Old Tue, Feb-09-2010, 02:35:13 AM   #1
M3ANMACHINE
@natrajusa
M3ANMACHINE's Avatar
Default Pic Request OEM 18x9 Square Set-Up on E46 //M3
I'm looking for pictures of an OEM 18x9 Square Set-Up on an E46 M3.
If possible, with a 10-15mm spacer in the rear making it as flush as possible...
I can't seem to find any decent pictures of this set-up anywhere!
Thanks ahead of time!
Old Tue, Feb-09-2010, 02:48:05 AM   #2
951KiD
Enthusiast
951KiD's Avatar
Reputation: 0 951KiD is on a distinguished road
No spacers
Scorza Exhaust | ZCP/SSR/Rennen M5 | TC Kline | Ground Control | Stoptech ST40 | OEM LED | Scorza CSL Trunk & Diffuser | Ice Link | TFX Retrofit
Jump to top 951KiD is offline   Reply With Quote
Old Tue, Feb-09-2010, 03:01:28 AM   #3
M3ANMACHINE
@natrajusa
Awesome!
Thanks, 951kid.
You seem to be lowered a decent amount... Do you experience any rubbing with the fronts? Do you have to run any major neg. camber?
Thanks!
Old Tue, Feb-09-2010, 03:09:23 AM   #4
951KiD
Enthusiast
951KiD's Avatar
No rubbing actually based on post track tire inspection. you are seeing the car under compression there. The car is lowered on TCK with the 13.5 and 13.0 ride height settings recommended with the kit.
Camber on the front was about -2, rear was -1.5 or something. i'd have to find my old specs, don't remember precisely - these pics are 2 years old.
The tires were dunlop Direzza D2G which were stamped as 265 but were just as wide as the (much better) 275 toyo RA1 i replaced them with which also didn't seem to rub.
Both set ups were tested on some very tight/demanding tracks that loaded the car up side to side quite heavily.
Old Tue, Feb-09-2010, 04:08:13 AM   #5
M3ANMACHINE
@natrajusa
Cool! Thanks!
If anyone's got anymore pix, post 'em up!
Old Tue, Feb-09-2010, 07:25:39 AM   #6
Tonester
Reputation: 0 Tonester is an unknown quantity at this point
Viet Nam
OEM square with 265/35/18 all the way around, 15mm spacer in the rear.
Pic in the sig, I'll dig for more parked shots.
Jump to top Tonester is offline   Reply With Quote
Old Tue, Feb-09-2010, 07:44:53 AM   #7
M3ANMACHINE
@natrajusa
That looks awesome!
I'd love to see some parked shots from different angles!!
Thanks
Old Tue, Feb-09-2010, 07:58:38 AM   #8
beeb
Reputation: 0 beeb is on a distinguished road
Picture of non-lowered M3 with square setup?
Jump to top beeb is offline   Reply With Quote
Old Mon, Feb-15-2010, 09:39:40 AM   #9
M3ANMACHINE
@natrajusa
Bump! Interested to see some non-rolling multi-angle shots! Thanks!
2011 E90///M3 | Space Grey | Fox Red | DCT | ZCP | Slicktop
APEX | BIMMERWORLD | COBY WHEEL | CORSA | H&R | MACHT SCHNELL | PEDALHAUS
2014 F15 X5 | Space Grey | M-Sport
Old Mon, Feb-15-2010, 01:48:56 PM   #10
BlazenXLT
We've had one yes, what about second breakfast?
BlazenXLT's Avatar
Reputation: 0 BlazenXLT is on a distinguished road
Stock suspension, 12.5mm spacer in the rear, no rubbing, 265 Dunlop star specs.
Jump to top BlazenXLT is offline   Reply With Quote
18x9, e46, oem, or or m3, pic, request, setup, square
Discussing Pic Request OEM 18x9 Square Set-Up on E46 //M3 in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
