Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > M3Forum Marketplace > Parts for Sale/Wanted
Parts for Sale/Wanted Post your Parts Wanted, and non commercial bmw related items for sale. We ask that companies selling goods become a Sponsor to advertise your goods.
Old Thu, Sep-13-2012, 05:22:58 AM   #1
p0lar
Naturally Agitated
p0lar's Avatar
Default Brackets for E92 M3 Rear Rotors + 996 GT3 4-Piston Rear Calipers
As the title says, I now have brackets that work for the following E46 M3 rear brake applications:
  • E46 M3 rear rotors (ZCP/CSL/Euro/Standard 328mm x 20mm) + Porsche Boxster/Cayman S rear 4-Piston calipers, NO RUST RING! NO INTERFERENCE WITH UPPER WISHBONE MOUNTING BOLT! Requires FMSI D737 pad.
    • Part numbers for Boxster S/Cayman S rear calipers: 996.352.421 & 996.352.422
    • Part numbers for Boxster S/Cayman S front Textar pads: 996-352-949-03-M3
    • Part numbers for Boxster S/Cayman S rear Textar pads: 986-352-939-10-M3 (D738, will leave a rust ring!)
    • Part numbers for Boxster/Cayman "front" Textar pads: 986-351-939-15-M3 (D737, should not leave a rust ring on the rear application!)
    • Part numbers for Boxster S/Cayman S front pad hardware kit: 996 351 959 01
    • Part numbers for Boxster S/Cayman S rear pad hardware kit: 996 352 959 01
  • E92 M3 rear rotors (350mm x 24mm) + Porsche 996 GT3 rear 4-Piston calipers (flip the bracket around so that the caliper's offset is slightly more inboard), SLIGHT RUST RING (~3-4mm), NO INTERFERENCE WITH UPPER WISHBONE MOUNTING BOLT! Requires FMSI D917 pad.
    • Part numbers for 996 GT3 rear calipers: 996.352.425 & 996.352.426
Right Rear 19" CSL rep wheel, E92 M3 350mm rear rotor, Porsche 996 GT3 rear 4-Piston caliper - Got brake torque?
Remito's E92 M3 350mm Rear Rotor + 996 GT3 rear caliper:
Note: The E92 M3 rear rotor requires minor modification that can be performed on any brake lathe - the rear 'lip' that would ordinarily surround the E92 M3 parking brake bracket retaining ring must be machined flat to the parking brake drum. It's aluminum, it takes about 2 minutes each on a brake lathe at any auto parts store and should cost no more than $12 each to do. The E92 M3 rear rotor also has an internal drum diameter of 185mm as opposed to the OE E46 M3 rear internal drum diameter of 180mm. You can use the parking brake shoes from an E92 M3 or an E46 330Ci, they're the same.
Note: The E46 M3 rear rotor requires no modifications to either the rotor or parking brake shoes with the Porsche Boxster S calipers.
Note: The recommend brake lines are Centric 950.34000 for the front and Centric 950.34506 for the rear. These are BANJO style lines and include the proper bolt and crush washers for the E46 application. The reason I suggest these is due to the ease of replacing the sealing surfaces (crush washers). Using non-banjo lines on the calipers can result in improper torque application from the line to the caliper, which can damage the internal caliper seat, strip threads, or worse - cause irreparable leaks.
I'm selling the brackets, plus all included hardware (8 metric socket cap screws, at least 10.9 hardness), for $110 a set, shipped within the continental US via the USPS Priority Mail small flat-rate box. These are powdercoated in 'Black River' textured coating to protect against road debris/salt/corrosion, etc.
A few FAQs I get often:
  • YES! This is the same bracket for both applications! Thus, if you wish to upgrade to a larger rotor later, you need only purchase the caliper and E92 M3 rear rotor. The brackets remain the same and are simply 'flipped' over to change the caliper offset.
