Old Thu, Nov-01-2018, 07:07:18 PM   #1
meekrob
Reputation: 0 meekrob is on a distinguished road
Exclamation 04 M3 - Front Passenger Squeak **VIDEO**
aahhhh.... :-F
Jump to top meekrob is offline   Reply With Quote
Old Fri, Nov-02-2018, 02:05:53 AM   #2
Default Re: 04 M3 - Front Passenger Squeak **VIDEO**
Is the surface of the rotor seated flat against the surface of the hub? There are 2 or 3 centering pins and 2 rotor screws.
Do you get any vibration while driving?
Have you tried washing all surfaces (pads and rotors)? Seems like some extra material getting caught around the same part of the rotor with every rotation.
Old Fri, Nov-02-2018, 03:51:55 AM   #3
Originally Posted by meekrob View Post
Yes the rotors are seated perfectly flat against the hub, no vibration.. these are brand new parts so it would be odd that something is getting stuck and it's not visible...
Noise has been happening since car was purchased a few years ago with all stock pads/rotors. The brakes have been apart a bunch of times, so if anything was out of place it would have been noticed I believe..
Brand new? Have you bedded the brakes yet?
Old Fri, Nov-02-2018, 04:51:02 AM   #4
lmtfi
lmtfi's Avatar
This.
Old Fri, Nov-02-2018, 06:37:25 AM   #5
lmtfi
lmtfi's Avatar
Not officially per say, but I have been driving around for a couple weeks already on these rotors/pads. I can try a few medium from 45-50 and some from highway speeds as well to properly break them in I guess.
Just odd that the noise is only present on one side, and it has been happening since the car was purchased...stock rotors/pads.
Here is the bedding process you want to follow. Don't do it at lower speeds and consider it done.
https://www.zeckhausen.com/catalog/i...Path=6446_6443
You might back the outside pad off the rotor a hair and then spin it to see if it is true. I know you said it was seated fully - but full seating on a very clean hub face is important. A lot of E46 M3 hub faces I see look like crap.
Also - make sure pads are seated right. The front outside pads can sometimes not have the "ears" just right.
e46, squeak, squeal, turbo, wheels
Discussing 04 M3 - Front Passenger Squeak **VIDEO** in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
