Old Mon, Mar-20-2017, 12:26:59 AM   #1
tripitz
Reputation: 0 tripitz is on a distinguished road
Default Cracked Rear Shock Tower
After having my RTAB pocket and subframe reinforcements welded in, I realized that my right rear shock tower is cracking.
It looks like I have two options... weld in the AKG "repair plate" or replace the entire shock tower. Is the AKG repair sufficient? The cracking is actually very minor right now as the broader area is still undamaged and the holes for the shock mounts still have some integrity. Can I get away with the AKG plate or do I really need to do the full job?
http://imgur.com/a/LrQyo
Jump to top tripitz is offline   Reply With Quote
Old Mon, Mar-20-2017, 12:32:02 AM   #2
westopher
westopher's Avatar
Default Re: Cracked Rear Shock Tower
How bad is it? Pics will go a long way.
98 m3, techno/anthrazit cloth, 103k and officially worthless. 2000 323i touring, silver/grey/sport pack, 170k and officially boring.
Jump to top westopher is online now   Reply With Quote
Old Mon, Mar-20-2017, 12:47:00 AM   #3
tripitz
Link to top and bottom... can see hairline cracks from top and also from bottom. Bigger cracks near the mounting hole.
Old Mon, Mar-20-2017, 12:49:14 AM   #4
fiveightandten
fiveightandten's Avatar
+1 Pics would help. If it really is minor, the plates are likely fine.
Are you on stock, or aftermarket suspension?
Don't forget, the towers don't hold up the weight of the car, so there isn't a huge amount of force on them. They usually fail due to worn mounts, or from blown shocks that let the suspension bottom out and allow big blows to the towers under shock compression. I'd definitely replace the mounts. If the shocks are questionable, it's time for new shocks as well.
-Nick
Old Mon, Mar-20-2017, 12:55:16 AM   #5
tripitz
This is for a track car build. Going to be running MCS with rogue shock mounts. Not running coilovers in the rear so spring rate won't matter. It's definitely an issue; I'm not sure if I can get away with just welding in the AKG plates or if I have to plan on a full repair.
Pics are linked above.
Old Mon, Mar-20-2017, 01:09:55 AM   #6
englishtom1596q
englishtom1596q's Avatar
I would just weld the plates in for now but I would run a bead along the cracks first and grind smooth. You'll definitely be able to salvage that without replacing the tower
Old Mon, Mar-20-2017, 01:44:11 AM   #7
fiveightandten
Agreed. Fill any cracked areas, grind it down, and weld the plates in. That will be fine. Look at it this way, a new tower would have a lot more welding involved than filling the damage you have, and the metal isn't separated and deformed. Right now, everything is lined up as it was from the factory and the damage is very minimal.
-Nick
Old Mon, Mar-20-2017, 02:27:33 AM   #8
tripitz
This may seem like a silly question... how do you grind that area? Since most of the damage is from the bottom, it is going to be crazy hard to get to. Do I need one of those long angle grinders and go with something like rolocs to grind it? If so, it may be cheaper for me to replace the shock tower.
Old Mon, Mar-20-2017, 10:45:42 AM   #9
LockDots
LockDots's Avatar
Pull the shock out and use an angle grinder without a shield. For a little more reach in that area from underneath try using a wire wheel.
Old Mon, Mar-20-2017, 12:12:29 PM   #10
englishtom1596q
it will absolutely not be cheaper to replace the shock tower. Also if you replace the tower you risk it not being aligned correctly and ruining the car forever. As said get in there with a angle grinder of dremel with a cutoff wheel. If you weld from the top it will be a lot easier to get to
Discussing Cracked Rear Shock Tower in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
