Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > Regional M3's > Pacific
Pacific For events in California, Idaho, Nevada, Hawaii, and Alaska.
Old Tue, Jun-02-2015, 05:24:12 AM   #31
admranger
Registered troublemaker
Default Re: Las vegas area members check in
Originally Posted by t3ddftw View Post
Awesome, thanks for the offer! Sad that you don't do bottom end; bearings are next on the list for me and it's one of the only projects I don't feel comfortable tackling alone because of the crazy torquing procedure.
I never said I don't "do" the bottom end...I just haven't yet. It's on my "to-do" list for late December 2015 (as well as control arms, control arm bushings, etc.).
I have all the tools to do it with stock rod bolts, including a freshly calibrated Snap On angle torque wrench. For ARP bolts I need to get a stretch gauge like Kaiv uses.
At this point though it's too damn hot to work in the garage for me (I'm old, remember?). I do all my serious wrenching during the cooler months.
However, if there's an emergency need to do something, LMK and I'll help out if I can. Rod bearings are something that's best done after the car sits for a while (like overnight) to let all the oil drip into the drain pan vs. onto your head. I try not to look like I came off a wildcatter's oil rig right after striking the motherload!
email is the best contact method: admranger
at earthlink
dot net.
'11 E90 M3, Melbourne/Black/Fox Red/Black, 6MT, roof, PP2, heated seats, Eibach Pro Kit, GC Street camber plates, Arc-8's, Technic harness, JL XD 600/6
Old Fri, Jun-05-2015, 12:14:59 AM   #32
t3ddftw
t3ddftw's Avatar
Reputation: 0 t3ddftw is on a distinguished road
at earthlink
dot net.
Got it, thanks! Well, I'm not in a huge hurry just yet but I'm looking to get it done before the end of the year. I hear you about not working during the summer; I always end up drenched after just a few minutes under the car . Pretty sure garages only get hotter than they do here on the surface of the sun.
2006 M3 ZCP 6MT Interlagos Blue on Cinnamon interior
Mods
Engine: Full Beisan Systems VANOS rebuild
Transmission: CDV Delete
Exterior: Smoked Corners | Black Side & Kidney Grills | Painted Reflectors
My Build/OCD thread
Jump to top t3ddftw is online now   Reply With Quote
Old Fri, Jun-05-2015, 12:23:00 AM   #33
Maxima SE
445 FTW
Maxima SE's Avatar
Reputation: 0 Maxima SE is on a distinguished road
Guys, just a heads up to let you know that I am available on a limited basis to work on your cars. I'm happy to step you through the process if you have never done it before but want to learn (oil change, brakes, tranny, diff, clutch, suspension, whatever), install mods, valve adjust, vanos bullet proofing, suspension work, etc. Doesn't have to be an E46M3 as I've been doing this since my E30 days. General maintenance to race prep. I don't weld or do lower end work on engines (sorry). I'm not the fastest guy in the world either.
I have a lift and all tools at my place. I'm not in business doing this, just looking to pay for some new mods here and there! I have a day job that is demanding, so please be patient. If you are desperate, let me know and I'll adjust as best I can or point you to the right person in town to do the work.
I don't want to compete with Kaiv, but if you aren't headed to SoCal or can't wait for him to get back to Vegas...
email me at admranger at earthlink d0+ Ne+
Plus sign = 't' (too many spamming threads lately).
awesome. Im huge DIY too but im always hesitant tackling new challenging projects since im limited on tools and also few members are around to lend a helping hand if i cant pull it off myself. its good to know that there is a couple of competent members around town including ftc3. Im planning on dropping my rear diff in january to do all the bushings, bolts and seals. could definitely use some help
2005 6MT Phoenix Yellow///M3
Jump to top Maxima SE is offline   Reply With Quote
Old Fri, Jun-05-2015, 01:43:31 AM   #34
duracellttu
Anybody done the rear 4 ball joints before? Looking for a tool to help me remove them as well. That's my next job.
2005 BMW M3 ZCP - Black/Black Built not bought. All DIY!
Evolve-R | AP V2 Headers | CPI Euro200R (200 cell) | SS Non-res X-pipe + Race | 3.91 w/ 3 stage clutch | TCK SA 450/500 | Vorshlag Camber Plates
Rogue Engineering ASP, RSM, RTABs, TM | TMS Sway Bars, Camber Arms, Pullies | Mason Race Strut, Rear X-Brace | AS 30% SSK | aFe Stage 2 | SPAL Fan
AKG FCABs, SFB | Redish Reinforcement | Turbo Toys V2 Hub | WPC Treated Rod Bearings
Old Fri, Jun-05-2015, 04:10:37 AM   #35
admranger
I might know someone...
However, I kluged together the tools and ended up with a "doh" moment on one of them... Had to order another one to finish the job. Good thing I had plenty of time as I was reinforcing the subframe, replacing the subframe bushings (w/FTC3's awesome Koch tool!), etc.
It dawned on me later that I think I had the right tool at one time, but put it in a box of other puller tools a friend lent me. Need to find that...though it was one that you hammered the ball joints out (and in). Not delicate, but effective. E36M3 rear ball joints are the same iirc, so I had this tool for my old race car when I did those ball joints.
I bought the ball joint puller for my X5 and it was worth every penny. So much smoother and easier than either of my other methods.
Old Fri, Jun-05-2015, 04:13:47 AM   #36
duracellttu
Thanks! If you find something that will work let me know.
I'll keep you in mind if something goes wrong with my X5 or 550i also
Old Fri, Jun-05-2015, 04:22:50 AM   #37
admranger
Yeah, you don't want to screw around with a DIY setup on the X5 ball joints, especially if they've seen treated roads in winter. They can be a bear.
Old Fri, Jun-05-2015, 04:25:58 AM   #38
admranger
Tomorrow I'm doing an alignment on the E90M3 after installing my Eibach pro kit springs. I have the Ground Control street camber plates in there so lots of adjustment range... I have too much camber F&R and too much toe in at the rear.
The E90M3 suspension is so much easier to work with than the E46M3 (rear anyway) it's not even funny. I should have it knocked out in an hour or so with a couple of trials (assuming my wife will have time to help with the toe plates).
Old Fri, Jun-05-2015, 04:28:27 AM   #39
duracellttu
Nice man. What time you working on your car? I'd love to come by and lend a hand and introduce myself. Suspension is on my to do list later this year too
Old Fri, Jun-05-2015, 05:04:53 AM   #40
ftc3
Reputation: 0 ftc3 is on a distinguished road
Unfortunately I've earned a minor in M3 subframes over the past year
Id be glad to lend a hand. It's not that bad once you've done it a few times
I did all mine when I did the subframe refresh. I used the Koch tool which made the swap a breeze. The Koch tool works around the brake dust shield without having to bend it like some of the homemade presses. I didn't end up buying that one - I rented from Obioban.
If anyone needs the subframe bushing press, just let me know. It makes short order of those four beastly bushings!
My journal
Dinan Intake | Dinan TBs | Schrick 280/272 | SSV1| SS Res Sec 2 | Dinan Exhaust | Koni Yellow | Dinan Springs | TTFS Tune | 356WHP
Jump to top ftc3 is online now   Reply With Quote
Discussing Las vegas area members check in in the Pacific Forum - For events in California, Idaho, Nevada, Hawaii, and Alaska. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
