Old Mon, Feb-13-2017, 08:49:50 PM   #11
911Fiddler
Reputation: 0 911Fiddler is on a distinguished road
United Kingdom
Default Re: Horrible engine noise
Cheers for the ideas. I dropped the oil into a clear plastic box and looked thoroughly through it, nothing at all. With damaged shell bearings I'd have expected white metal and or copper in there.....
Clutch eh, interesting, I've never had a clutch fall apart on me.
Jump to top 911Fiddler is offline   Reply With Quote
Old Mon, Feb-13-2017, 09:24:02 PM   #12
mleveroni
Reputation: 0 mleveroni is on a distinguished road
Just shooting out ideas here but if its not vanos or rod bearings, it sounds like there is a pressure leak on one cylinder. Like a header leak or something of that nature. Just really sounds like a pulsing sound more than a metal on metal clank, if that makes sense. I would check all the rocker arms and valves to make sure there is nothing messed up. Could potentially even be a cracked head/ head gasket issue. Have you tried driving the car since the noise? Is it throwing any codes? With the vanos and cams being fine, and clean oil, pinpointing this issue is difficult. These situations are the worst, good luck.
2002 M3 Carbon Black 6MT
ARP Headstuds|ARP Rod Bolts|Beisan Vanos|Topspeed Exhaust|AR20's|Ebay Headers|Turner Subframe Plates|ZCP Rims|Custom Rear Strut Bar|AKG Bushings|ST XTA Coilovers|Clutchmasters FX300 Clutch/Aluminum Flywheel|RK Tune
Jump to top mleveroni is online now   Reply With Quote
Old Mon, Feb-13-2017, 10:53:05 PM   #13
Jfbsaratoga
Reputation: 0 Jfbsaratoga is on a distinguished road
Could it be the water pump bearing?
Sent from my ONEPLUS A3000 using Tapatalk
Jump to top Jfbsaratoga is offline   Reply With Quote
Old Tue, Feb-14-2017, 12:50:58 AM   #14
CLAWHAMM3R
BELOW M3
CLAWHAMM3R's Avatar
Reputation: 0 CLAWHAMM3R is on a distinguished road
You can't see the cam bolts without taking the hubs off, so unless you did that and ommtted mentioning the total tear down of the front end, you shouldn't rule those out. What kind of sound does it make at start up. That's usually a dead give away on the bolts.
2004 ///M3
Jump to top CLAWHAMM3R is offline   Reply With Quote
Old Tue, Feb-14-2017, 10:02:31 AM   #15
911Fiddler
United Kingdom
Fair point, those bolts are inside the hub. If they're loose, can this be checked without dismantling? Eg checking for backlash?
Old Tue, Feb-14-2017, 02:29:24 PM   #16
schoonerm3
Reputation: 0 schoonerm3 is on a distinguished road
Ireland
You can visualise the back of the bolt. So you can rotate the engine and visualise the back of the bolts and with a pick you could see if they are loose or if they have backed out. But to definitely cannot see the head of the bolt or out a spanner in them as they are behind the hub.
Jump to top schoonerm3 is online now   Reply With Quote
Old Tue, Feb-14-2017, 03:20:14 PM   #17
911Fiddler
United Kingdom
[QUOTE=schoonerm3;1067591560]You can visualise the back of the bolt. So you can rotate the engine and visualise the back of the bolts and with a pick you could see if they are loose or if they have backed out. But to definitely cannot see the head of the bolt or out a spanner in them as they are behind the hub.
Cheers Ill go check this today.....standby for new news
Old Wed, Feb-15-2017, 08:07:31 PM   #18
911Fiddler
United Kingdom
Vanos internal bolts are good.
Top chain guide is not good!
She's not rebuilt as yet so until I've done that and run her I wont be sure this was the fault (might have 2 faults).
Old Wed, Feb-15-2017, 08:09:08 PM   #19
CLAWHAMM3R
BELOW M3
CLAWHAMM3R's Avatar
I hope it was as simple as that!
2004 ///M3
Old Wed, Feb-15-2017, 08:52:19 PM   #20
HassanEido
HassanEido's Avatar
Lebanon
Hope that was it! At your mileage if you haven't done the bearings yet, it's good idea to just do them now anyway.
Mods:
Modified stock airbox,afe plastic intake elbow Afe prodry drop in, electric fan conversion,SSV2 catless headers, custom 2.5" dual sec1, custom sec2 2.5" dual with e9xM X pipe, SuperSprint Race inspired custom section 3,tms pulleys,Cat Cams 280 272, custom dyno tune, csl box pending
357.7 whp 283.5 wtq
Discussing Horrible engine noise in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