  • If you have questions about powdercoating, please contact mike@thepowdercoater.com. I am no longer able to address those questions as I am not a powdercoater and seem to get the answers wrong more often than not.
  • If you have questions about brake bias, please consult the thread listed in my signature, both these kits are good; however, the E92 M3 rotor-based kit has more brake torque available than the Boxster/Cayman S kit for the same pedal travel. I have written extensively about this and you can find just about any bias reference you want within that table. If not, please pose the question in that thread and I will address it promptly!
  • The Porsche Boxster S calipers will not fit the E92 M3 rear rotor. It's tight on the E46 rear rotor, and simply won't wrap over the significantly larger 350mm E90 M3 rear rotor.
  • Porsche Boxster S calipers are usually costing about $100-$125 each. They're cheap.
  • 996 GT3 rear calipers are usually costing about $250 each. *They're not cheap.
  • OEM E92 M3 rear rotors are approximately $528/pair from Turner Motorsports.
  • I cannot reliably source Porsche Boxster S or Porsche 996 GT3 (~2002 Porsche 911 Turbo) rear calipers, unfortunately.
  • Do not swap calipers from left to right (ever); however, you will be required to swap the lines from the right caliper to the left caliper's bleeder positions & vice versa. This will allow you to install the calipers with the bleeders facing up and the pistons in their proper arrangement for a trailing caliper orientation. Some rear calipers have indentations on both sides, some do not. In either case, the lines will swap without incident.
  • Pad recommendations can vary from application to application - the OEM Textars are great pads, but dust a lot. If you don't like dust, I won't be of much help - it doesn't bother me in the least.
  • These are fitments for OEM rotors. If you can find a rotor that works with the OEM brakes and is the same size, it should work. Try www.racingbrake.com for two-piece rotors. If it doesn't work, I won't be of much help unless you're willing to send one to me for a test fitment. If you want it back, you'll need to send return postage; otherwise, it's mine to keep!
  • I'm not sure if these brackets will work on other E46 applications. Maybe -- maybe not. Buy it to try, or ship me a rear trailing arm assembly, and I'll let you know very quickly. Alternately, stop by the house and we'll give it a go ourselves!
  • As with almost any rear BBK, the rear dust shield must be modified, its 'ears' can either be bent back, or cut off. This took me about 30 seconds per side, including slight grinding to debur the edges, when using a DeWalt 20V Max cut-off wheel. It made very short work of that task. Harbor Freight sells a very inexpensive cut-off tool that will do the same chore in the same amount of work. It should be good enough to make 4 cuts.
  • I don't know if your wheel will fit over the calipers or if your spokes will touch. OEM 18" wheels, as well as my 19" CSL replicas, will clear both applications. I won't comment past that unless you're willing to ship me your wheel - same shipping rules apply as above, heh, so don't turn your wheel into a spare coffee table for me.
  • Yes, you could easily make your own - go for it, they're that simple. Don't forget the expensive hardware, and the powdercoating, and the 6061-T6 aluminum, and making sure your holes are dead-on precise, and the cost of getting the right taps/drill bits, and a proper file, and.. and.. (You absolutely do not want a caliper that's not perfectly true to the rotor!)
  • I can no longer reserve sets, unfortunately. These are on a first come, first served basis - my sincerest apologies!
More information about the development and characteristics of the kit can be found in an upcoming thread in the E46 M3 section (to be discussed soon). This is simply the FS thread to keep track of orders for the brackets.
DISCLAIMER: I AM NOT LIABLE FOR WHAT YOU DO TO YOUR BRAKES. IF YOU BUY THIS KIT, YOU INDEMNIFY ME FROM ANY AND ALL LIABILITY THAT MAY ARISE FROM ABUSE/MISUSE/INSTALLATION OR ANY OTHER FORM OF OPERATION OF THE BRACKETS. THESE ARE FOR OFF ROAD USE ONLY. NOT FOR FITMENT TO ANY DOT-SANCTIONED VEHICLE. DO NOT USE ON THE STREET. BATTERIES NOT INCLUDED OR NECESSARY.
