Old Mon, Feb-10-2014, 12:59:09 AM   #21
Ronin M3
Northern VA M Crew
Reputation: 0 Ronin M3 is on a distinguished road
Default Re: How to reset rain sensor - help!
Originally Posted by kuksul08 View Post
Are you getting 255's still? If so, it didn't code properly. As I mentioned before it will say that it coded properly but then you cycle the key and the error code would reappear. This was via INPA though
I don't think I have anymore options.
In DIS, i'm getting the error: "optical initialization is not possible"
Jump to top Ronin M3 is offline   Reply With Quote
Old Mon, Feb-10-2014, 03:30:31 AM   #22
kuksul08
Reputation: 0 kuksul08 is on a distinguished road
Originally Posted by nis350 View Post
You are correct. I read the manual and cars that come with rain sensor do not have the manual time interval option. Therefore, can not be deactivated.
So the manual time interval function would work if it is unplugged?
I just read that somewhere. Don't think I ever tried it. Give it a whirl, it won't wreck anything.
Try a new sensor then would be my guess.
Make sure the connector and wiring is good.
~*Mods*~: High Flow Carbon Fiber Strut Pipe Trim, Custom Aero DME Shift Linkage, Forged Titanium Race-Euro-Spec Illuminated Diff Sleeves, Catless Dog CSL Retrofit, Mod Bug Delete & More
S54 Valve Adjustment DIY, Excel, Print out: http://dl.dropbox.com/u/28231781/S54...ent%20info.zip
S54 VANOS DIY video (cam bolts, oil pump disk, etc.): http://www.youtube.com/watch?v=9SkT2j3jsU0
Jump to top kuksul08 is offline   Reply With Quote
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Copyright 1999-2014 M3Forum.com
Discussing How to reset rain sensor - help! in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
