Old Wed, Aug-05-2009, 07:35:51 PM   #1
sunnybono
Reputation: 0 sunnybono is on a distinguished road
Default Adjust fuel consumption accuracy?
Is this possible? Assuming you know your average mpg figure under reads by 10% can you adjust this out in the computer?
Jump to top sunnybono is offline   Reply With Quote
Old Wed, Aug-05-2009, 11:37:23 PM   #2
RedM3/4
Default good question
I believe this is possible in the E36 - to a point. Example, if you put in cams and 24lb injectors in an E36M3, there isn't enough adjustment to get this far.
I've never seen it discussed or heard of it done on an E46.
ADS
06 SMG/ZCP - April 09, MCS 2WR (replaced Dinan over Konis/replaced OE), Supersrpint street section3, RAC RG63, homelink with off-delay, multifunction steering wheel buttons, RacingBrake Front kit.
Old Wed, Dec-19-2012, 06:39:09 PM   #3
pleiku69
Reputation: 0 pleiku69 is on a distinguished road
Default Re: Adjust fuel consumption accuracy?
my actual mpg is about 1.7 mpg lower than indicated on info center. Can this be adjusted?
Jump to top pleiku69 is offline   Reply With Quote
Old Wed, Dec-19-2012, 06:45:14 PM   #4
m3 hal
I would ask the guys who are working on the ecu hacks. I bet the answer is yes.
Old Wed, Dec-19-2012, 07:23:51 PM   #5
808elise
808elise's Avatar
Reputation: 0 808elise is on a distinguished road
Since I installed my supercharger it reads 28. Not sure why it is doing that.
-Josh
Jump to top 808elise is offline   Reply With Quote
accuracy, adjust, consumption, fuel
Discussing Adjust fuel consumption accuracy? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
