Old Tue, Mar-14-2017, 12:27:56 PM   #21
fiveightandten
fiveightandten's Avatar
Default Re: Money Shift Into Second Around 70 MPH
Originally Posted by j0rdan J View Post
Just curious, does your car have the 5th gear lean issue? If so, that can explain why the money shift happened! When you fix the car, drop the trans and take care of that so it won't happen again
How would the 5th gear lean cause him to money shift from 3rd to 2nd?
-Nick
Old Tue, Mar-14-2017, 03:39:32 PM   #22
Sloppy shifter does not help anything. I suppose one could be an indirect cause of missing a shift since it changes the pattern a little from where it should be.
I partially blame my E90M3 for my 4th to 2nd E mis-shift in my E36M3. The E90 has 4th where 2nd is on the E36 (the E90 has 2-4-6 in the rear of the pattern). I also blame myself -- I was tired, had not been driving the E36 much, and was not paying attention
Old Tue, Mar-14-2017, 04:03:46 PM   #23
englishtom1596q
englishtom1596q's Avatar
Because when you pull it out of 3rd it wants to pop over to the right. Meaning you have to put pressure on the shifter to hold it left to get it into 4th. Too much pressure and you can pop into 2nd. I've done it before on my old M3 which prompted me to immediately order the detent kit and get it sorted. Luckily for me I noticed the revs when I started to release the clutch.
Old Tue, Mar-14-2017, 04:27:45 PM   #24
fiveightandten
When I had the 5th gear lean, it was only sticky going in or out of the 5th gear gate. 3rd and 4th were completely unaffected, unless it involved shifting in/out of 5th to/from one of those gears.
I've never heard of this issue *pulling* the shifter into the 5th gear gate from 3rd gear.
-Nick
Old Tue, Mar-14-2017, 06:03:46 PM   #25
j0rdan J
Reputation: 0 j0rdan J is on a distinguished road
Basically this. At least for me, I had some difficulty getting fourth gear with my detent issue. Luckily I never money shifted my car. I do have a friend who grabbed second instead of fourth at highway speeds, he quickly pressed the clutch back in once he was near 7 grand. Luckily no damage.
Another issue my transmission had was the forward gear detents, so third and fourth were really notchy on my car and required considerable effort when cold
Jump to top j0rdan J is offline   Reply With Quote
Old Tue, Mar-14-2017, 06:05:28 PM   #26
tsmith25
Reputation: 0 tsmith25 is on a distinguished road
You weren't quite at the fifth gear lean stage yet then. Also, 5th gear lean doesn't shift the pattern like some people have said, it just reduces the centering that the transmission does for you. Mine is like you are describing. When it is cool in the morning and the transmission has not warmed up yet, if I put it into 5th, It will give me the lean till it gets warmed up. I treat it like a 4 speed till it gets hot now to avoid that. I never understood how people money shift, until I was driving mine and got the temporary 5th gear lean. It is exactly like he described above. You can't hit 4th without pulling it a little towards 2nd. It would be easy if you were rushing to go past and hit 2nd instead.
Jump to top tsmith25 is offline   Reply With Quote
Old Tue, Mar-14-2017, 06:29:02 PM   #27
fiveightandten
Agreed. It sounds like you have the typical symptoms. But out of all the documentation I've seen and every E36 I've driven with 5th gear lean issues in the past 10+ years, I've never heard of the transmission pulling the gear shift from 3rd to 5th when 5th was not initially engaged. That sounds very dangerous.
Anyways, I think we can all agree on the formula to avoid misshifts:
-Good condition motor mounts and transmission mounts
-Good condition shift linkage parts
-Fix 5th gear lean
-Prudent shift technique
If any of those things are questionable in your mind, don't drop that clutch out before you know where your shifter is. It's not worth the 1/2 second to confirm....on the street or on the track.
-Nick
Old Wed, Mar-15-2017, 12:39:39 AM   #28
thirtysixnick
To answer the fifth gear lean question, yes.
Do I think it caused my miss shift? No. I blame myself and bad bushings that should've been replaced my first few months of ownership.
Tried doing a compression test today, but my battery is SHOT.
At first cylinder 1 pulled 150psi and then after slowing moving down cylinders the cranking got slower and slower along with the other cylinder's psi decreasing so I went back to cylinder one and pulled 90psi.
I hooked my car up to my dads Camry with jumper's and restarted from cylinder one, pulled 150psi again, pulled 90psi on two, went back to cylinder one and pulled 90psi.
Can't tell if the tool or it was just my shot battery so I moved to cylinder three and pulled like 60psi???? Cylinder three wasn't even one that was read for a misfire so I just assumed the battery is done, even on jumpers. I believe the battery is long overdue to be replaced I've just been neglectful on changing that.
I decided to order two new ignition coils for cylinder four and five, as per instruction from the indy mechanic who's done pretty much all the work on my car previously (including new clutch/flywheel/rear main seal/electric fan swap).
Quick final question: when I was doing the compression test I removed the fuel pump relay and went WOT during the times I was cranking the engine. Would doing this harm the engine or flood anything that would ignite on initial startup since I couldn't start the engine to completely run it out of fuel? Sorry4noobyness
Old Wed, Mar-15-2017, 01:25:29 AM   #29
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
Ok I see the hand positioning article is already mentioned now.
WhenI saw that some years ago, I tried it. At first a little odd, now it has become second nature.
When you shift from 3 to 4, don't you reverse your hand? (So the thumb is down and the shifter is at the right of your hand, not on the left side).
It's water under the bridge now, but this makes it impossible to pull the shifter to the left wjen pulling out of 3.
Old Wed, Mar-15-2017, 01:56:35 AM   #30
fiveightandten
Ignore the cylinder numbers and your test results suggest a lack of power to crank the engine sufficiently.
Test 1 - 150
Test 2 - 90
Test 3 - 90
Test 4 - 60
You should see the needle rise very rapidly, then rise a little more, and stop rising. It sounds to me like the engine just wasn't cranking enough. Was the Camry running? That should provide sufficient power, but you may have to wait a few minutes in between tests. It sounds like you need a new battery regardless.
-Nick
cel, e36 m3 money shift, misfire, money shift
Discussing Money Shift Into Second Around 70 MPH in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
