Old Mon, Mar-20-2017, 09:55:00 PM   #11
C-M2
Reputation: 0 C-M2 is on a distinguished road
Default Re: Insurance coverage amounts
Just a heads up to OP. Grundy's risk acceptances: http://www.grundyworldwide.com/pdf/EligibilityReqs.pdf
Hagerty and American Modern will also take the risk.
Originally Posted by Kaptom540 View Post
Here is the previous discussion about Hagerty Insurance .. You can get an agreed value policy .. of course the higher the value the higher the premium. I believe Hargerty requires the vehicle to be garaged and not your daily driver. As for Grundy based on their commercial, I believe they offer daily driver coverage.
This is correct for most specialty insurers. If the car is your daily driver they will likely not accept it.
2009 Space Gray e92 M3 Coupe/// OEM C/F Performance Trim, OEM Performance Steering Wheel, OEM Performance C/F Limited Center Console, OEM C/F Performance Mirror Covers, OE GTS Front Splitter/Lip, LCI Tails, IND Blacked Out Trim Pieces, SuperSprint Race Section 1-2-3, Apex EC7s 18x10/18x11, Stoptech 6pot, AlekShop 90mm Studs, AlekShop Half Cage, Recaro Profi XL's, Planted Seat Hardware, Custom Rear Seat Delete, Ohlins R&T Coilovers, Vorshlag Camber Plates, RD Sport Sways, AlekShop Solid/Delrin Rear Subframe Bushings, AlekShop Solid/Delrin Diff Bushings, Dinan Intake
Sold
04 ///M3 Jet Black Coupe
Jump to top C-M2 is online now   Reply With Quote
Discussing Insurance coverage amounts in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
