Old Sat, Jun-25-2011, 02:21:06 PM   #51
Default Re: DIY: How to Swap Euro Mirror (glass part only)
Originally Posted by mpower22 View Post
The E46 isn't set up to accept auto-dimming exterior mirrors (at least the US spec isn't). Not sure about the euro version, but the US version isn't even wired for it..
I don't think any E46 came with the auto-dimming outside mirrors from the factory, but it probably wouldn't be very difficult to retrofit. The BMWs that do have autodimming outside mirrors just use the rear-view mirror to control the dimming; there aren't any extra sensors. The auto-dimming rearview mirrors have a set of pins that are meant to trigger the dimming function on the outside mirrors (pins 4&5 and 6&7 for left & right respectively IIRC). I think you could use the + pins to trigger a relay and wire the relay output to the dimming pins on the mirror. Since the E90s have the exact same shape mirror as the E46, you could grab the dimming mirrors from them. If you don't want to use relays, you could probably grab mirror modules from an E83 (X3) or E85 (Z4) since they're very similar to the E46 electrically.
With all that said, it's not worth retrofitting them IMO. I did a lot of research into this and was very tempted to do the retrofit until I actually drove a car with the dimming mirrors. They just get too damn dim, I nearly hit a couple cars because I couldn't see a damn thing. It's especially bad if you have tints.
Old Thu, Aug-11-2011, 04:11:05 PM   #52
WCM3
canŧ főcus mŷ attėntĭon
WCM3's Avatar
Reputation: 0 WCM3 is on a distinguished road
Guys, where can you buy these anymore? Just ECS?
Talked to my dealer and he can't get them..
Precision|Boostlogic|TiAL|AEM|MaxPSI|IveyTune
HKS|Blitz|VPFab|UUC|Cometic|ARP|SPA|Defi|PLX
Jump to top WCM3 is offline   Reply With Quote
Old Thu, Aug-11-2011, 11:23:53 PM   #53
gleech
gleech's Avatar
Reputation: 0 gleech is on a distinguished road
if you have no problem with a used one, try ebay uk....
SuperSprint V2 headers, CP cats rasp killer, Scorza muffler, Frank Smith custom Alpha-N tune, Repoman CSL airbox
TMS subframe reinforcement kit
GC trackschool kit - 525/545 lb springs, GC FCABs/Powerflex RTABs
OEM Nav, Bluetooth, Sirius, Intravee and Euro Mirror
CSL AIRBOX GROUP BUY: http://www.m3forum.net/m3forum/showthread.php?t=444943
Jump to top gleech is offline   Reply With Quote
Old Fri, Aug-12-2011, 01:03:28 PM   #54
WCM3
WCM3's Avatar
I was actually thinking of that. I probably wouldn't mind. All the euro ones should be the same, right?
Old Fri, Aug-12-2011, 10:54:12 PM   #55
gleech
gleech's Avatar
should be, as long as it is for E46 M3, and I'll quote terraphantm post about using other euro mirror....
Pre-facelift E90. Same part number as the M3 mirrors actually. Just easier to find the E90 listings on eBay since there are a lot more of them. E82, E87, and E92 also use the same mirrors IIRC. Z4 might too, but I'm not 100% sure about that.
Old Fri, Mar-23-2012, 05:58:49 PM   #56
Moop
⊕ m
Moop's Avatar
Reputation: 0 Moop can only hope to improve
Location: El Pueblo Nuestra Senora la Reina de los Angeles de Porciuncula
Which wires go where on the mirror? The black and brown ones.
I just switched out to power fold mirrors with euro glass. I want to put the mirror glass on as the last step and there's no indicators on the posts. Does it matter?
Thanks.
Jump to top Moop is offline   Reply With Quote
Old Sat, Mar-24-2012, 12:22:54 AM   #57
gleech
gleech's Avatar
I guess it really doesn't matter....when I swapped mine, I didn't take note of which wires goes where....I just plug them in, and so far, both are working without any problem....
but I might be wrong, hopefully somebody could chime in....
Old Sat, Mar-24-2012, 01:08:07 AM   #58
Thanks.
Polarity doesn't matter for these.
Old Sat, Mar-24-2012, 01:33:57 AM   #59
abakos
abakos's Avatar
Reputation: 0 abakos is on a distinguished road
Nice thread revival...
I had found a DIY about using something to spin the two tabs under the mirror to one side, which spins a locking collar and releases it. That leaves the tape holding the mirror in place, which peels off without much trouble. Just peel slow and take your time...
I put mine on a couple months ago, and I love them! I had the euro mirrors on my old Jetta and seriously missed them on the M.
-Aaron
2004 M3 - Coupe, 6spd, Silver Grey on Black
RAC RG63, PSS, ZCP Brakes, aFe, SS (V1, Res. X-pipe, Street Muffler), Epic Alpha-N, 319whp
2006 Jetta TDI/DSG, Pkg 2, Silver on Black - Sold
2004 M3 SMG - Silver Grey on Black, Convertible - RIP
1995 525I 5spd - Black on Black -Sold
2004 X3 3.0i AT- Blue on Tan - For the wife....
Jump to top abakos is offline   Reply With Quote
diy, euro, glass, mirror, part, swap
Discussing DIY: How to Swap Euro Mirror (glass part only) in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
