Old Mon, Mar-20-2017, 09:21:43 PM   #1
trippower
Reputation: 0 trippower is on a distinguished road
Default M3 e46 Crank No Start
(First time poster)
Had my 2002 BMW M3 (SMG) parked for the winter, In my garage. I was forced to park my car out on the street one night where it sat over night, Next morning went to start my car and the car cranked and cranked but would not start, my gas tank was nearly empty, the temperature outside was in the negatives. Filled it back up with gas, still nothing, replaced the fuel pump, still nothing, replaced the fuel filter, still nothing, no check engine light, newer spark plugs and coils.I can hear the fuel pump priming, and the car cranks, almost starts and dies back out. I tried all my spare keys, I thought it could be a DME issue still nothing. Im at a loss right now of where to check next.
Here's a link of what the car is doing
Jump to top trippower is offline   Reply With Quote
Old Mon, Mar-20-2017, 09:45:30 PM   #2
rovert604
rovert604's Avatar
Do you hear your fuel pump priming prior to engine start attempt? Maybe a fuse is broken?
It's interesting how the started stops while the revs go up then tries starting right after the revs fall.
--Trevor in 604--
Vancouver, BC, Canada
Old Mon, Mar-20-2017, 09:53:12 PM   #3
trippower
Default Re: M3 e46 Crank No Start
Yes I can hear the fuel pump priming before I attempt to start the car, I did check fuse 54 I believe, it was a yellow 20 amp fuse that was labeled fuel pump, and it was fine.
Old Mon, Mar-20-2017, 09:56:36 PM   #4
rovert604
rovert604's Avatar
Check the shrader valve at the fuel filter to see if there is actual pressure. If there isn't then I'd assume something is wrong with the pump even though it sounds like it primes?
--Trevor in 604--
Old Tue, Mar-21-2017, 12:30:15 AM   #5
Monte0704
Monte0704's Avatar
Reputation: 0 Monte0704 is on a distinguished road
Unplug your MAF and see if it starts. Just had a fella on facebook post a question like this, and as soon as he unplugged his MAF the damn thing started running fine on the backup failsafe air map I guess.
His would crank and try to start, but almost like as soon as it even fired once it would stop.
2004 E46 M3 SMG II | 1990 Nissan Skyline GTR
Jump to top Monte0704 is offline   Reply With Quote
Old Tue, Mar-21-2017, 12:45:49 AM   #6
trippower
Ill give it a try!
Old Tue, Mar-21-2017, 04:44:51 AM   #7
trippower
Still nothing.
Old Tue, Mar-21-2017, 09:46:52 AM   #8
MartynT
MartynT's Avatar
United Kingdom
Do you have INPA? Try syncing your EWS.
Jump to top MartynT is offline   Reply With Quote
Old Tue, Mar-21-2017, 01:33:36 PM   #9
NathzZ
Reputation: 0 NathzZ is on a distinguished road
Had a very similar problem. Turned out to be the fuel pump. The pump will come on but couldn't hold pressure.
Jump to top NathzZ is offline   Reply With Quote
Old Tue, Mar-21-2017, 04:28:58 PM   #10
Monte0704
Monte0704's Avatar
Okay, so you've eliminated the fuel pump and the MAF. I would lean towards the key being the issue, like these guys are saying, if you have new spark and coils.
crank, electrical fault, m3 e46, no start, smg
Discussing M3 e46 Crank No Start in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
