Old Fri, Jul-10-2015, 05:50:33 PM   #11
octoberz
Reputation: 0 octoberz is on a distinguished road
Default Re: Anyone have a good DIY for rear seat removal?
Originally Posted by Mash3 View Post
Is that for a convertible?
For a coupe, after you remove the bottom bench you will find, right in the middle at the back edge just under the seatbacks, a metal clamp held with a Torx bolt. Loosen this and remove the top of the clamp. You will see that the rear seatbacks are hinged here, and can be pulled up then wiggled out of the side point.
How do you remove the bottom bench?
Jump to top octoberz is offline   Reply With Quote
Old Fri, Jul-10-2015, 06:24:08 PM   #12
poms302
Reputation: 0 poms302 is on a distinguished road
Grab the passenger side corner and drivers side corner at the same time, pull up then out.
Look up fuel pump replacement on YouTube, maybe one of those will show you.
6 year thread bump lmao.
Jump to top poms302 is offline   Reply With Quote
Old Fri, Jul-10-2015, 07:06:21 PM   #13
daytonaviolet
OEM CSL Whoore
daytonaviolet's Avatar
also keep in mind that the bench has these square corner metal loops. these things can really scratch the shiet out of your rear panels if your not careful. i suggest pulling each side, one at the time. this way you can flex the bench so the corners will not hit the rear panels.
Tischer aka GetBmwParts
Jump to top daytonaviolet is offline   Reply With Quote
Old Fri, Jul-10-2015, 09:51:40 PM   #14
roarf
Jimmies: Not Rustled
roarf's Avatar
Reputation: 0 roarf is on a distinguished road
This. Removing the seat bottom isn't as easy as it sounds as I recently discovered. You have to kind of get one side out at a time and flex the whole thing as you do it to clear the side armrest. You can't "just pull it straight out" like a lot of people say, as it is blocked by the armrests and center console. Removing the seat bottom is much easier on a sedan.
'14 Evora S - Chrome Orange/Ebony
'02 M5 - Carbon Black/Silverstone
'01 M3 - Imola Red/Black (gone but not forgotten)
'08 RS4 - Imola Yellow/Black (gone but not forgotten)
Jump to top roarf is offline   Reply With Quote
Old Fri, Jul-10-2015, 10:47:46 PM   #15
cold m3
___///M3___
cold m3's Avatar
Reputation: 0 cold m3 has disabled reputation
Here you go:
http://m3support.net/thread/229/trunk-rear-seats
Photos of My ///M3
Jump to top cold m3 is offline   Reply With Quote
Old Mon, Dec-07-2015, 02:12:21 PM   #16
GhosfaceBrn
Reputation: 0 GhosfaceBrn is on a distinguished road
Poland
Originally Posted by cold m3 View Post
Can you tell me what kind of bolt is that you must use the torx 30 on this guide? I don't have it (lost it) and that scrachy noise is driving me crazy.
Jump to top GhosfaceBrn is offline   Reply With Quote
Old Mon, Dec-07-2015, 03:13:13 PM   #17
PM me a pic of where the bolt came from. I might have one since I've removed most of my interior.
Old Mon, Dec-07-2015, 03:18:30 PM   #18
Kong Sheng Han
Banned
Reputation: 0 Kong Sheng Han is on a distinguished road
North Korea
Another DIY you can check out is the Schroth Quick Fit install, but it does not show seat back removal.
Jump to top Kong Sheng Han is offline   Reply With Quote
Old Mon, Dec-07-2015, 07:09:36 PM   #19
robgill
I'd rather be at the track.
robgill's Avatar
Reputation: 0 robgill is on a distinguished road
Just did this over the weekend. The Torx 30 is for the bolt in the middle of the folding back seats that holds them in. You access it with the seats folded down.
Jump to top robgill is offline   Reply With Quote
Old Mon, Dec-07-2015, 07:28:56 PM   #20
GhosfaceBrn
Poland
I know which one. But I don't have that bolt and I need tu buy so back seats don't make sqeaky noise. And my question is what kind of bolt is it? I can't find the part number for it.
diy, good, rear, removal, seat
Discussing Anyone have a good DIY for rear seat removal? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
