Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > M3Forum Marketplace > Parts for Sale/Wanted > E90/x - Parts for Sale/Wanted
E90/x - Parts for Sale/Wanted Use this section to post parts for sale or wanted that are related to the E90, E92 and E93 M3 only.
Old Wed, Mar-08-2017, 05:14:54 PM   #1
breadvan
Default High end USA made alignment equipment gear Intercomp - NEW
x pair Digital turn plates (p/n 102191)
0.1 Increments
2,000lb Capacity
Set of Two
Measure Wheel Angle with the Industry’s First Digital Turn Plate
Multiple Direction X & Y Movement
High-Strength Bearings
Large, Easy-to-Read Electronic Display
0.1 Graduation
Range of 30 (60 Total)
Light-Weight Aluminum Construction
Take Several Easy Measurements to be Used for Alignment. Including Caster/Camber & Ackerman
Can be Placed on Top of Scale Pads
Standard 9-Volt Battery Operation
Dimensions: 13" x 15" x 1.625" (330 x 380 x 41mm)
1 x pair turn plate rear aluminum spacers (p/n: 100339-09)
Features:
Maintain Proper Weight Distribution by Keeping the Rear Level with the Front Plates
Constructed from Light-Weight, Aerospace-Grade, Aluminum
1 x Digital camber caster gauge with magnetic adapter and carry case (p/n: 100005)
Features:
Indicates to 1/10 & has a 20 Caster/Camber Reading
Selectable 15 or 20 Caster/Camber Reading
Up To 10 Times Greater Accuracy than Traditional Bubble Gauges
Standard 9-Volt Battery Gives Up to 100 Hours of Operation
Lightweight, Aluminum Design with Auto Shut-Off & Backlight
Inclinometer Mode for Pinion & Strut Angles
Built-in Diagnostic Mode for Resetting Camber Zero
1 x RIM CLAMP - AUTO (13 to 18"/330 to 457mm) (p/n: 100007)
$2,100 USD shipped anywhere in the world. Local pickup in SF, Bay Area preferred.
Jump to top breadvan is offline
Rate Seller View Rating
Old Thu, Apr-06-2017, 04:20:26 PM   #2
breadvan
Default Re: High end USA made alignment equipment gear Intercomp - NEW
still available
Old Thu, Jun-08-2017, 03:01:25 PM   #3
breadvan
uppity up!
Old Sat, Sep-23-2017, 07:28:30 AM   #4
breadvan
track time boys!
Old Tue, Oct-24-2017, 02:19:35 PM   #5
breadvan
still available
Old Tue, Nov-28-2017, 07:13:35 PM   #6
breadvan
Black Friday BUMP
Old Wed, Dec-27-2017, 09:26:57 PM   #7
breadvan
Hello NY bump
Discussing High end USA made alignment equipment gear Intercomp - NEW in the E90/x - Parts for Sale/Wanted Forum - Use this section to post parts for sale or wanted that are related to the E90, E92 and E93 M3 only. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
