Old Thu, Feb-16-2017, 07:31:44 AM   #21
911Fiddler
Reputation: 0 911Fiddler is on a distinguished road
United Kingdom
Default Re: Horrible engine noise
Hope that was it! At your mileage if you haven't done the bearings yet, it's good idea to just do them now anyway.
Yes the rod bearing shells were done a while back....
http://forums.m3cutters.co.uk/showthread.php?t=104983
Jump to top 911Fiddler is offline   Reply With Quote
Old Thu, Feb-16-2017, 09:39:05 AM   #22
paulclaude
paulclaude's Avatar
Reputation: 0 paulclaude is on a distinguished road
Scotland
One of mine is making almost the exact same noise right now. I'm 99% sure it's either the clutch release/throw out bearing or broken pressure plate. The noise disappears if a gear is engaged, only does it in neutral or at standstill in gear (clutch disengaged).
I'm pulling the gearbox this weekend.
2005 E46 M3 Track - DIY Tuned - SSV2/BW 3.5" Single Exit - Schrick 288/280 - AEM Infinity - Karbonius CSL Intake - Nitron NTR R3 - Turner ARBs - Poly Bushed - Apex ARC-8 Square Setup - Alcon 365/345mm F&R BBK - Corbeau Buckets - Sabelt Harnesses - SD Half Cage - 6MT Conv. w/CAE Ultra Shifter - Seibon CSL Carbon Boot - GSR Carbon Wings
Jump to top paulclaude is offline   Reply With Quote
Old Fri, Feb-17-2017, 08:00:03 AM   #23
911Fiddler
United Kingdom
I had that same prob on my (this car) SMG, 3 years back. Was different noise Id say. At first I thought it was the power steering pump, was a growly rotary sort of noise. The clutch release bearing had failed.
Old Wed, Feb-22-2017, 05:53:14 PM   #24
911Fiddler
United Kingdom
News...
The job is moving slowly, injured finger!
-vanos is rebuilt and timed up using digital angle gauge (v accurate) as photo.
-checked the spark plugs to rule running issues out of play -all identical/perfect colour.
-I cut open the oil filter, nothing much in it at all (5.5k miles).
-I bought a new bucket, emptied the oil into it, waited 2 days for things to settle then looked at the dregs, outcome: virtually none (but some) metal, not enough to consider a rod bearing failure, unless as stated earlier, I've caught it & stopped the engine seconds after a spun shell.
I'm hoping its not a rod bearing and so far no evidence that it is, which is good of course, however instinct tell me it is.
More news asap.
Old Wed, Feb-22-2017, 06:05:06 PM   #25
HassanEido
HassanEido's Avatar
Lebanon
some metal isn't a good sign usually..I was hoping it would be a bad follower or a spit shim or something minor, maybe check those? Maybe u missed it
Mods:
Modified stock airbox,afe plastic intake elbow Afe prodry drop in, electric fan conversion,SSV2 catless headers, custom 2.5" dual sec1, custom sec2 2.5" dual with e9xM X pipe, SuperSprint Race inspired custom section 3,tms pulleys,Cat Cams 280 272, custom dyno tune, csl box to be installed sooooonn
357.7 whp 283.5 wtq
Custom exhaust thread and dyno:
http://m3forum.net/m3forum/showthread.php?t=569086
Cams thread and dyno:
http://m3forum.net/m3forum/showthread.php?t=554439
Custom cf airbox thread:
http://m3forum.net/m3forum/showthread.php?t=595180
Old Tue, Mar-14-2017, 06:13:59 PM   #26
911Fiddler
United Kingdom
Its the clutch!
-pivot pin looks ok
-attrition marks where the clutch release arm was hitting the clutch
-release bearing burnished on the outside, not the pressure face/land
Root cause,,,,,-> a bit unclear.
New everything in there should fix it
Old Mon, Mar-20-2017, 05:38:16 PM   #27
911Fiddler
United Kingdom
It was the clutch limit stop, -fractured after 40k miles.
New flywheel has killed off the M clunk ! I'm pleased.
Old Tue, Mar-21-2017, 12:53:03 AM   #28
M3_#67
Reputation: 0 M3_#67 is on a distinguished road
How did you arrive looking at the clutch?
'02 Imola Red on Black
Jump to top M3_#67 is offline   Reply With Quote
Old Tue, Mar-21-2017, 08:49:33 PM   #29
911Fiddler
United Kingdom
Progressively eliminated possible faults until best option was to drop out the gearbox. Only when out was the fault clearly visible.
Discussing Horrible engine noise in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
