Old Tue, Apr-11-2017, 06:02:35 PM   #31
SunD3v1L
hi
SunD3v1L's Avatar
Reputation: 0 SunD3v1L is on a distinguished road
Italy
Default Re: Pilot Super Sport - awful tread wear ?
RTABs / FCABs
Burned through a set of rears in like 5k to almost bald - changed RTABs - 15k and still going strong
Got the partial warranty credit on the new pair too, even though it was dude to mechanical issues lol
Jump to top SunD3v1L is online now   Reply With Quote
Old Tue, Apr-11-2017, 06:15:45 PM   #32
JTM09
I like cats
JTM09's Avatar
Reputation: 0 JTM09 is on a distinguished road
What kind of discount did you get from them?
Boys, my fcabs and rtabs are new - less than 15k on them.
2017 YMB/GB ZCP 6MT
2006 IR/Blk ZCP 6MT-sold
2006 AW/Cinn (slick top) 6MT-sold
2002 TiAg/Grey 6MT-sold
Jump to top JTM09 is offline   Reply With Quote
Old Tue, Apr-11-2017, 07:54:30 PM   #33
SunD3v1L
hi
SunD3v1L's Avatar
Italy
I forget - the tread life warranty is like 30k.
And then it's cut in half, if your fronts and rears are different sizes; which mine are so 15k.
Then they took the mileage that were on them, vs the warranty (15k), and pro-rated a discount towards the new pair.
So I essentially got the new pair for 66% off.... then drove straight over to my shop to get RTABs and FCABs done... then an alignment.
Old Tue, Apr-11-2017, 08:20:00 PM   #34
JTM09
I like cats
JTM09's Avatar
That's not too bad at all. I bet where I get screwed will be the fact that I run a winter set up from mid nov - now.
if they look at the invoiced mileage and my car current odometer it'll look like I put 9500-ish on the pilots. When in reality close to 1/2 that is on my winters. Oh well ..still going to check into it.
2017 YMB/GB ZCP 6MT
Old Tue, Apr-11-2017, 10:34:51 PM   #35
Monte0704
Monte0704's Avatar
Reputation: 0 Monte0704 is on a distinguished road
Not if you have a receipt showing the switch.
2004 E46 M3 SMG II | 1990 Nissan Skyline GTR
Jump to top Monte0704 is offline   Reply With Quote
Old Wed, Apr-12-2017, 01:52:52 AM   #36
JTM09
I like cats
JTM09's Avatar
I do the winter/spring swap myself at home ..no receipt
2017 YMB/GB ZCP 6MT
Old Wed, Apr-12-2017, 05:01:32 AM   #37
Zero toe up front for you Eric or a hair out? I run zero and 1/32"-3/64" each side inwards rear.
_
Old Wed, Apr-12-2017, 02:25:24 PM   #38
EricSMG
40 something
Toe in up front, hands down. It's better in all ways, in my opinion, especially on center, giving the wheel a locked down feeling over flighty sections of road. I like a steering wheel that "wants" to stay at 12 o'clock, requiring driver intent to change direction.
I like to drive fast and I don't want the steering wheel to do anything other than what I tell it. I don't like overly quick turn-in or fast ratios and I like some amount of understeer if really provoked.
I'm weird
2004 E46 M3 6MT SG/Black
Old Wed, Apr-12-2017, 03:12:22 PM   #39
Toe in up front less than, equal to or more than in the rear? Thanks Eric.
_
Old Wed, Apr-12-2017, 03:35:28 PM   #40
EricSMG
40 something
.03ish toe in, each side, front
.12ish toe in, each side, rear
Discussing Pilot Super Sport - awful tread wear ? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
