Old Sun, Feb-12-2017, 06:41:49 PM   #1
911Fiddler
Reputation: 0 911Fiddler is on a distinguished road
United Kingdom
Default Horrible engine noise
This evening, following a cold start up, car was sat idling for 10 mins whilst I did a bit of INPA, suddenly a knocking started in the engine, so I switched her off. I waited 5 mins then restarted her, noise had changed slightly but still there and horrible, arghhhhhhh!
Experience based opinions please on what it could be....
-engine has been v healthy, no knocks etc, looked after v well, lots of fresh parts.
-rod bearings done 20k miles ago, preventive refresh, crank journals were fine.
-vanos refresh last year, internal seals, but not the oil pump disk or the infamous bolts.
Right now I'm thinking it could be...
-vanos oil pump drive tab fracture.
-vanos bolt failure.
-spinning rod bearing shell. (Hoping it's not this)
Tomorrow I'll take off the top of the engine, check the vanos.
Deep misery. But at least it happened at home.
Jump to top 911Fiddler is offline   Reply With Quote
Old Sun, Feb-12-2017, 07:22:31 PM   #2
lmtfi
lmtfi's Avatar
Default Re: Horrible engine noise
What did you do in INPA before the knock?
Old Sun, Feb-12-2017, 07:26:23 PM   #3
HassanEido
HassanEido's Avatar
Lebanon
doesn't sound like a rod to me.. is it an SMG?
Mods:
Modified stock airbox,afe plastic intake elbow Afe prodry drop in, electric fan conversion,SSV2 catless headers, custom 2.5" dual sec1, custom sec2 2.5" dual with e9xM X pipe, SuperSprint Race inspired custom section 3,tms pulleys,Cat Cams 280 272, custom dyno tune, csl box to be installed sooooonn
357.7 whp 283.5 wtq
Custom exhaust thread and dyno:
http://m3forum.net/m3forum/showthread.php?t=569086
Cams thread and dyno:
http://m3forum.net/m3forum/showthread.php?t=554439
Custom cf airbox thread:
http://m3forum.net/m3forum/showthread.php?t=595180
Old Sun, Feb-12-2017, 07:29:50 PM   #4
911Fiddler
United Kingdom
Is was re pairing the cell phone in INPA at the time it started.
Shes an SMG, 150k miles, sweet runner up to now.
Tomorrow I'll first take of the drive belts and check the ancillaries, then the cam cover...
Old Sun, Feb-12-2017, 08:12:52 PM   #5
schoonerm3
Reputation: 0 schoonerm3 is on a distinguished road
Ireland
Sorry to hear this. Gutting after doing the preventative maintenance. Hope you sort it
Jump to top schoonerm3 is online now   Reply With Quote
Old Mon, Feb-13-2017, 01:11:03 AM   #6
sloww_M3
Reputation: 0 sloww_M3 is on a distinguished road
Sounds like vanos cam bolts to me, same thing happened to my dads car. He drove it like that for about a month (don't do that) and nothing detrimental happened to it, I replaced them with the upgraded bolts and no problems since. I would park it and tear it down and see what it looks like under the valve cover
Jump to top sloww_M3 is offline   Reply With Quote
Old Mon, Feb-13-2017, 01:56:39 PM   #7
911Fiddler
United Kingdom
News...
-Ancillaries, water pump etc are all ok, smooth and free.
-Vanos bolts and tabs look fine, cam lobes & chain also.
-I can see the chain tensioners and rails in place, don't seems to have moved.
-Oil is clear, no debris, likewise the oil filter as far as I can see.
So no evidence as yet, however I'm totally sure there's a problem. I still think its the rod ends, maybe as its just happened, its too early for copper debris to show up in the oil.
Anyone got any further suggestions?
Old Mon, Feb-13-2017, 03:17:50 PM   #8
bigjae1976
Pull the oil filter. If its making that much noise, you might be able to see metal shavings in the oil filter. A rod knock is more of a clacking sound. You can also drain the oil through a fine filter/mesh to see if you have any metal bits.
Does it move and drive? Does it sound like its coming from the front of the engine?
Could be a transmission related issue. Something loose with the clutch or pressure plate.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Mon, Feb-13-2017, 03:18:53 PM   #9
HassanEido
HassanEido's Avatar
Lebanon
I assume you took the drive belts off and sound was still present. If so, then drop the pan. Maybe chuncks are too large to go thru the oil pump screen . 150k no rod bearing service done?
Mods:
357.7 whp 283.5 wtq
Old Mon, Feb-13-2017, 03:20:32 PM   #10
HassanEido
HassanEido's Avatar
Lebanon
This also. A member had a horrible noise that turned out to be a broken pressure plate.. it was an smg.. thats why i asked. But as mentioned drain the oil and see what u find.
Mods:
357.7 whp 283.5 wtq
Discussing Horrible engine noise in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
