Old Thu, Oct-25-2007, 02:16:00 PM   #41
jkalex05
Reputation: 0 jkalex05 is on a distinguished road
I just purchased my M3. However I burned about a half a quart to a quart inbetween 2000 miles. However whats weird is that it happened in a week. Because I had checked the oil level and it was fine and one day I turn on car and it takes a while to crank and when it finally does low oil light is on.
Check dipstick isn't even reading oil. After a couple of seconds it finally reads oil. Added a quart and its back at Max line, a tiny bit over.
2002 BMW M3 Coupe 6MT / Steel Grey on Grey Leather Premium Package / H&K / 19in OEMs / Xenons | MODS: Streamline Panel Filter, 20% Tint / Coming Soon: Dixis Titanium Exhaust, AP Headers, DA Race Software, SS Straight Pipe Sec 1/2 w/o Res, and eventually a new 4.10 differential!
Jump to top jkalex05 is offline   Reply With Quote
Old Sat, Dec-08-2007, 04:58:20 AM   #42
Scooter426
roadracer
Scooter426's Avatar
Reputation: 0 Scooter426 will become famous soon enough
remember that this engine has a sump system for the oil. 2 places where oil is stored. That means that you have to follow the procedure in the manual for checking the oil level or your readings could be way off. Make sure you run the engine for the specified time and shut it down and wait the specified time for the oil to settle a bit. Then measure oil level. Read your manual, it has very specific instructions for measuring the oil level.
Scooter
Seattle (Issaquah), WA USA
2001 M3 Vert
Alpine White
Black Leather
K&N air filter!
Jump to top Scooter426 is offline   Reply With Quote
Old Sat, Dec-08-2007, 08:07:38 AM   #43
HiRide
Driver
HiRide's Avatar
Reputation: 0 HiRide is just really nice
Thats funny, my oil light has been coming on recently as well. As the cold weather hit, i noticed this. I have never had this problem before, and I put in a 1/2 litre and was back at max.
Now another month later and the light is back on. But here is the thing.
It doesnt always come on. like on the way to work, no light. On the way home at 9:00 pm the light comes on. now on the way to work I am moving pretty quickly and changing throttle, on the way home i use cruise control and then the light just pops on.
And sometimes it comes on about 10 minutes after starting the car, sometimes I am almost pulling into my apt 20 minutes later. I had also replaced my oil level sensor as i thought it was dead a while ago. turns out the OBDII fuse blew which makes an oil light and the oil temp sensor go dead. So on a side note, if your oil temp gauge goes out and you have an oil light, check the OBDII fuses first.
But I am going to check that oil separator, thanks for the tip.
although, this kind of consumption could be normal the way I drive though. Now that I am putting down 321RWHP, I cant keep my foot off of the gas. Sad part is that we pulled fuel in the tune for my daily driving conditions to give me better fuel economy which, if i use cruise control and dont speed, works great and yet i wouldnt know because i am flying all over the place. The car even has a different sound now, it has a howling sound to it like a 350Z on steroids, but it will always have a hint of rasp...
maybe i should take it easy and see if that helps, could just be serious blowby from driving so hard.
"If everything seems in control, you're not going fast enough."
-Mario Andretti
“When I raced a car last it was at a time when sex was safe and racing was dangerous. Now, it’s the other way round.”
- Hans Stuck
"Aerodynamics is for those who cannot manufacture good engines"
- Enzo Ferrari
Jump to top HiRide is offline   Reply With Quote
Old Sat, Dec-08-2007, 11:16:21 AM   #44
Serious
Serious's Avatar
Reputation: 0 Serious has a spectacular aura about
replacing the oil seperator seems to have solved my oil consumption issues.
Jump to top Serious is offline   Reply With Quote
Old Sat, Dec-08-2007, 11:32:35 AM   #45
hogger453
hogger453's Avatar
Reputation: 0 hogger453 is on a distinguished road
Bulgaria
If you are burning or leaking that much it's not normal.
