Old Fri, Feb-10-2017, 03:33:20 AM   #1
///ALpineVert
Reputation: 0 ///ALpineVert is on a distinguished road
Default Clutch DIY Venue?
So I want to DIY my clutch. I have 2 options:
1. Use the auto shop on my local military base. This place has lifts that I can rent for $10 per hour. I can't leave my car on the lift for more than one night. My concern is that I won't be able to finish in time. I also won't have much access to friends for help.
2. Jack stands in my garage. Much harder to do but I can take as much time as I want and have easier access to help. My M3 is a second car so downtime isn't an issue.
I'm leaning to option 2 due to the fact that something ALWAYS comes up on a project like this where I might need more time. I can't just leave it on base on the lift indefinitely.
Never done a BMW clutch, pretty intimidated actually but I think I can do it.
What would you do?
Thanks!
Jump to top ///ALpineVert is online now   Reply With Quote
Old Fri, Feb-10-2017, 03:46:55 AM   #2
Monterey///M3
Reputation: 0 Monterey///M3 is on a distinguished road
Default Re: Clutch DIY Venue?
It's not too involved, you can probably get away with doing it on the lift if you have everything you need and not have to go out and buy stuff. But with that being said, I'd go with option 2. I did mine on jackstands, and it wasn't too bad. I used the 6 ton Harbor Freight ones which have a lot of ground clearance.
You also hit it right on the head with something always coming up during a project.
Vehicles:
2004 Ti/Dove M3
1997 Boston/Modena M3 Sedan
Jump to top Monterey///M3 is offline   Reply With Quote
Old Fri, Feb-10-2017, 05:22:58 AM   #3
Rajvosa
Reputation: 0 Rajvosa is on a distinguished road
at home on jackstands.
my friend and I did his clutch only to find out that E46's have a self adjusting clutch ....guess what we had to redo the whole job again following weekend..haha .
Jump to top Rajvosa is offline   Reply With Quote
Old Fri, Feb-10-2017, 05:29:33 AM   #4
kaiv
SoCal S54 specialist :P
kaiv's Avatar
France
Do it at home and take your time. Get a set of 6-ton jack stands so you have plenty of room.
E46 ///M325i Touring journal
Old Fri, Feb-10-2017, 03:19:28 PM   #5
mdavidm3
Reputation: 0 mdavidm3 is on a distinguished road
I'd do it on jackstands at home. Once you have the exhaust and driveshaft out, it's just 11 more bolts to drop the transmission
AKG||Euro Headers||Tilton Twin Disk Clutch||RTD||Mishimoto||Customized Bimmerworld Race Exhaust||Kirk Rollbar||Schroth||Sparco||Momo||OMP||Ground Control||Eibach||JRZ RSpro (rear coilover)||PFC Z31 BBK||Enkei NT03||Nitto NT01||TTFS Tune||2800 lbs
Trackspec Autosports
MMI Vehicle Systems
Ravenol
IG: MD__M3
Jump to top mdavidm3 is offline   Reply With Quote
Old Fri, Feb-10-2017, 03:48:00 PM   #6
E46_USMC
E46_USMC's Avatar
Reputation: 0 E46_USMC is on a distinguished road
I was in the same situation as you. Do it at the shop on base, or do it at home in a garage. Ended up going to a friends house and we knocked it out in a weekend, as well as new brake pads, rotors, and a new clutch line.
Jump to top E46_USMC is offline   Reply With Quote
Old Fri, Feb-10-2017, 05:02:01 PM   #7
Cmamainer
Reputation: 0 Cmamainer is on a distinguished road
This, and with a transmission jack you can do this job alone if need be, also, If you have the stock shifter it's a great time to rebuild the linkage and replace the CPV o-ring on the engine.
Jump to top Cmamainer is offline   Reply With Quote
Old Fri, Feb-10-2017, 07:27:50 PM   #8
If you'd done one before I'd say lift, but since it's your first... better to not have the time pressure, at do it at home.
Old Fri, Feb-10-2017, 10:20:42 PM   #9
///ALpineVert
Thanks guys. I was leaning towards home as well, this seals the deal. Time to accumulate parts. I'll start with an auto solutions SSK.
Anyone know the lead time on their kits? I'd like to do the 20% kit but I don't want to have to wait several months to get it. Goal is clutch complete by mid April.
Old Fri, Feb-10-2017, 10:46:05 PM   #10
Chris_M
Chris_M's Avatar
Reputation: 0 Chris_M is on a distinguished road
Not sure what your base shop parking situation is, but do you have the option of simply pushing the car out into a parking area if not finished on time, and pushing it back in to complete another day? And is there an actual high lift transmission jack available?
Certainly doable in a home garage, but not particularly enjoyable IMO.
[2004 M3 Coupe - 1998 Wrangler Sport]
Jump to top Chris_M is offline   Reply With Quote
Discussing Clutch DIY Venue? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
