Old Tue, Oct-16-2007, 02:19:10 AM   #31
Serious
Serious's Avatar
Reputation: 0 Serious has a spectacular aura about
http://www.realoem.com/bmw/showparts...6&hg=11&fg=15]
#1
replace/clean #2 as well for good measure.
Jump to top Serious is offline   Reply With Quote
Old Tue, Oct-16-2007, 02:40:18 AM   #32
M3 S3-R
M3 S3-R's Avatar
Reputation: 0 M3 S3-R is on a distinguished road
Originally Posted by Viper966 View Post
so, my oil light has been coming on lately.... its been eating about 1/2 qt of oil every 3k miles approx... any ideas? should i be concerned? it doesnt smoke, and i dont see any drippings in the driveway....
Something is not write. Mine burns no oil at 3k and the car is S/C ed. Was the car broken in correctly?
2003 Steel Gray E46 M3
S3-R Dinan Supercharger 5.5 lbs ~ Throttle Bodies ~ SMG Software ~ Eisensmann Miescherschaft Titanium exhaust ~ Eisensmann Titanium Section I/II Dinan Stage II Suspension/TCK Monoball bushings/Rear subframe re-enforcement kit ~ Champion RG41's ~ Brembo 6 piston front/4 piston rear ~ 275/30 front/285/30 rear ~ Aluminum pedals.
Jump to top M3 S3-R is offline   Reply With Quote
Old Tue, Oct-16-2007, 04:17:25 AM   #33
bmwJohhnyD
user formerly known as bmwbob
bmwJohhnyD's Avatar
United Nations
Originally Posted by bagzman View Post
yep, i too get the orange oil light sometimes. Somtimes when I drive, sometimes when I turn off the car. I burn about 1/2 a qt every 5000 miles.
I hope it stays that way and doesn't get worse. I dont even beat on the car..too much
i have 43k on the motor. pulls as hard as ever.
that is exactly often mine comes on...
02 52k miles, bearing recall performed, had the oil leak after the recall but since it was fixed can not find any evidence of leaking oil...(took off panels and put it on a lift)
i think i burn about a quart every 5k miles or so.. i also believe that the engines with the rod bearing recall where "programmed" to where the oil light comes on faster than the non bearing recall engines.. sometimes i get oil light and it will be just slightly below the full mark..
i normally fill it the first time i see it.. but this time i let it go.. (even though i checked it all the time) to see how much more constant the light became with the oil getting lower..
now the light comes on just about all the time and it is exactly on the lower line indicating it is a full quart low...
i was just discussing this with mvez the other day..
he has a newer one with about 16k on the clock and he does not add oil between oil changes... my cpo is up in december and i may mention it to them before then... but i know what they are going to say...
Old Tue, Oct-16-2007, 04:21:27 AM   #34
Serious
Serious's Avatar
there is a service bulletin out about the oil level sensor as well IIRC.
common for these to fail and the yellow light to come on all the time.
Old Tue, Oct-16-2007, 04:23:55 AM   #35
bmwJohhnyD
bmwJohhnyD's Avatar
United Nations
had that replaced as well...
and at one time i thought the problem was that sensor.. i had it replaced and it still comes on before it is a quart low.. and the oil level light does come on with greater frequency the lower it gets...
Old Tue, Oct-16-2007, 08:10:16 PM   #36
HareRee
HareRee's Avatar
Reputation: 0 HareRee is on a distinguished road
How do I tell if oil separator is the problem? Do you have a write of on how to inspect it and clean it? Thanx.
Jump to top HareRee is offline   Reply With Quote
Old Tue, Oct-16-2007, 08:34:36 PM   #37
doublearon20
Certified User
doublearon20's Avatar
Reputation: 0 doublearon20 is on a distinguished road
Yeah the light shouldn't be coming on when you lose a half quart, especially considering they take (someone correct me if I'm wrong) like 6 quarts, BMW I would imagine would factor in a certain amount of acceptable consumption. I wouldn't be too concerned, maybe physically check the level every now and then to ease you mind.
The land of the free, because of the brave.
Jump to top doublearon20 is offline   Reply With Quote
Old Tue, Oct-16-2007, 09:00:06 PM   #38
Serious
Serious's Avatar
pull the cosmetic black M cover off and youll see a black thing that looks like a pastic maxi pad held on by 4 bolts connected to a tube that runs into the intake plenum.
remove tube, unbolt, and look inside the holes to see if its really clogged up with sludge.
if it is it might be time to buy a new one... should be 40-60 at dealer.
Old Thu, Oct-25-2007, 04:46:13 AM   #39
Scooter426
roadracer
Scooter426's Avatar
Reputation: 0 Scooter426 will become famous soon enough
My oil light is coming on quite often. Every 3 tanks of gas (750 miles). I have noticed that the oil level will be near the lower mark, but not past. I put in a 1/2 quart the first time. Now I added a full quart. I have only had this car for 2500 miles and it has burned at least a quart to a quart and a half. This seems a bit excessive, but is normal from what BMW says. I keep the oil level high, just in case. I always carry a spare quart for peace of mind.
Scooter
Seattle (Issaquah), WA USA
2001 M3 Vert
Alpine White
Black Leather
K&N air filter!
Jump to top Scooter426 is offline   Reply With Quote
Old Thu, Oct-25-2007, 05:47:33 AM   #40
Rac'nmyT/A
Rac'nmyT/A's Avatar
Reputation: 0 Rac'nmyT/A is on a distinguished road
Have 15k on odo and no oil consumption at all, even at 6k oil change intervals. I cant say that I never gunned it during initial break in, but I never messed around until the oil was at least up to temp. These engines only need a few hundred miles of initial break-in to set the seals and bearings. I know, I know... BMW recommends 1200 but whatever.
CarbonBlack ZCP/Cinn Interior
6sp Manual
F-235/35/19 R-265/30/19 PSS
“If liberty means anything at all, it means the right to tell people what they do not want to hear.” _George Orwell
Jump to top Rac'nmyT/A is offline   Reply With Quote
consumption, oil, s54
Oil Consumption zoso E36 M3 (1992-1999) 39 Thu, Dec-08-2005 05:24:57 AM
Oil consumption... ArtM3 E46 M3 (2001-2006) 11 Fri, Oct-07-2005 09:32:48 PM
oil consumption?? g35coupe E46 M3 (2001-2006) 8 Tue, May-03-2005 11:51:50 PM
Oil consumption???? rossdogarr E46 M3 (2001-2006) 2 Fri, Jul-30-2004 04:31:05 PM
Oil Consumption jimmypM3 E46 M3 (2001-2006) 1 Thu, Feb-20-2003 03:25:14 AM
Discussing s54 oil consumption in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