If it was my car and no external leaks, I would look at changing the valve seals. It's the first thing that goes on abused or high milage vehicles. On the sevarity you would or would not see smoke from the tail pipe or oil on the spark plugs. GL.
Also, all great engines should burn a little oil.
Two possibilities exist:
Either we are alone in the universe or we are not.
Both are equally terrifying.
Arthur C. Clarke
Jump to top hogger453 is offline   Reply With Quote
Old Tue, Jan-08-2008, 07:08:29 AM   #46
vespam5
vespam5's Avatar
Reputation: 0 vespam5 is on a distinguished road
Not that I can confirm this is a fix for all, but the oil separator seemed to be a bit gummed up in my 55K car so I replaced it with a lower mileage one from a wrecked car I had access to. I no longer had noticable consumption.
Another definite factor (at least with my car) was cold weather. In the cold months (yes even in SoCal), the car seemed to consume more oil.
And as someone else stated, check the oil about one minute after having run your engine.
Jump to top vespam5 is offline   Reply With Quote
Old Tue, Jan-08-2008, 10:59:40 PM   #47
Need4Spd
Need4Spd's Avatar
Reputation: 0 Need4Spd has a reputation beyond reputeNeed4Spd has a reputation beyond reputeNeed4Spd has a reputation beyond reputeNeed4Spd has a reputation beyond reputeNeed4Spd has a reputation beyond reputeNeed4Spd has a reputation beyond repute
It's not normal for M3s to burn oil. You should have the car checked.
Past car: '05 M3 'vert, 6MT, custom 18" RAC RG63 Hyperblack monolites, Continental Extreme DW 245/40 and 275/35, Nav, HK, BT, Euro rotors, Custom Performance Rasp Terminator (2nd Gen.), Silverline DICE iPod adapter, EAS Aurora 60 LED Angel Eyes, "-CDV," "free & easy" camber mod (-1.7 degrees), Koni S/A shocks, Rogue Engineering RSMs and transmission mounts, Bimmerworld silicone intake boot, spacesaver spare from LeatherZ, updated OEM RTABS
'11 Jaguar XFR
Jump to top Need4Spd is offline   Reply With Quote
Old Wed, Jan-09-2008, 02:07:07 AM   #48
hsantos
hsantos's Avatar
Reputation: 0 hsantos is on a distinguished road
Does not burn oil with 72996-very hard miles......
'02 M3 6-SPD Jet Black
Jump to top hsantos is offline   Reply With Quote
Old Sat, Oct-31-2009, 07:56:35 PM   #49
xM P0W3Rx
Dan the VANOS man
xM P0W3Rx's Avatar
Reputation: 0 xM P0W3Rx is on a distinguished road
Hate to dig this up but any more info on the oil separator? I burn a fair amount of oil if car hangs in higher revs(driving event).
My Reviews
Jump to top xM P0W3Rx is offline   Reply With Quote
Old Sat, Nov-07-2009, 12:02:32 AM   #50
jrf313
Reputation: 0 jrf313 is on a distinguished road
'06 M3 Coupe 38,000 miles. Uses no oil between changes.
Jump to top jrf313 is offline   Reply With Quote
consumption, oil, s54
Oil Consumption zoso E36 M3 (1992-1999) 39 Thu, Dec-08-2005 05:24:57 AM
Oil consumption... ArtM3 E46 M3 (2001-2006) 11 Fri, Oct-07-2005 09:32:48 PM
oil consumption?? g35coupe E46 M3 (2001-2006) 8 Tue, May-03-2005 11:51:50 PM
Oil consumption???? rossdogarr E46 M3 (2001-2006) 2 Fri, Jul-30-2004 04:31:05 PM
Oil Consumption jimmypM3 E46 M3 (2001-2006) 1 Thu, Feb-20-2003 03:25:14 AM
Discussing s54 oil consumption in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
