 M3 (2001-2006) 11 Fri, Oct-17-2008 11:51:50 AM
Changing TWO Buttons on my steering wheel. R/T and the other one. Is it possible? jamesbond E46 M3 (2001-2006) 10 Tue, Aug-22-2006 09:37:21 AM
Unused steering wheel buttons Eastwwood E46 M3 (2001-2006) 1 Thu, Feb-16-2006 06:51:38 AM
Steering wheel buttons what are these for? brownie E46 M3 (2001-2006) 4 Wed, Oct-26-2005 02:37:59 AM
Looking for a Satellite Radio receiver that I can contro using the wheel buttons lozarus Audio/In Car Entertainment (I.C.E.) 5 Wed, Jun-01-2005 01:33:39 PM
Discussing Info on steering wheel radio/telephone buttons on a ZCP car in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
