Old Wed, Apr-12-2017, 04:09:40 PM   #41
SunD3v1L
hi
SunD3v1L's Avatar
Reputation: 0 SunD3v1L is on a distinguished road
Italy
Default Re: Pilot Super Sport - awful tread wear ?
Zero toe up front for you Eric or a hair out? I run zero and 1/32"-3/64" each side inwards rear.
Toe in up front, hands down. It's better in all ways, in my opinion, especially on center, giving the wheel a locked down feeling over flighty sections of road. I like a steering wheel that "wants" to stay at 12 o'clock, requiring driver intent to change direction.
I like to drive fast and I don't want the steering wheel to do anything other than what I tell it. I don't like overly quick turn-in or fast ratios and I like some amount of understeer if really provoked.
I'm weird
where do you guys go here in SoCal where you can be so precise with your alignment specs?
Jump to top SunD3v1L is offline   Reply With Quote
Old Wed, Apr-12-2017, 05:21:54 PM   #42
Any shop that has the laser (e.g., "Hawkeye") alignment equipment. I once went to a local place where the guy got out his highschool geometry kit and I was like "ummm, no thanks bye."
In all seriousness, if the guy knows what he's doing, it can be done manually, but I feel like those people are getting harder and harder to find.
/// 2004 SilberGrau M3 · Coupe · 6MT · slicktop · manual seats · zero options · ~3200lbs · JOURNAL
_
Evolve-R Alpha N · Evolve CSL CF Airbox · Eventuri Scoop · Supersprint V1 stepped 2.5" · SS V1 S pipes 2.5" + 200 cell HFC · OE sect 2 · SCZA 2.5" sect 3 · Besian · RE pullies · fan/SAP/washer delete · CSL battery
Bilstein HD B6/Eibach 325/600lb + GC "tall" RSMs · Hotchkis front sway (med) · rear strut bar · TMS camber & subframe plates · Eibach alu rear camber arms · RE trans mounts · AKG poly subf/diff 95a · SDW RTAB · weighted ///M knob + ZHP alcantara boot + UUC DSSR + delrin bushing · Mason clutch pedal + brass bushing · TMS black pedals · delrin brake pedal bushing
OE CSL trunk · Sportline 8S 18"x8.5/9.5" · MPSS 245/275 · APEX 75mm Studs · Brembo 996 4 pot 36/40 345mm CSL & 28/30 328mm CSL · ZHP "712" rack · Pioneer/CDT/Eclipse/Kicker
Old Wed, Apr-12-2017, 05:27:15 PM   #43
cowboyM3
Reputation: 0 cowboyM3 is on a distinguished road
Do PSS stretch good?
I know they run a little big but I only had the experience with them on my oem 19's (255/35/19)
I want to try 325/25 on 20x14
Jump to top cowboyM3 is offline   Reply With Quote
Old Wed, Apr-12-2017, 05:31:19 PM   #44
It's obvious you don't care about proper chassis setup and you're not the type to cough up the dough required for top quality parts, so why bother with PSS? Seems like they'd be wasted on what you set your car up for. I'm being serious.
_
Old Wed, Apr-12-2017, 05:32:59 PM   #45
cowboyM3
Touche
looking at these toyo's instead
Old Wed, Apr-12-2017, 05:37:51 PM   #46
Just get whatever's cheapest and burn through them enjoying your car the way you want to; burnouts, drifting.
_
Old Fri, Apr-21-2017, 12:44:18 AM   #47
twism
Reputation: 0 twism is on a distinguished road
Bulgaria
I can't believe no one mentioned inflation. If your tires were overinflated they will wear out pretty quickly. It happened to my wifes f30. Its usually a good rule of thumb to check tire inflation every couple weeks.
Jump to top twism is offline   Reply With Quote
Old Fri, Apr-21-2017, 12:57:48 AM   #48
T-Rex
Reputation: 0 T-Rex is on a distinguished road
Go see Darren & Chris at West End Alignment in Gardena. You'll never go anywhere else again - they're absolute wizards when it comes to alignment.
Jump to top T-Rex is online now   Reply With Quote
Old Fri, Apr-21-2017, 01:53:05 AM   #49
Cha5en
Reputation: 0 Cha5en is on a distinguished road
Default Pilot Super Sport - awful tread wear ?
This. Call and get ready to wait, but it's well worth it. These guys setup most of the super fast autoX cars around here
Or Racewerkz Engineering.
Jump to top Cha5en is offline   Reply With Quote
Old Fri, Apr-21-2017, 04:30:15 AM   #50
JTM09
I like cats
JTM09's Avatar
Reputation: 0 JTM09 is on a distinguished road
What psi should I run? Rears are 275/35
2017 YMB/GB ZCP 6MT
2006 IR/Blk ZCP 6MT-sold
2006 AW/Cinn (slick top) 6MT-sold
2002 TiAg/Grey 6MT-sold
Jump to top JTM09 is offline   Reply With Quote
Discussing Pilot Super Sport - awful tread wear ? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
