Old Thu, Jan-20-2011, 05:31:08 AM   #1
Sunnyside
Sunnyside's Avatar
Reputation: 0 Sunnyside is on a distinguished road
Default loss of power, do these throttle bodies look normal? ( PIC )
I posted about my 2001 e46 m3 with 93k getting sacked by a massive power loss ( with no check engine lights )
Here's a picture of my throttle bodies, does anything look strange or out of place? why are 4 of the 6 visually darker / dirtier? Should I clean them?
Here's what the mechanic said:
"Tomorrow we are going to try a reinstall of the original (stock) DME software to see if the system works properly. We are obtaining the voltage reading for the EDK motor assembly to see if it is a EDK motor, wiring harness or terminal issue."
So far have replaced air filter, spark plugs, fuel filter, checked exhaust back pressure, VANOS test, compression test...
DAMN U POWER LOSS, I WILL DEFEAT YOU!
Jump to top Sunnyside is offline   Reply With Quote
Old Thu, Jan-20-2011, 02:01:39 PM   #2
Ramp1
Ramp1's Avatar
Reputation: 0 Ramp1 is on a distinguished road
Default Re: loss of power, do these throttle bodies look normal? ( PIC )
I would clean them but more importantly, why is there such a difference in them. It's not like is all the front or all the back...1 and 4 are clean and the rest are dirty. That leads me to think you have an issue with your intake valves closing properly...was the compression test even across all 6?
Keep us posted.
Jump to top Ramp1 is offline   Reply With Quote
Old Thu, Jan-20-2011, 02:09:44 PM   #3
apnea
Reputation: 0 apnea is on a distinguished road
Keep us posted.
Um, what he said. What did your mechanic think of what you just showed us?
2002 Jet black/Imola SMG
Supersprint X-pipe, S-pipe; Eisenmann race muffler; AFE intake; Bilstein PSS9's; SSR GT-3 wheels with Nitto NT05's
Tools I can loan: Bilstein spanner wrenches, Motive power bleeder, Peake code reader
Giving away: single Active Autowerke rear camber control arm for anyone who wants a spare. Active no longer makes or has parts for these.
Jump to top apnea is offline   Reply With Quote
Old Thu, Jan-20-2011, 02:14:06 PM   #4
Simann
Reputation: 0 Simann is on a distinguished road
Always check compression first when there is a power loss with no CEL.
Check fuel injectors and fuel filter.
Make sure throttles are able to be moved wide open, maybe one of the actuators motors is not articulating the full range (mechanical problem not seen by computer).
Jump to top Simann is offline   Reply With Quote
Old Thu, Jan-20-2011, 02:18:56 PM   #5
apnea
Is this something you could ascertain with passive activation (ie your finger)?
Old Thu, Jan-20-2011, 02:57:29 PM   #6
ovrstr08
ovrstr08's Avatar
Reputation: 0 ovrstr08 is on a distinguished road
That looks like oil residue to me have him chack crankcase vacum. you could have a failing oil seperator. I have never had our intake apart but if it were baffled or sectioned in a way it might keep the oil form getting to those throttle assy. just a thought.
Jump to top ovrstr08 is offline   Reply With Quote
Old Thu, Jan-20-2011, 07:17:59 PM   #7
Sunnyside
Sunnyside's Avatar
Keep us posted.
we did do a compression test, all cylinders showing 160 across the board. ( thank jebus it wasn't a compression issue, i nearly **** my pants waiting for the results... )
We did change out the fuel filter, I'm not sure if we've checked the fuel injectors. Here's the diagram he sent over, I think he's going to check all the values and hopefully pinpoint the issue.
I'll bring this to his attention. I definitely want to make sure I address any issues I find weather they be minor or major, I want my car running like new when I get it back.
Thanks for all the feedback, i'll keep you guys posted...
Old Mon, Feb-07-2011, 12:04:21 PM   #8
ovrstr08
ovrstr08's Avatar
Did the shop fix your car?
Old Mon, Feb-07-2011, 05:39:39 PM   #9
bvnmspt
bvnmspt's Avatar
Reputation: 0 bvnmspt is on a distinguished road
Have you ever ran out of fuel? Is your fuel level correct on your gauge?
My guess is that your fuel pump is bad. If it can't maintain pressure of I believe 5 bars, you're going to lose power.
I ran out of fuel couple times since my fuel level gauge was off. When I ran out of fuel, my fuel pump got damaged since there wasn't any fuel to cool and lubricate it. When I filled the car back up, I notice that my car lost major power. I just replaced the sender unit, fuel pump, and the fuel filter. Everything is fine now. If I were you that's where I would start. The pump goes for $300, the sender unit goes for $70. Since you have 93K miles, the pump is most likely the culperit. There are DIYs online. It takes about 1 hour to do both.
Fuel pump DIY
http://www.m3forum.net/m3forum/showt...=fuel+pump+diy
Read the blurb about the fuel pump on Turner's website...
http://www.turnermotorsport.com/html...ID=16142229684
I found that tischer bmw was the cheapest. I also changed my fuel sender unit since my fuel level gauge was off.
Dream as if you'll live forever. Live as if you'll die today.
Jump to top bvnmspt is offline   Reply With Quote
Old Sun, Mar-19-2017, 10:48:30 PM   #10
BMWM3180
Reputation: 0 BMWM3180 is on a distinguished road
This is an OLD post ,Please Update results !
Have similar issues and would like to see what you Found . Thx
Jump to top BMWM3180 is offline   Reply With Quote
Discussing loss of power, do these throttle bodies look normal? ( PIC ) in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
