Old Wed, Oct-21-2009, 07:51:09 PM   #1
BlueAngel M3
BlueAngel M3's Avatar
Reputation: 0 BlueAngel M3 is on a distinguished road
Default How do u use the fuel consumption on the OBC
I'm trying to figure it out but had little trouble. Someone please tell me how u set the fuel consumption on the OBC? Thank you.
Jump to top BlueAngel M3 is offline   Reply With Quote
Old Wed, Oct-21-2009, 07:53:05 PM   #2
Blanchimont
License Revoked
Blanchimont's Avatar
Reputation: 0 Blanchimont is on a distinguished road
Assuming you filled your tank up
1. you just select Consump 1 or 2 and press the set/rest hold it and it will turn zero.
2. then on the odo you set the trip to zero and that is about it
i guess that answers your question
Jump to top Blanchimont is offline   Reply With Quote
Old Wed, Oct-21-2009, 08:03:32 PM   #3
M3n00b
M3n00b's Avatar
North Korea
Are you trying to compensate for when it's inaccurate? You have to unlock the OBC.
http://www.bimmerinfo.com/E36_OBC_tricks.htm
Old Wed, Oct-21-2009, 08:11:01 PM   #4
BlueAngel M3
Thank you!
No, I wanted to see what I average a day, but thank you.
Old Wed, Oct-21-2009, 11:26:25 PM   #5
Blanchimont
License Revoked
Talking
if you want to find out what you average a day:
-Reset Consump 1 or 2 everyday the first time you drive your car.
-Better reset consump 1 for everyday and reset consump 2 only on full tank.
Shhh! dont tell'em i told you....its a secret.
Old Thu, Oct-22-2009, 12:40:18 AM   #6
BlueAngel M3
Will do! Thats much for your kind help.
Old Thu, Oct-22-2009, 12:50:19 AM   #7
Samon8ive
Check the Rhyme
Samon8ive's Avatar
Reputation: 0 Samon8ive is on a distinguished road
My ODC average is always about 2 MPG higher than actual (23 vs 21 actual), so don't put a lot of faith in the reading until you've recalibrated the ODC.
SAnta MOnica, ca N8IVE.
1999 M3 Cosmos 5 spd
koni's and RSM's....the rest is stock
Jump to top Samon8ive is offline   Reply With Quote
Old Thu, Oct-22-2009, 01:13:17 AM   #8
BlueAngel M3
I don't know if its accurate. How do u calibrate it?
Old Thu, Oct-22-2009, 01:13:03 PM   #9
Richardsperry
95 SC M3
Richardsperry's Avatar
Count miles and divide by gallons. That is what you are getting. Compare that # to what the OBC is telling you. Find the % difference +-.
Unlock the OBC functions, and adjust the correction factor by the % you calculated.
Example, If the OBC is off by +2%, and calibration # is 1100, subtract 2% of 1100 (22) and enter the new factor 1078
At least I think I remember that correctly.
I think Ron Styger's site www.unofficialbmw.com/e36.html has the procedure, but that is the jest.
Jump to top Richardsperry is online now   Reply With Quote
Old Fri, Oct-23-2009, 01:53:17 AM   #10
BlueAngel M3
Thank you for the helpful information!
consumption, fuel, obc
Discussing How do u use the fuel consumption on the OBC in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
