Old Mon, Mar-20-2017, 12:22:21 PM   #21
schoonerm3
Reputation: 0 schoonerm3 is on a distinguished road
Ireland
Default Re: RACP cracking / separation
Any pics of the front mount upper welds?
Jump to top schoonerm3 is offline   Reply With Quote
Old Mon, Mar-20-2017, 01:30:04 PM   #22
SliM3
SliM3's Avatar
Reputation: 0 SliM3 is on a distinguished road
Originally Posted by bigjae1976 View Post
I love the garage walls...are you in the basement of a medieval castle or something?
Ha, too funny. That was the first thing I noticed too! Some of that hard to find REAL stone and not recycled left overs.
GL with the RACP ops Flow
Jump to top SliM3 is offline   Reply With Quote
Old Mon, Mar-20-2017, 02:08:36 PM   #23
kokgo20
kokgo20's Avatar
Reputation: 0 kokgo20 is on a distinguished road
Originally Posted by jdev View Post
His might not be that bad yet, but I'd definitely inspect the tops of the front mounts and reinforce those welds if I were him. Yours had cracks around the spring perch if I remember right. He might not have that yet, but I agree he likely has other spot weld stress in the floor next to the wheel arch.
Some general advice for everyone. Buy and use crack locating dye. I thought my front left was ok, but just happened to see a crack in the right light. The cracks can be longer than you see with your eyes as well.
What's that crack locating dye look like? And how do u use it to check for cracks?
Build thread
05/2004 SMG PY/BLK - 600 TCKline - CPI Headers & resonated Sec1- Stoptech BBK 6 pod front & 4 pod rear with steel lines - 75mm Studs conversion - PF RTABs & FCABs - AKG subframe bushings - Multi color AEs - FR-X 3.0 Projectors - Smoked Side markers - Euro bumper - V1 with hard wire & Stealth one - M Track Mod - ZCP steering rack - Dual LI - CSL Style diffuser - SCZA Exhaust - E9x Door handle LED retrofit - SCZA CSL bootlid - VEI systems custom air vent A/F & boost gauge - VEI custom air vent Water temp & oil pressure guage- Active Prima plus + FS tune - Mishimoto Radiator & Oil cooler - H&R front Sway - UUC camber arms - keyless & push to start system - clear bra - interiors red stitching contrast - Apex PS7s - 16" Spal fan
Jump to top kokgo20 is offline   Reply With Quote
Old Mon, Mar-20-2017, 02:28:56 PM   #24
Kdubski
Kdubski's Avatar
Reputation: 0 Kdubski is on a distinguished road
In the case of these minor cracks and installation of vince bar, will you need to repair these cracks? Will the vince bar serve as a repair itself and simply stop them in their tracks?
Jump to top Kdubski is offline   Reply With Quote
Old Mon, Mar-20-2017, 02:33:48 PM   #25
0-60Motorsports
Established 1998....
0-60Motorsports's Avatar
Bahrain
You Have to repair themBefore you move forward with the install or during the install Of the vincebar.
Jump to top 0-60Motorsports is online now   Reply With Quote
Old Mon, Mar-20-2017, 02:42:28 PM   #26
Kdubski
Kdubski's Avatar
repair in what way? Would drilling at the beggining and end of the crack, and welding over the crack suffice?
Old Tue, Mar-21-2017, 03:40:53 AM   #27
STAATS
STAATS's Avatar
Reputation: 0 STAATS is on a distinguished road
Yes. Drilling at the beginning and end of the crack, and welding over the crack will repair the crack as part of either Redish Motorsport / Turner Motorsport Plates install and/or VinceBar / CMP Engineering Bar installs.
STAATS
BMW E46 M3 Vehicle Log Book & Service Tracker Tool: http://www.m3forum.net/m3forum/showthread.php?t=564731
BMW E46 M3 Vehicle Data Record & Modification Journal Template: http://www.m3forum.net/m3forum/showthread.php?t=566440
2003 BMW E46 M3 Street / Road Rally Build: http://www.m3forum.net/m3forum/showthread.php?t=566468
Jump to top STAATS is offline   Reply With Quote
Old Tue, Mar-21-2017, 07:54:52 AM   #28
jdev
Reputation: 0 jdev is on a distinguished road
start here: https://en.wikipedia.org/wiki/Dye_penetrant_inspection
02 Silver/Red
Jump to top jdev is offline   Reply With Quote
Old Wed, Mar-22-2017, 02:15:30 AM   #29
Fhcrubarb
Fhcrubarb's Avatar
Reputation: 0 Fhcrubarb is on a distinguished road
It looks like you caught it early enough that you won't have to fully replace the RACP. Good luck
Jump to top Fhcrubarb is offline   Reply With Quote
Discussing RACP cracking / separation in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