Jump to top p0lar is offline
Rate Seller View Rating
Old Thu, Sep-13-2012, 01:17:04 PM   #2
p0lar
Naturally Agitated
p0lar's Avatar
Default Re: Brackets for E92 M3 Rear Rotors + 996 GT3 4-Piston Rear Calipers
order tracking.
Old Fri, Sep-14-2012, 02:33:27 AM   #3
p0lar
Naturally Agitated
p0lar's Avatar
Reserved + Bump - I found enough hardware locally to finish 5 more sets of these and get them moving out the door immediately.
Old Sun, Sep-16-2012, 06:19:51 PM   #4
p0lar
Naturally Agitated
p0lar's Avatar
4 sets are immediately available - I'll purchase more hardware on Monday to complete more sets.
Old Mon, Sep-17-2012, 01:17:38 PM   #5
SliM3
SliM3's Avatar
Hey p0lar,
Just purchased a pair of GT3 rear calipers and would like to purchase your brackets as well. Can you please forward me the details for ordering?
Thanks
///M3 '06 Carbon Black
-Benjamin Franklin
- Fuel adaptations explained
- Checksum Verification
Old Mon, Sep-17-2012, 01:28:21 PM   #6
p0lar
Naturally Agitated
p0lar's Avatar
Originally Posted by SliM3 View Post
Hey p0lar,
Thanks
Really!? I didn't think anyone was going to be crazy enough to do the 996 GT3 caliper + E92 M3 rear rotor conversion! SWEET!!! I'll be MORE than happy enough to sell them to you as you'll be the only other car other than mine with it on there.
You've got a PM incoming!
Old Tue, Sep-18-2012, 07:05:09 PM   #7
MartynT
MartynT's Avatar
United Kingdom
My brackets arrived to me in the UK today, great service from Steph!
Jump to top MartynT is offline   Reply With Quote
Old Tue, Sep-18-2012, 07:25:56 PM   #8
p0lar
Naturally Agitated
p0lar's Avatar
I'm happy to hear it, Martyn! Please keep me updated on your installation - feel free to post photos here too, if you like.
Old Sat, Oct-06-2012, 02:18:49 AM   #9
p0lar
Naturally Agitated
p0lar's Avatar
I've not heard anything back from the mods after two weeks, so I'm bumping this up as it's a sunk cost if at least what's left in the box doesn't sell!
Old Sat, Oct-06-2012, 03:46:20 AM   #10
t3stman
t3stman's Avatar
Reputation: 0 t3stman is on a distinguished road
Please post up pics and provide any inputs on this setup! I'm interested to know as i'm on the fence
Hey p0lar,
Thanks
2005 ///M3Alpine White with Imola Red Nappa Leather, 19", NAV, ZCP Competition Pck, and SMG
Cosmetic Mods: OEM CSL Bootlid, OEM CSL Diffusor, OEM Euro Fire Extinguisher, Premium Clear Bra, EAS Aurora Angel Eyes 6000k, EAS CF Titanium seat outer trims, EAS CF Titanium upper trim, EAS CF Titanium SMG Dome, Ice-Link, Painted Matching Bumper Reflectors, Painted Hood Grill, 40% Huper Optik Tint, and Ultimate pedals.
Performance Mods: VFE Stg2, SS stepped headers, cats, x-pipes, and NOW KW v3
91 Pump - 478.86 HPs
MS-109 - 511.56 HPs
Future Mods: Eibach or GC swaybars, BBK, and Hard wired V1
Jump to top t3stman is offline   Reply With Quote
Discussing Brackets for E92 M3 Rear Rotors + 996 GT3 4-Piston Rear Calipers in the Parts for Sale/Wanted Forum - Post your Parts Wanted, and non commercial bmw related items for sale. We ask that companies selling goods become a Sponsor to advertise your goods. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
