Old Tue, May-29-2007, 10:40:29 PM   #11
Helios59
Helios59's Avatar
Reputation: 0 Helios59 is on a distinguished road
Scotland
No oil burned or leaked in 14 months and 12,000 miles.
Kudos to the M Division! These are some pretty well-built engines.
'03.5 Cab: TiAG/Gray, SMG.
Current mods: VM CSL Reps, painted reflectors, BSW Stage 1 speakers, Konis, Eibach Pro-Kit (SOLD)
'11 ZCP Coupe Jerez Black/Black M-DCT, modless for now
Jump to top Helios59 is offline   Reply With Quote
Old Tue, May-29-2007, 11:00:31 PM   #12
Mash3
Look out below!
Reputation: 0 Mash3 is a jewel in the rough
The only oil I've burned in 51,000 miles was once right after break-in on a long trip up PCH, and after an all-day track sessions in the desert @ Willow Springs that see redline in 4 gears in 100 deg. heat. Otherwise it doesn't burn drop between 7.5k fills.
Greg
http://www.m3forum.net/gallery/data/522/medium/Willow_.jpg
Forum Member Since 2003.
. . 2004 M3, SG/ IR. No sunroof. 6MT. MCS SA. 18" Squares. Z4M rack. 130,000k miles. Original owner.
Jump to top Mash3 is offline   Reply With Quote
Old Tue, May-29-2007, 11:26:34 PM   #13
Radar
Radar's Avatar
Reputation: 0 Radar will become famous soon enough
I was actually just thinking about this.
I'm amazed that the car hasn't lost a drop at 4k from the last oil change.
The car only has 13k on it though.
Also I'm use to seeing the oil black after 1k with my Audi's I'm happy that with the M after 4k it still looks a nice light brown.
I use to loose 1 quart between my 3k oil changes on my TT
03.5-6MT M3 AW Vert
04-X3 3.0i FR
93-Nissan Hardbody
99-Yamaha R1
Jump to top Radar is offline   Reply With Quote
Old Wed, May-30-2007, 03:46:26 AM   #14
ArtM3
Reputation: 0 ArtM3 is on a distinguished road
BMW says 1 in 500 miles is OK, but I call BS...
1/2 in 3000 is not bad...what is more important is how it's changing...
if it's been that way forever, fine...
if it was
0 in 6000
1/2 in 6000
then 1/2 in 3000
there may be an issue...
how many miles on the car
how is it driven...hard all the time?
leaking or burning?
Jump to top ArtM3 is offline   Reply With Quote
Old Mon, Jun-25-2007, 03:25:39 AM   #15
sonoma99
Reputation: 0 sonoma99 is on a distinguished road
I am having the same problem. My oil light came on last month so I took the car into the dealership and it was a 1/4 low on oil. I figured it was b/c the dealership didn't fill it up after installing new cats, gaskets and manifolds.
Just yesterday the light decided to come back on and I'm trying to figure out the issue .
I've only put 1900 miles on the car in the past 3 months. No oil in the garage or driveway and no white smoke blowing out the rear.
Any suggestions from this group would be great.
I will plan to have the oil pan gasket checked since the oil bearing recall was done on the vehicle.
Any other advice?
JP
2002 SMG
Jump to top sonoma99 is offline   Reply With Quote
Old Mon, Jun-25-2007, 03:31:55 AM   #16
vndkshn
Goin' crazy... wanna come?
Reputation: 0 vndkshn is on a distinguished road
Just under 23k, zero oil consumed between changes.
Jump to top vndkshn is offline   Reply With Quote
Old Mon, Jun-25-2007, 05:08:03 AM   #17
cmackin300
cmackin300's Avatar
Reputation: 0 cmackin300 is on a distinguished road
Mine never uses oil. I suggest you get it looked at
Drive it like you stole it!
Jump to top cmackin300 is offline   Reply With Quote
Old Mon, Jun-25-2007, 05:13:46 AM   #18
Tp///M3
Got ///M?
Tp///M3's Avatar
Reputation: 0 Tp///M3 will become famous soon enough
Laos
No oil consumed here either, 39K
04 CarbonBlack/ImolaRed
Jump to top Tp///M3 is offline   Reply With Quote
Old Mon, Jun-25-2007, 08:13:43 AM   #19
tracktime
Reputation: 0 tracktime is on a distinguished road
From what I can tell, sometimes, oil leaks on these S54s of ours simply drip right onto the underbody tray underneath our cars, thereby missing the driveway. Neat freaks, these Germans, eh? ok ok i knoww.. the tray is to clean up the airflow underneath the car, I'd presume..
I'd recommend jacking up the car, and unscrew that tray FIRST, and THEN look for leaks..
2003 E46 M3 Steel Gray 6MT | OEM 19s 245F/275R | TCK S/As 400/500 | TCK Front Camber Plates | GC Sway Bar End Links | GC RTAB Shims | TCK/Buna RSMs| Dinan ECU Reflash | CDV delete | UUC Evo 3 SSK | GSP Clutch Pedal | ZHP shift knob & alcantara boots | Acts 20:24 | DICE | Euro Tray | Premier ClearBra | misc. cosmetic trim cleanup
Jump to top tracktime is offline   Reply With Quote
Old Mon, Jun-25-2007, 02:13:53 PM   #20
diogenes
diogenes's Avatar
Reputation: 0 diogenes is on a distinguished road
I was in to the dealer last week because I have gone from a liter every 3000 miles (over the last five years) to a liter every 1000. The SA showed me a page from bwmtis.net stating that a quart every 500 miles is acceptable (as Art notes above), but they're having me come in every 500 miles for the next 1500 to do an oil consumption test. They were a little vague about what happens next, except to state that BMWNA requires the test before deciding what if anything they will do.
Jump to top diogenes is offline   Reply With Quote
consumption, oil, s54
Oil Consumption zoso E36 M3 (1992-1999) 39 Thu, Dec-08-2005 05:24:57 AM
Oil consumption... ArtM3 E46 M3 (2001-2006) 11 Fri, Oct-07-2005 09:32:48 PM
oil consumption?? g35coupe E46 M3 (2001-2006) 8 Tue, May-03-2005 11:51:50 PM
Oil consumption???? rossdogarr E46 M3 (2001-2006) 2 Fri, Jul-30-2004 04:31:05 PM
Oil Consumption jimmypM3 E46 M3 (2001-2006) 1 Thu, Feb-20-2003 03:25:14 AM
Discussing s54 oil consumption in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
