Old Wed, Mar-15-2017, 03:31:33 AM   #31
Default Re: Money Shift Into Second Around 70 MPH
Put the battery on a charger while cranking. Spark plugs out of all holes. Throttle wide open.
Old Wed, Mar-15-2017, 01:08:56 PM   #32
englishtom1596q
englishtom1596q's Avatar
When I had the 5th gear lean, it was only sticky going in or out of the 5th gear gate. 3rd and 4th were completely unaffected, unless it involved shifting in/out of 5th to/from one of those gears.
I've never heard of this issue *pulling* the shifter into the 5th gear gate from 3rd gear.
This is not true 5th gear lean. 5th gear lean is when the spring and detent pushing the shifter towards the left of the gate gets stuck fully retracted. This causes the shifter detent for the left side to push it all the way to 5th gear. Hence the name 5th gear lean. From neutral (by 5th gear) you have to put pressure to the left to get it into 4th and even further for 2nd. My car I have now exhibits the same issue you have which I believe is the precursor to full 5th gear lean when the detent seizes. This is also why when you do the detents you install an updated bushing that has an orange plastic bushing almost to stop it siezing
Old Fri, Mar-17-2017, 07:12:47 PM   #33
thirtysixnick
10/10 wasn't ignition coils on the misfiring cylinder LOL
Definitely assuming the worst so I'll be saving up maybe a grand or two, and then looking into getting it actually taken to a shop... Almost would rather sell the car as a roller, save up a couple of thousand, and then look for another E36 M, but it just wouldn't be the same...
So torn not being able to drive this damn thing haha
Old Fri, Mar-17-2017, 08:49:13 PM   #34
betrezra
Is there too much risk buying a <100K miles used E36 motor?
E36M3
Old Fri, Mar-17-2017, 08:52:40 PM   #35
westopher
westopher's Avatar
Fix it, fix it right and you will have a very fresh motor and know exactly what's going on. I've ****ed some shit up on my car, but as time goes on and I blow more and more money on fixing everything properly I know exactly what to expect. Being 100% confident in your car means so much to the enjoyment of it.
98 m3, techno/anthrazit cloth, 103k and officially worthless. 2000 323i touring, silver/grey/sport pack, 170k and officially boring.
Old Fri, Mar-17-2017, 09:47:41 PM   #36
thirtysixnick
Not at all, but I would rather have a rebuilt top end on my 160k mile engine vs a possibly more abused engine that could run into more minor hiccups than mine. Dealing with an engine swap really isn't what I'm looking for at my age and pay grade either
Oh man I definitely plan to get it all done right for sure. The best part about breaking things on my car is knowing that when they're fixed, they're fixed GOOD. As you said, being confident makes it so much more enjoyable, and by the time I'm "done" (never) with this damn machine it'll be such a joy in every aspect; Even if it takes a year or two of on and off driving just to get it to that point, I plan to get it there.
Also thanks for the reply and FYI, a few shots from your member journal are a part of my cycling wallpapers at my tech school. Keeps me motivated to keep striving to be OEM and clean haha.
Still debating on how I want to handle all of this exactly. Should probably get a little money before I start jumping into stuff though.
Old Sat, Mar-18-2017, 12:43:25 AM   #37
tripitz
Reputation: 0 tripitz is on a distinguished road
As I am/have learned, an engine swap usually results in a non-stop list of "while you are in there" things to change/fix just so you KNOW what is done or not done on your engine. It is also a ton of work...
Jump to top tripitz is offline   Reply With Quote
Old Sat, Mar-18-2017, 02:10:39 PM   #38
M-technik-3
Why not get a used head, Have you used a borescope and looked at the internals? As most have said you have a bent valve or two or three...Hopefully you did not drop a valve as that world render swap out the head.
Autozone or advanced sometimes will have a borescope for loan or heck the Chinese emporium aka Harbor Freight.
Are you a CCA member? Maybe there is a local near you that would be willing to loan you a hand or some tool's. I know the Boston Chapter is good like that.
Old Sat, Mar-18-2017, 02:22:19 PM   #39
englishtom1596q
There are usually plenty of refreshed heads that pop up on eBay and bimmerforum for like $800. I would not go all out if you don't have the money and just want it back on the road. Either that or just pull yours and get it to a machine shop and have them do the bare minimum of replace the bent valves, install new guides, seals and lapping.
Old Sat, Mar-18-2017, 06:20:38 PM   #40
M-technik-3
My thought's too ^ It's not overly complicated. The head is pretty much the same for all 4 engines we got here in the US except the hole for OBD I vs II for coolant sensor area.
cel, e36 m3 money shift, misfire, money shift
Discussing Money Shift Into Second Around 70 MPH in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
