Old Sun, Mar-11-2018, 01:02:34 AM   #11
JitteryJoe
Default Re: M50 manifold installation question (yet another)
Bend it.
I know those CNC adapters look like they make the M50 conversion a breeze... but they don't (They do work well though). Everything will be kind of tight with it.
Thanks Braymond. I got pissed and cut off about 1/2 inch off the bracket. You are right. Not as easy as the sellers make out. True for this and other aftermarket mods as well.
Old Mon, Mar-12-2018, 02:33:59 PM   #12
BMWManiac
Turbo 97 M3
BMWManiac's Avatar
Reputation: 0 BMWManiac is on a distinguished road
I'm another that has left off the braces....over-engineered parts?
1997 Artic Silver M3
CES Stage IV - 651rwhp/615rwtq@ 24 psi
Jump to top BMWManiac is offline   Reply With Quote
Old Mon, Mar-12-2018, 05:01:07 PM   #13
JitteryJoe
I left the rear support brace as I did not have any problem fitting it. The front simply does not fit with the aluminum adapter plate installed.
Old Mon, Mar-12-2018, 05:03:09 PM   #14
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
Looks like the whole thickness of that blue adapter plate is extra space between the manifold and the M52 'plate'.
In 2012 I used an Alpina357 (Guy from UK) converted M50 manifold, that has the M52 plate as good as directly fitted to the manifold.
This made it PnP without any issues.
Old Mon, Mar-12-2018, 06:42:41 PM   #15
JitteryJoe
That sounds great. Lowering everything with the adapter plate causes a lot of fitment issues. I worked around them but I wished the TMS instructions took into account all the messing around needed to get the fitment right.
Does the person you mention make these for sale?
Old Mon, Mar-12-2018, 09:41:46 PM   #16
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
The old forum is dead. Don’t know if he still does it. I guess it’s not really a business anymore.
Still need to remove mine, as I want it make to stock. Since I have the M3 now.
I also bought bigger tb’s kit from him (main and asc+t).
Old Tue, Mar-13-2018, 03:39:43 PM   #17
NotUrAvgM
Reputation: 0 NotUrAvgM is on a distinguished road
Speaking of the TMS kit, if anyone wants one I have one for sale
-Matt
[2004 330xi/6] Orient/Natural :: 147k :: ZSP :: ZPP :: ZCW
[1998 M3/4/5] Cosmos/Black :: 126k ::TCKline D/A (500/600) :: GC plates :: RD Sways :: GC Rear Arms :: BW FCAB :: BW RTAB :: AKG Subframe :: 3.64 Diffsonline :: TMS Pulleys :: AA + Borla :: XBrace :: AS SSK :: ZHP Rack :: M50 :: DTC60 :: Direzza ZIII :: Safety Equipment
[2016 Yamaha R3] White/Red
Past:
[1995 M3] Avus/Dove :: 242k :: S52 OBDI :: M50 manifold :: 3.5" HFM :: Turner Chip :: XBrace :: SS Lines :: Turner RTABS :: Vogtland CS :: Bilstein Sport
[1999 M3] Cosmos/Black :: 87k :: TCKline S/A (400/500) :: Turner plates :: UUC Front Sway :: PF RTABs :: AA Intake :: Borla :: XBrace :: TRM C2s :: CL RC6E :: Direzza ZII :: Safety Equipment
[1993 325is] Brilliant/Black :: 139k :: Bilstein sports :: Eibach sways and springs :: Dinan camber plates and chip :: Borla :: LSD
[1983 320i] Safari/Brownish :: 242k :: homebrew CAI :: some rust :: multicolor body panels
Jump to top NotUrAvgM is offline   Reply With Quote
Old Wed, Mar-14-2018, 06:11:36 PM   #18
Mindart
Reputation: 0 Mindart is on a distinguished road
Hey guys... fwiw... I just used my front bracket and omitted the back bracket.
as for fitment issues... i have had all the above issues as stated, needing to bend the larger hard coolant line as well as the smaller coolant line that feeds the TB. I also found when i went to put the TB back on it was all shifted down so i had to bent the smaller hard line back up. I also found that the OEM bracket actually is touching the hard coolant line! when the manifold is seated property and down all the way.... is that normal? is there concern for long term reliability issues.
another issue i found is the ICV plug... it is basically touching the hot lead to the starter... no wires are exposed but that still doesn't seem ideal.... same for you guys? doesn't seem like i can get that terminal wire to bend any more.
Lastly i found that the CCV hose return to the dip stick needs to be shortened as the OEM hose is too long and bends akwardly which if figured would fight gravity on the return tot he oil pan. Also the CCV is relocated down and is VERY close to the motor mount bracket that connects to the block... is this NORMAL too and are there any long term issues?
Here are some pictures.. i stripped and painted my turner adapter to black so its more discreet for SMOG purposes. Any feed back on my work is invited
thanks
Jump to top Mindart is offline   Reply With Quote
Old Wed, Mar-14-2018, 07:09:33 PM   #19
JitteryJoe
thanks
I cut the bottom off the bracket so it would not press hard against the metal coolant line. I did not have the issue with the IVC plug. I re-routed it so there is less stress on the wire. I also installed a new starter and the new starters are smaller in size than the original (still a Bosch unit).
Old Wed, Mar-14-2018, 07:15:53 PM   #20
Mindart
Do you feel like cutting the bracket was totally necessary?
Can you explain how you re-routed it? did you cut the zip tie it was bundled too and then run it around the back of the starter cable?
Also... do you see any issues with the CCV being so close to the motor mount bracket?
thanks!
Discussing M50 manifold installation question (yet another) in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
