Old Sun, Mar-19-2017, 06:02:45 PM   #1
JitteryJoe
Default Gauge pod & gauges
I'm looking to add some gauges. I looked at steering column pod (RallyRoad) & sunglasses tray pod (LeatherZ). I think I'd opt for steering column because the other is just too far off the normal driving sight line. But I prefer 3 gauges: oil & water temp, oil pressure. So either solution seems a compromise.
Have others solved this problem? Is there a 2 in 1 gauge (say oil temp & pressure in one gauge)? What about steering column vs. Sunglasses tray installation? I've looked at LeatherZ but it just seems too much out of sight.
Also, I've looked at analog style gauges (e.g. VDO) and digital (e.g. ProSport EVO). Any suggestions here?
Thanks! Joe
Old Sun, Mar-19-2017, 06:38:17 PM   #2
TheJDub-E36
TheJDub-E36's Avatar
Reputation: 0 TheJDub-E36 is on a distinguished road
I've been looking at this.
http://www.chetcodigital.com/vGauge/...pec_Module.htm
Also this but it's been sold out for a while
http://www.etbinstruments.com/index....product_id=171
Jump to top TheJDub-E36 is offline   Reply With Quote
Old Sun, Mar-19-2017, 07:21:53 PM   #3
JitteryJoe
Default Re: Gauge pod & gauges
Both look difficult to place without significant modification (such as a track car).
Hoping not to stray too far from OEM look & feel.
Old Sun, Mar-19-2017, 08:57:48 PM   #4
Evtron
Evtron's Avatar
Reputation: 0 Evtron is on a distinguished road
I've put a lot of thought into this recently. I also want 3 gauges, and I'd prefer to not use the A-pillar or the sunglass tray. I'm leaning toward the stereo DIN slot, and considering relocating the stereo to the glovebox to retain bluetooth functionality. Just need to figure out a clean way to do it. I also haven't found a decent 3 gauge DIN panel yet, thinking about making one out of the factory DIN blank.
E36 M3 Sedan Journal
Jump to top Evtron is offline   Reply With Quote
Old Sun, Mar-19-2017, 09:12:18 PM   #5
TheJDub-E36
Yeah, it's definitely more of an install than just the typical gauges, I had a three pod in the sunglass tray and it just looked too tuner or ricer and like you said it's hard to see them.
Old Sun, Mar-19-2017, 09:44:27 PM   #6
JitteryJoe
Not sure I'd be willing to remove radio. Plus, I think to do it right, you need to pivot the gauges toward the driver. I'll be interested in what you come up with. Thanks!
Old Sun, Mar-19-2017, 09:46:46 PM   #7
JitteryJoe
More tuner than a steering column pod? One of the issues I have with the column mount is that it seems a bit tunerish. But also seems the most practical. Go figure.
Old Sun, Mar-19-2017, 09:52:42 PM   #8
betrezra
I've been going thru this as well....... after removing my glove box to change carpet..... it seems you could put some gages in your glove box (spare box).... pop the door open to check on things. If you want to retain oem looks.
Another option I installed an a clk55 years ago to remain stealth was a digital multi-function display...... the trick bit was to install it behind smoked lexan. When off you saw nothing.... when on I had my remove V-1 display there and my wide-band display there. You can put this lexan window just about anywhere you have a flat panel.
I wonder if there is a blue-tooth feed avail...... mount your I phone to a suction cup windshield mount.... blue-tooth to your black box which is connected to the temp, oil, etc... no wires, no boy racer gages..
E36M3
Old Sun, Mar-19-2017, 09:55:52 PM   #9
TheJDub-E36
The nice thing about the rally road set up is you can adjust the height, but it's only two gauges.
Old Sun, Mar-19-2017, 09:56:28 PM   #10
You can get some 2 in 1 gauges. More expensive. I like the RR column dual pod. It's on my list. I have 3 on the pillar and 3 in the sunglass cubby. Would rather just have a single with 5 digital lines but you have to buy a plug together system to get that. Zeitronix maybe and there are probably others. Have seen people put displays into rear view mirror but that is advanced class. Also where mpg is in cluster. Could replace stock idiot coolant gauge in cluster with real one.
Discussing Gauge pod & gauges in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
