View Poll Results: You can only fit into one of the 4 categories. Choose the one that includes you.
Broken in per bmw, doesn't burn oil OR not broken in per bmw and does burn oil 49 80.33%
broken in per bmw, does burn oil OR not broken in per bmw and doesn't burn oil 12 19.67%
Voters: 61. You may not vote on this poll
Closed Thread
Old Fri, Feb-03-2006, 11:39:22 PM   #41
If I had more options it would be useless because the conclusion would be unclear based on needing to combine results. I've broken it down into "breakin affects oil consumption" and "breaking doesn't affect oil consumption.
How do you know there is no correlation? So far the results suggest there it...
Jump to top Obioban is offline
Old Fri, Feb-03-2006, 11:55:07 PM   #42
Beowoulf
Grumpy
Beowoulf's Avatar
Reputation: 0 Beowoulf has disabled reputation
United Nations
You have more than 2 options for polls, just look for the button when you post the poll..
Alex
Jump to top Beowoulf is offline
Old Sat, Feb-04-2006, 01:11:36 AM   #43
I didn't want more than two option, it woudl just add confusion. As it stands:
Option 1) breakin has a relation to oil consumption
option 2) it doesn't have a relationship to consumption
Old Fri, May-02-2008, 03:07:31 PM   #44
bump for more results, before everyone who owns the car bought it used
Old Fri, May-02-2008, 04:10:25 PM   #45
pnovacon
pnovacon's Avatar
Reputation: 0 pnovacon is on a distinguished road
04 w/ 42K and not a drop of oil burned. Followed the breakin to the letter.
Jump to top pnovacon is offline
Old Fri, May-02-2008, 04:16:56 PM   #46
RBC44
Reputation: 0 RBC44 is on a distinguished road
I broke my 2006 M3 in strictly by BMW recommendations and have never burned any oil. Same was true of my 2001 M3.
[SIG PIC]
"Equal Justice Under Law"
Mods: BMW Motorsport 4.10 Diff (REM Polished); Euro Headers/Cats; Evolve-R Tune; VibraTechnics Engine Mounts and Transmission Mount; Stainless Steel Brake Lines; Mason Engineering GSP Clutch Pedal; Dinan Muffler; RAC 63 18" Wheels (silver) w/ Michelin Pilot Super Sport Tires; 17" Winter Wheels w/Michelin Pilot Alpin 3 Tires; AutoSolutions SSK (30% throw); CPI Rasp Terminator; Koni Yellow Shocks; Hotchkis Sway Bars; CDV Delete; Streamline Panel Filter; Stainless Steel Shift Knob and Ebrake Handle; Stainless Steel Pedal Set; Leather Z IR Shift Boot; Tekarbon 1/2CF CSL Style Diffuser; Dice Silverline Ipod Integration Kit; BeemerEvolution IR Dash Gauge Rings; Micro Antenna; M3 Trunk Mat; Stealth Bulbs; Eurotray; Eurowise Billet S54 Dipstick; SGM Hardtop; Vert. Windblocker; LeatherZ Spare Tire Kit; LeatherZ IR Shift Boot; IR Arm Rest; BMW Advanced Charging System; Body Colored Reflectors; Venture Shield Clear Bra; Keyhole Delete; BMW Car Cover.
Jump to top RBC44 is offline
Old Fri, May-02-2008, 04:31:37 PM   #47
grmnrkt
To start press any key. Where's the "any" key?
grmnrkt's Avatar
Reputation: 0 grmnrkt is on a distinguished road
This poll is not well constructed for extrapolating any type of information or corrolary cause/effects. You would really want to break this down more like jerryg said and give four distinct choices that would allow you to reach a relationship between break in style and oil consumption.
However I don't believe you would find any information that is truly useful from this poll. How you drive the car at warm up and oil change frequency are factors that will have a much larger effect on you oil consumption. Do you drive up a big hill when you leave the house every morning, do you run the piss out of it as soon as you turn the key on a cold motor, do you go the 15k BMW recommends between oil changes? These factors will have a much larger effect on your motor than your break in period.
All one needs to worry about breaking in a new engine is how soon you get the original oil out of the sump. 500miles is plenty to break off any burrs left from machining. Even inside 500 miles as long as the engine oil is up to temp you can drive it like you stole it. It helps seat the piston rings properly and will increase the life of the rings and the bores. There are different schools of thought on engine break ins, but there is no definative answer as to which if either is the better way.
I prefer to change my oil regularly (3k, I think last year I went 1200 track miles) and run the hell out of it. I don't notice any oil burning inside 3k. But I don't know how the car was broken in, I do know it had 5 oil changes by the time I bought it at 5500 miles.
You don't see a break in period on an Indycar, F1 motor, or NHRA, they just pre-heat the oil and coolant, pump it in, crank the motor and instant 10k burnout leaving the pits for miles of testing/qualifying/racing. And they have to last several races to boot. (not including NHRA in the last statement)
2003 ///M3 IR on Red Roll Cage
Sunroof Delete, SMG, #016 BMWCCA Race Car
Jump to top grmnrkt is offline
Old Fri, May-02-2008, 04:39:25 PM   #48
statepkt
statepkt's Avatar
Reputation: 0 statepkt is on a distinguished road
Bought the car at 30k, so no clue on break in.
Car had some oil leak issues, but was fixed under warranty.
Absolutely no oil loss since my first oil change.
I did not vote as I did not have the car during the break in period, but am curious as to other M's burning oil
03 Imola Red Coupe
Jump to top statepkt is offline
Old Fri, May-02-2008, 04:49:26 PM   #49
lmtfi
lmtfi's Avatar
Broken in like absolute religion. Does NOT burn oil.
Jump to top lmtfi is offline
Old Fri, May-02-2008, 06:03:42 PM   #50
ThatOneGuy
In the left lane, flashing to pass.
ThatOneGuy's Avatar
Reputation: 0 ThatOneGuy is on a distinguished road
Germany
Originally Posted by KILO15 View Post
I drive her real real, real hard. I broke her in using Performence center guidelines. 4000rpm max for the first 600miles then nothing over 5500rpm for the rest of the break in.I did however use sport mode but did not go over 80 % throttle even with sport on. I also baby her when she is cold. 3k rpm till the tach lights turn off then under 4500rom till she is all warmed up. I havent burned a quart.
Same here, but haven't used a drop.
The Blog
Jump to top ThatOneGuy is offline
Closed Thread
breakin, consumption, oil, period, poll
Oil Consumption Poll - Related to Break In Poll slickrick E46 M3 (2001-2006) 19 Sat, May-07-2005 05:06:30 AM
question about breakin period after done the bearing recall stlgrym3333hp E46 M3 (2001-2006) 10 Fri, Oct-08-2004 01:00:37 AM
is there a breakin period for eismann sect 1&2 ? yellowfever E46 M3 (2001-2006) 5 Sat, May-15-2004 11:56:05 PM
Oil Consumption jimmypM3 E46 M3 (2001-2006) 1 Thu, Feb-20-2003 03:25:14 AM
Breakin Oil wish5670 E46 M3 (2001-2006) 1 Wed, Dec-18-2002 12:23:25 AM
Discussing breakin period vs oil consumption poll in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
