Old Tue, Jan-17-2017, 04:25:33 PM   #11
HassanEido
HassanEido's Avatar
Lebanon
Default Re: Why is my cammed s54 still making the same power?
I wrong in assuming even an untuned cam car would still make more power than before? The fact that it doesn't is what makes me skeptical.
Yes. An untuned cammed car will make less power.. my car made 313.4 whp before cams. After cams it was making 290.. some 23 whp were missing before the retune, similar loss was in torque it went from 267 to 245 or so
Mods:
Modified stock airbox,afe plastic intake elbow Afe prodry drop in, electric fan conversion,SSV2 catless headers, custom 2.5" dual sec1, custom sec2 2.5" dual with e9xM X pipe, SuperSprint Race inspired custom section 3,tms pulleys,Cat Cams 280 272, custom dyno tune, csl box pending
357.7 whp 283.5 wtq
Old Tue, Jan-17-2017, 05:06:31 PM   #12
nickpiper12
nickpiper12's Avatar
Reputation: 0 nickpiper12 is on a distinguished road
I would get on the dyno and have a custom tune done, only if the car checks out mechanically.
It took me months and multiple visits to the dyno with my tuner to achieve my results and drivability, 371whp/260wtq, on a stock head with the 288/280's.
2003.5 E46 M3 SMG | Alpine White/Black
2000 E46 Touring Sport 5MT | Steel Grey/Tanin Red
2011 E91 Touring Sport 6AT | Alpine White/Chestnut Brown
Jump to top nickpiper12 is offline   Reply With Quote
Old Tue, Jan-17-2017, 08:52:02 PM   #13
digger
Originally Posted by . View Post
Leak down was done. From my understanding there's nothing a compression test would show that the leak down wouldn't assuming I could even get accurate results in the compression check with these cams and the huge overlap.
i value compression test data over leakdown. i would only ever do leakdown upon finding issues with a compression test. compression test can tell you if cam base timing is off, you would expect a reduction with a cammed engine compared to stock, if the compression is higher the stock then youd know the timing is way off
post up overlayed dyno data, the shape of the curves can be revealing as whether its a vanos issue or something
its unlikely to be anything related to bottom end, most likely vanos and tuning but its always good to check mechanical things
1996 e36 M3 Evo
Jump to top digger is offline   Reply With Quote
Old Tue, Jan-17-2017, 09:32:27 PM   #14
CrookedCommie
Captain Slow
CrookedCommie's Avatar
Bulgaria
I'm not understanding how compression can be higher if timing is off, or lower because he's running different cams.
Jump to top CrookedCommie is online now   Reply With Quote
Old Tue, Jan-17-2017, 09:49:29 PM   #15
HassanEido
HassanEido's Avatar
Lebanon
Static compression changes, since longer durartion cams have higher overlap, and valves open sooner and close later. Which means that the cylinder might not seal as well statically while cranking, so you get a lower static compression reading if you test the conventional way, and it's partly why tuning is needed for cams. Of course vanos tuning changes that, and your dynamic compression will rise back with proper tuning, and with the added flow you'll be makibg more power.
Mods:
357.7 whp 283.5 wtq
Old Tue, Jan-17-2017, 09:52:43 PM   #16
digger
if its not timed correctly it could be installed over advanced, which raises cranking compression. a non vanos engine with similar specs would crank closer to 200psi, the s54 cranks lower than this because of the default cam installation position is retarded alot
1996 e36 M3 Evo
Old Tue, Jan-17-2017, 11:15:17 PM   #17
stash1
100% agreed w/this! It can take lots of trial and error to find the right combination of parts and tuning to make these motors come alive...just throwing parts at a car w/o proper knowledge and tuning sometimes ends with poor results.
Ya, agreed digger, but typically what we're seeing here w/folks that are having poor results running these 288 cams is a reduction in static compression from skewed cam timing. I think OP will eventually find that (barring any other mechanical defects) his is a cam timing problem...makes all the difference in the world!
EDIT: Just wanted to add that until mechanical cam timing has been corrected...everything else in the tune is irrelevant.
'04 AW/IR...Not Stock
Old Tue, Jan-17-2017, 11:24:38 PM   #18
digger
is the end result more advance in the vanos maps compared to what you end up with stock cam and optimised tune? Im assuming the IVC is going to end up somewhere close to what it was before with the standard cam within a few degrees. i would have still expect a gain somewhere at the very topend with no tuning changes
1996 e36 M3 Evo
Old Tue, Jan-17-2017, 11:24:55 PM   #19
TheWarHammer
TheWarHammer's Avatar
Reputation: 0 TheWarHammer is on a distinguished road
holy christ. you made 371 with 288s and just basic bolt ons? thats pretty damn good lol
Jump to top TheWarHammer is offline   Reply With Quote
Old Tue, Jan-17-2017, 11:42:38 PM   #20
nuc1
Meh
nuc1's Avatar
Reputation: 0 nuc1 is on a distinguished road
And if you aren't expecting the compression numbers to be lower you will go Code Brown after seeing what your brand new fully built engine with 288/280s reads.
Ask me how I know...
Mike
02 TiAg/Black 6MT
Go
- BW CSL Intake - Dinan ITBs - Ported & Polished Head - Schrick 288/280 - ARP Head/Main/Rod Bolts - Epic Rod Bearings - CP Pistons - Beisan VANOS - Okada Coils - SS V1 Stepped Headers & Catless Sec 1 - OEM Sec 2 - AA Gen 6 Sec 3 - OEM CSL MAP & Pressure Rail - CSL Software - 4.10 Polished Diff - TTFS Tune
Stop
- Brembo 355F/345R - Stoptech Pads (Street) - GC Street/Track SA 525/550
Show
- OEM Euro Front Bumper - OEM CSL Trunk - Polished OEM 19s - OEM Euro Folding Mirrors - OEM LEDs w/ BFD - Sunroof Delete - Dynavin - JL 12W6 - JL 300/2 & 500/1 - Focal K2P
15 MR/Black 320i Family Truckster
11 Tundra Super White/Black Actual Truckster
Jump to top nuc1 is offline   Reply With Quote
Discussing Why is my cammed s54 still making the same power? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
