Old Fri, Apr-09-2010, 02:09:00 PM   #1
Double_J
Reputation: 0 Double_J is on a distinguished road
Default Oil Consumption related to warm up?
Just had a thought.
My 08 e90 has always been good with oil consumption. I would rarely (if ever) have to top it off between services.
That said, I recently changed the way I drive when the car is warming up. I used to use 4,000 RPM as my limit until the car hit temperature but switched to 3,000 based on what I've read on this and 'the other' M3 board.
After the change, I've noticed that I'm losing a bit of oil. Not enough to be considered a problem by any means but definitely more than I did before.
I'm going to top off the oil and go back to the 4,000 warm up practice just to see if the oil loss stops. In the meantime, are there any technical merits to this? Is there any reason that warming up at a lower RPM threshhold would allow a bit more oil loss than a higher one?
I've read about driving style, break-in, etc. all affecting oil consumption but I don't think I've really heard this one mentioned yet.
Jump to top Double_J is offline   Reply With Quote
Old Fri, Apr-09-2010, 05:48:21 PM   #2
Da Jemster
Institutionalized User
Da Jemster's Avatar
Reputation: 0 Da Jemster is a jewel in the rough
How are you topping it off with no dipstick?
2017 i3 - Capparis White w/BMW i Frozen Blue Accent
2016 M235i - Black on Black
2008 E93 - AW - DCT - Stock...for now
2004 E46///CB-BLK///SMG II///D/A tuned///AFE Stg 2///SS Stepped///SS Metallic Cats///Eisenmann SS X-pipe///SS Race///4.10 diff///ACS CF Front Lip///6000K Xenons & Fogs///CF Grills & Gills///Angel Eyes///Clear Corners w/Solaris///Painted Reflectors///Black'd Sides & Tails///TEIN S
Jump to top Da Jemster is offline   Reply With Quote
Old Fri, Apr-09-2010, 09:09:37 PM   #3
Double_J
Figured I'd wait until the meter showed minimum and then add a quarter of a bottle at a time until it shows max (like others have done on this board).
Old Sat, Apr-10-2010, 02:02:41 AM   #4
AMPowerJ
One mod leads to another ...
AMPowerJ's Avatar
Reputation: 0 AMPowerJ is on a distinguished road
I would have thought you would have more consumption with higher revs. I don't know if it really has anything to do with it either way. I burn about .5L every 7500 miles. I broke my car in pretty hard while mostly observing the rules before 1200 miles. I made sure I put a lot of compression on the motor and I think it worked.
2009 E90 M3 - LeMans Blue - Speed Cloth - 6 speed
ESS Tune - BMW Performance Exhaust - StopTech Trophy BBK - KW Clubsport Suspension - TE37SL Wheels
Jump to top AMPowerJ is offline   Reply With Quote
Old Sat, Apr-10-2010, 02:22:51 AM   #5
///M.EngT
Reputation: 0 ///M.EngT is on a distinguished road
if your burning... your over filling simple as that.
Jump to top ///M.EngT is offline   Reply With Quote
Old Sat, Apr-10-2010, 03:25:30 AM   #6
Studntloan
Reputation: 0 Studntloan is on a distinguished road
i burn alot, usually atleast 1 qt before every 7500 miles i thought that was normal tho, how much is everyone else doing
11 e90 zcp mr m3 (current)
08 E92 space gray m3 (sold)
04 r32t (in the works)
05 e46 ir/ir m3 (sold)
01 e46 py m3 (sold)
96 e36 silver m3 (sold)
Jump to top Studntloan is offline   Reply With Quote
consumption, oil, related, warm
Discussing Oil Consumption related to warm up? in the E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convertible) (2008-2013) Forum - {Engine: S65 - Max Hp: 414 hp (420 hp Euro) at 8,300 rpm / 295 lb/ft at 3,900 rpm} at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
