Old Mon, Mar-20-2017, 06:17:35 PM   #1
mrgicm
mrgicm's Avatar
Reputation: 0 mrgicm is on a distinguished road
Croatia
Default Fan wont stop working after A/C and SAP delete
So I have removed the A/C and all lines, removed the SAP pump and now when I turn on the engine the fan just starts working on maximum.
Does anyone know what is needed to regulate this?
Do I even need the front fan?
Jump to top mrgicm is offline   Reply With Quote
Old Mon, Mar-20-2017, 06:39:53 PM   #2
Drewster
Drewster's Avatar
Default Re: Fan wont stop working after A/C and SAP delete
Sounds like you grounded out the Aux fan control wire, or pissed the ECU off to the point that it's just giving 100% to the controller.
Did you actually code the SAP out or just remove it?
Old Mon, Mar-20-2017, 07:05:08 PM   #3
mrgicm
mrgicm's Avatar
Croatia
I just removed it. Could coding it out be the solution?
Old Mon, Mar-20-2017, 07:26:14 PM   #4
SliM3
SliM3's Avatar
Yeah, you're going to have to code everything out of the tune. The A/C usually activates the electric fan when the compressor clutch is connected, which, is controlled by the DME as well.
///M3 '06 Carbon Black
-Benjamin Franklin
- Fuel adaptations explained
- Checksum Verification
Old Mon, Mar-20-2017, 08:02:04 PM   #5
10speed
Reputation: 0 10speed is on a distinguished road
I am in this position as well.
I want to delete AC but I know when I do that the electric fan that I have wired to the AUX controller will operate at 100%.
Coding this out is a little bit outside of my skill set at the moment, so I may just wire the electric fan in a more traditional way.
Jump to top 10speed is offline   Reply With Quote
Old Mon, Mar-20-2017, 08:21:09 PM   #6
SliM3
SliM3's Avatar
Let me look through the software and see exactly what needs to be corrected, and I'll post back here, if that'll help.
-Benjamin Franklin
Old Mon, Mar-20-2017, 08:21:17 PM   #7
mrgicm
mrgicm's Avatar
Croatia
I also want to install the Spal electric fan and will do that in a few weeks.
Would it be possible just to add a resistor to the pressure valve?
Old Mon, Mar-20-2017, 09:01:44 PM   #8
SliM3
SliM3's Avatar
If you're still going to run a push-pull set up, you can wire the Spal to the stock fan controller, set the switch-on %'s in the DME, and run something like a 160 fan controller to the stock electric fan.
-Benjamin Franklin
Old Mon, Mar-20-2017, 09:16:08 PM   #9
mrgicm
mrgicm's Avatar
Croatia
That would be great thanks!
I am going to run a thermalswitch for the spal fan.
Old Wed, Mar-22-2017, 06:56:09 PM   #10
mrgicm
mrgicm's Avatar
Croatia
So not to start a new thread , I have removed the mechanical fan and the AC including the ac radiator, so can I use now just the Aux fan for cooling or is any coding / wireing needed and which ones.
I have searched but never came to using this with the AC removed?
Discussing Fan wont stop working after A/C and SAP delete in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
