Old Mon, Mar-20-2017, 03:26:20 PM   #11
tripitz
Reputation: 0 tripitz is on a distinguished road
Default Re: Cracked Rear Shock Tower
The guy who welded in my RTAB pockets has done the shock tower repair before. It seems almost not much worse than grinding the whole area down.
Will a welded in AKG plate really be sufficient to fix this problem? This will be a track car. Will the plate interfere with other things like rogue shock mounts and/or a bar?
Jump to top tripitz is offline   Reply With Quote
Old Mon, Mar-20-2017, 03:35:28 PM   #12
LockDots
LockDots's Avatar
Originally Posted by englishtom1596q View Post
it will absolutely not be cheaper to replace the shock tower. Also if you replace the tower you risk it not being aligned correctly and ruining the car forever. As said get in there with a angle grinder of dremel with a cutoff wheel. If you weld from the top it will be a lot easier to get to
I disagree somewhat. One would have to almost literally botch the job terribly or purposefully line it up badly in order for it to not be aligned properly.
If the broken shock tower is removed appropriately (seam sealer wire-wheeled off, seams cut through with a knife/blade, and the tack welds cut out using a tack weld cutting bit) the wheelhouse metal should end up fairly straight enough to literally sit the new tower into place and have it line itself up as you push up on it from underneath.
That being said, the AKG plate will definitely be cheaper than replacing the tower, but replacing the tower isn't necessarily significantly riskier. Besides, it's what the shock mounts to and is a part that swivels in and out at the base of the shock, not so much the top. It certainly shouldn't affect the alignment of the car and shouldn't affect the feel, so long as the repair is done properly, aka not-botched-up.
Old Mon, Mar-20-2017, 04:42:43 PM   #13
tripitz
My welder has done the job for his track car, so I feel good about his capabilities. His recommendation was to check to see if there is a quicker/easier alternative given that my towers are mostly intact and the tears on one side are not all the way through. He did not like the idea of actually welding the cracks themselves given the need to have everything flat. He wants to tie the AKG plates into the good/strong materials away from where the cracks are.
It doesn't seem like there is a significant downside for going this approach. It is still going to be a lot of work. What is the impact on the shock mounts that I can use? I have the rogue ones for the rear..
Old Mon, Mar-20-2017, 05:01:18 PM   #14
tripitz
Ordered AKG plates. Talked to them. Going to give this a try.
Old Mon, Mar-20-2017, 06:35:28 PM   #15
Oogie_M
o_O
Oogie_M's Avatar
Reputation: 0 Oogie_M is on a distinguished road
Taiwan
This is how mine were installed. Original condition was a slight crack near the lip, welded up and the plate installed. Seam sealer and then painted later on.
Jump to top Oogie_M is offline   Reply With Quote
Old Mon, Mar-20-2017, 07:43:29 PM   #16
tripitz
That looks great. Not a ton of load in this area when using the stock suspension configuration so hopefully mine will work like this. It is also seems like an easy fix. Will start cleaning up the area tonight.
Discussing Cracked Rear Shock Tower in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
