Old Thu, Dec-14-2017, 12:43:48 AM   #331
daytonaviolet
OEM CSL Whoore
daytonaviolet's Avatar
Default M3 SMG pump reconditioning
Originally Posted by scoopy128 View Post
After you put the smg motor how long did it last before u got the light again
https://drive.google.com/open?id=1yb...tmtzeZOamYKxue
About 1yr 4mo. Here is a video of todayís pressure test. It never drops below 45bar. Iíll try to record it again but with a data logger while driving.
Let me know if you canít view the video.
Tischer aka GetBmwParts
Jump to top daytonaviolet is offline   Reply With Quote
Old Thu, Dec-14-2017, 12:55:06 AM   #332
scoopy128
Reputation: 0 scoopy128 is on a distinguished road
Default Re: M3 SMG pump reconditioning
Saw it can you use inpa while ur driving or can you start the car ? My pressure test is 32psi and it says i passed. But when i use thr car for like an hour i got this when im trying to do the pressure test
Jump to top scoopy128 is offline   Reply With Quote
Old Thu, Dec-14-2017, 12:58:16 AM   #333
daytonaviolet
OEM CSL Whoore
I tested for about an hour today. I could not get the cog light to come on. I was able to start ignition.. drive .. park.. could not duplicate previous issues. I had inpa on while driving but difficult to drive and watch the screen
Old Thu, Dec-14-2017, 12:59:04 AM   #334
daytonaviolet
OEM CSL Whoore
When you got this error .. does it say your still connected ?
Old Thu, Dec-14-2017, 01:01:25 AM   #335
scoopy128
Ok got it hehe i just ordered the motor kit and accumulator to them should have bought the seals so everyhing is new. My car has 17k miles and i get the cog sometimes when im in traffic and if its hot hehe
Old Thu, Dec-14-2017, 01:07:49 AM   #336
daytonaviolet
OEM CSL Whoore
Wow issues at 17k miles ? But car has 10yr old seals
Old Thu, Dec-14-2017, 01:13:55 AM   #337
scoopy128
I know but i bled the accumulator and clutch and made adaptation il check if i will get the cog light again. It had a leak before in the hose so i changed that and i just bled it now hopefully later when its hot and traffic here in my country i will check.
Yeah it is connected to the car thats what i got when i had the cog light and when i got the 4th gear error when i had the adaptation hehe.
Old Thu, Dec-14-2017, 01:17:29 AM   #338
daytonaviolet
OEM CSL Whoore
Too bad you canít read the temps. Burkhart commented that ~70c issues can occur
Old Fri, Dec-15-2017, 04:45:02 AM   #339
scoopy128
Still got it hehe did you use their oil? Also what code do you get now
Old Fri, Dec-15-2017, 05:19:04 AM   #340
Dr M3an M3
GroupBuyingPower@outlook. com
Dr M3an M3's Avatar
Are the issues occurring even in colder (winter temps) or only when it's warm out, or when stuck in traffic? Have you relocated the SMG pump?
IG: DrM3anM3
Mods: Genuine OE CSL Bumper, Both Karbonius and Streamline CSL Airboxes, OE CSL Snorkel w/ working Flap, OE Map Sensor + OE Air Rail, Paul Claude Custom Tune, CSL Engine management with CSL converted DME, Supersprint V1 Stepped Headers w/ Oversized Catless section 1, SS 2.5" Twin-Piped Oversized section 2, Rogue Engineering Muffler (soon to be switched), WPC treated rod-bearings, VinceBar (weld) + Redish Plates, Full Beisan VANOS lockdown, BBS LMs w/ PSS, CSL style CF diffuser, Vorsteiner CF CSL Bootlid, CSL SMG Engine DME tune, CSL '255' SMG DME tune.
Active Group-Buys (PM if Interested): OE CSL Bootlids, Supersprint Headers/Exhaust MEGA thread, New Supersprint Oversized Twin-Piped Section 2 ...and more to come!
Please PM me - In search of: Nothing at the moment.
Discussing M3 SMG pump reconditioning in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
