Old Sat, Jul-15-2017, 05:41:12 PM   #11
black bnr32
Reputation: 0 black bnr32 is on a distinguished road
Default Re: Overheating water temp at high rpm.
I assume there's a thermostat in the stock oil cooling system, no? maybe it's not cooling the oil at all.
Jump to top black bnr32 is offline   Reply With Quote
Old Sat, Jul-15-2017, 06:19:58 PM   #12
IRM3
Reputation: 0 IRM3 is on a distinguished road
I do have stock ODV but the car should overheat under normal driving if that fails.
Jump to top IRM3 is offline   Reply With Quote
Old Sat, Jul-15-2017, 06:33:23 PM   #13
black bnr32
I disagree.
Old Sat, Jul-15-2017, 07:03:01 PM   #14
IRM3
Driving in the city in 115 degrees with AC on with no oil cooling should raise the temp, but I had no temp issue under such condition.
Old Sat, Jul-15-2017, 07:25:13 PM   #15
PITT M3 RR
PA
PITT M3 RR's Avatar
I don't remember the exact thread but I'm 99% sure a new OEM rad was the FIX. After, the old was cut open and the passegess were reduced by nearly half their capacity as deposits and build up accumulated. You could soak it in an aluminum / plastic safe solvent to break that up, then flush.
I took out my behr e36 unit during my swap, back flushed it and blew compressed air the opposite direction. I got a ton of shit out.
S54 E36 BUILD
Old Sat, Jul-15-2017, 07:47:18 PM   #16
IRM3
Originally Posted by PITT M3 RR View Post
I don't remember the exact thread but I'm 99% sure a new OEM rad was the culprit. After, the old was cut open and the passegess were reduced by nearly half their capacity as deposits and build up accumulated. You could soak it in an aluminum / plastic safe solvent to break that up, then flush.
I will try that. Thank you for suggesting it. I was looking into Bluedevil radiator flush but I don't want to risk putting anything corrosive in my engine block. I'll take the rad out and flush it that way.
Old Sat, Jul-15-2017, 08:23:11 PM   #17
PITT M3 RR
PA
PITT M3 RR's Avatar
Fixed my post, new oem Rad was the FIX*** old one was compromised at race level stresses.
S54 E36 BUILD
Old Sat, Jul-15-2017, 11:14:55 PM   #18
speeeding
Reputation: 0 speeeding is on a distinguished road
Hey IRM3, glad you posted this. We were having the same problem at Thill.
Jump to top speeeding is offline   Reply With Quote
Old Sun, Jul-16-2017, 12:00:54 AM   #19
exodus454
Reputation: 0 exodus454 is on a distinguished road
Stupid I know, but I've noticed this on mine a few times when I've overfilled the oil slightly by mistake. Usually cruising around my oil temp needle is at 11:30, when overfilled it would sit at 12:30 and regularly climb up to 215*. Water temp was also warmer than normal.
Sucked 1/4 L out and back to normal.
05 ZCP - 6MT >> CPI Stepped Headers - Magnaflow cats & 1 Cherrybomb - Meisterschaft Titanium - CSL software - Eibach pro kit - 15mm rear spacers - BW studs - GC Hybrid FCABS - BW Spherical RTABS - TMS front bar
Manual Leveling - Factory Xenon - Nightbreakers - ZKW-R lenses
Jump to top exodus454 is offline   Reply With Quote
Old Sun, Jul-16-2017, 09:54:18 PM   #20
IRM3
Solved the overheating issue. It turned out to be bad fan clutch. I didn't think to check since it was replaced less than two months ago. The fan clutch was Behr/Hella brand, not expensive OEM unit. I'm very surprised at how quickly it fails.
Discussing Overheating water temp at high rpm. in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
