Old Fri, Oct-15-2010, 07:58:14 PM   #1
xekrete36
xekrete36's Avatar
Reputation: 0 xekrete36 is on a distinguished road
Mexico
Default Fuel consumption
For the past couple of days I noticed that my E36 M3 gas consumption is off the roof. It is using more gas than my E46 M3 on a commute with the occasional stomp on the pedal. It threw a couple of codes the other day that it had previously, the P0455 and the P1250. I searched and found that the 0455 is the code for a big vacuum leak, first thing was the gas cap but it is still in good condition so I decided to check the little tank behind the rear passenger wheel well. I take it out and one of the connections on top was broken. I could smell some gas fumes yesterday when I was putting the license plate on it. Could this be why it is using so much fuel? I replaced the plugs a couple of weeks ago also.
E46 M3- KW V2's, CF Grills and gills, Depo smoked corners and sidemarkers, ZHP shift knob, 12mm RE spacers front, Focal Polyglass speakers, Kicker Comp VR... Sold!
Jump to top xekrete36 is offline   Reply With Quote
Old Fri, Oct-15-2010, 09:34:23 PM   #2
SIDEWAYS
is the way to carve canyons...
SIDEWAYS's Avatar
Reputation: 0 SIDEWAYS is on a distinguished road
Have you been checking your engine temperature gauge? Is the engine staying abnormally low and not reaching proper operating temp? If so, it's likely a bad/stuck t-stat, causing the excessive fuel consumption.
One of the last remaining members of the E36 M3 original owners club...a dying breed indeed.
What's worse is that the E36 M3 has sadly become the new Honda Civic of tuning...
Jump to top SIDEWAYS is offline   Reply With Quote
Old Fri, Oct-15-2010, 09:49:28 PM   #3
Synenergy52
Reputation: 0 Synenergy52 is on a distinguished road
Even when I bought my 98 M3 with a broken (literally broken in half) thermostat, the car got a consistent 23mpg (OBC) and drove it like that for a month before I did the cooling system. I know it wasn't the best but it was my only car
Jump to top Synenergy52 is offline   Reply With Quote
Old Fri, Oct-15-2010, 10:26:16 PM   #4
xekrete36
xekrete36's Avatar
Mexico
I watch my temp gauge like a hawk since I recently bought the car and not know what to expect yet, but so far the temp has been where it normally should be. I know I am not getting 23mpg. I replaced the plugs with the old one's today and it seems the same.
Old Fri, Oct-15-2010, 11:08:37 PM   #5
das borgen
Off-Topic King
das borgen's Avatar
Reputation: 0 das borgen is on a distinguished road
the temp gauge cannot be counted on since it's not linear...... I believe the lower bound for 12oclock is 130F and I dunno the upperbound to make it go opast 12oclock
guys with actual temp gauges, can you chime in here?
Jump to top das borgen is offline   Reply With Quote
Old Sat, Oct-16-2010, 03:39:45 AM   #6
CMG
Reputation: 0 CMG is on a distinguished road
So has the consumption changed since you bought it? Have you actually calculated it yet?
Jump to top CMG is offline   Reply With Quote
Old Sat, Oct-16-2010, 05:47:38 AM   #7
epj3
Reputation: 0 epj3 is on a distinguished road
Sorry, no way (unless your commute was all highway) you got 23mpg with a bad tstat.
Jump to top epj3 is offline   Reply With Quote
Old Sat, Oct-16-2010, 06:04:06 AM   #8
xekrete36
xekrete36's Avatar
Mexico
So a little while ago I got on my car and started it up to go somewhere and noticed that the fuel needle was higher than what it was last time I used the car. I'm thinking I have a bad fuel level sensor. The car did throw a CEL code of p1250 which is fuel level too low. It's just playing games with me then.
Old Sat, Oct-16-2010, 03:05:32 PM   #9
epj3
Were you parked on a hill when you turned the car on?
Old Sat, Oct-16-2010, 04:03:32 PM   #10
WRXEATR
The Frugal and Outspoken One
Reputation: 0 WRXEATR is on a distinguished road
And no, he is not joking by asking this.
Jump to top WRXEATR is offline   Reply With Quote
consumption, fuel
Discussing Fuel consumption in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
